Request for the new command - change baudrate
Re: Request for the new command - change baudrate
Postby costaud » Thu Oct 30, 2014 2:10 am
Maybe you can try to add your own CMD in the AT SDK,
and change the baudrate via
maybe there should be some sync steps .
and reset uart tx rx fifo :
By the way , there would be a sdk patch for a potential uart bug these days.
I have tested the uart , it can support a high speed up to 115200*40 bps
uart_div_modify(uart_no, UART_CLK_FREQ / (Your_baut_rate));
SET_PERI_REG_MASK(UART_CONF0(uart_no), UART_RXFIFO_RST | UART_TXFIFO_RST);
CLEAR_PERI_REG_MASK(UART_CONF0(uart_no), UART_RXFIFO_RST | UART_TXFIFO_RST);
Postby AlOdin » Fri Oct 31, 2014 3:23 pm
have added the +BAUD command
please include this mod to official release
- Attachments
- AT_addBAUD.zip
- (1.64 KiB) Downloaded 982 times
Regards, Alexander
Postby igrr » Fri Oct 31, 2014 4:32 pm
The standard command for setting baud rate is +IPR. There's really no need inventing custom names for standard features of AT protocol.
Also you may want to save the baud rate into the user settings region of the flash, otherwise it's a bit pointless.
Postby AlOdin » Fri Oct 31, 2014 10:36 pm
actually name of command is not important for me
i have shared this code for the Espressif developers as an example only
i want to help them to make their AT-firmware more usable for the real projects
Regards, Alexander
