I work for a medical device manufacturer. We are considering integrating the WROOM-02 Espressif module in our devices to connect to a server to send information regarding the status of the device and to receive some information (changes in settings, for example).
We would communicate with the WROOM-02 module from our medical device microprocessor. We were planning to do so by using AT commands. This is the same strategy we are using to communicate with other communication modules (for example, GSM), and is quite simple to integrate in our microprocessor code. However, we do not know how to proceed to establish de SSL connection. We want to use certificates at least at the server level, and maybe also in the client (in the WROOM-02 module). When we read the docummentation, we understand that we have to flash the firmware of the Espressif module to load the certificates. However, in the GSM module, we can do so using an AT command, which significantly simplifies the process. Moreover, once the certificates are uploaded, we are not sure if we will be able to manage the communication using AT commands or if we need to use the API somehow.
Could you please give me some tips? I really appreciate your help. We are trying to decide if this module would be adequate for our application.
Manage SSL connection using AT commands
Re: Manage SSL connection using AT commands
Postby prgvitor » Thu Sep 09, 2021 5:08 am
Hello Friend
Have you been successful in your project with SSL implementation (certificates and keys)?
If yes, please help me, as I have the same problem, I tried several times to include the certificates in ESP8266 but I was unsuccessful.
Thanks,
Att
Thanks,
Att
Postby Her Mary » Fri Sep 10, 2021 11:06 am
Could this document help? https://docs.espressif.com/projects/esp ... connection
