On compiling this program I wrote it is able to receive UART from the live SCREEN terminal I have opened that is MicroUSB into a Wemos D1 Mini Pro. That work's fine. However I also have a UART Bridge on another port wired to RX and TX pin, I am receiving data but when I send via my bridge it does not kick off the receiving of the data on the ESP. It seem's only when I send via the Live Screen Terminal it works and not through the RX pin. However, if I short the RX and TX everything works fine and kicks off the correct INT's which makes me think It's receiving the data but not interpreting it as a byte received. Maybe the Stopbit is wrong or something I am not sure. Does anyone have any tips?
Thanks,
-Agent
https://wiki.wemos.cc/products:d1:d1_mini_pro
//https://www.mikrocontroller.net/attachment/263828/The-ESP8266-Book-August-2015.pdf
#include "ets_sys.h"
#include "osapi.h"
#include "gpio.h"
#include "os_type.h"
#include "ip_addr.h"
#include "mem.h"
#include "user_interface.h"
#include "lwip/stats.h"
#include "espconn.h"
#include "c_types.h" ////ONE WIRE
#include "../library/uart.h" //Copy these from your Driver Lib to your local folder
#include "../library/gpio16.h" //Copy these from your Driver Lib to your local folder
#include "../library/common.h"
#define user_procTaskPrio 0
#define user_procTaskQueueLen 1
os_event_t user_procTaskQueue[user_procTaskQueueLen];
void uart0_tx_buffer(uint8 *buf, uint16 len);
char rxbuff[31];
char rxindex = 0;
void UartReceive(char ByteReceived)
os_printf("[%s] Got UART Callback!\r\n", __func__);
os_printf("Byte Recevied: %c\r\n", ByteReceived);
rxbuff[rxindex++] = ByteReceived;
if (rxindex == sizeof(rxbuff))
rxindex = 0;
else
os_printf("%d != %d\r\n", rxindex, sizeof(rxbuff));
os_printf("Buffer: %s\r\n", rxbuff);
void ICACHE_FLASH_ATTR sdk_init_done_cb(void)
os_printf("[%s] initializing ESP8266!\n", __func__);
while(true)
uart0_tx_buffer("test", 4);
delay_second();
delay_second();
void ICACHE_FLASH_ATTR user_init()
uart_init(BIT_RATE_115200, BIT_RATE_115200, &UartReceive); //This only seems to be kicked off via the COM-USB onboard, Not the TX/RX port
//system_uart_swap(); //http://smallbits.marshall-tribe.net/blog/2016/11/13/esp8266-quiet-uart - Makes D7 RX and D8 TX
system_init_done_cb(sdk_init_done_cb);
wifi_set_opmode(0);
wifi_set_sleep_type( NONE_SLEEP_T );
ETS_GPIO_INTR_DISABLE();// Disable gpio interrupts
gpio_init();
SetAllGPIOPinsAsOutput();
/* Need to fix this to display value */
uint32 VDDADCByte[4] = {0};
spi_flash_read(0x3fc06b, (uint32 *)&VDDADCByte, 1); //Read pads the other 3 bytes with FF
os_printf("\r\n\r\nStarting ESP8266 OTA!\r\nSDK version:%s\r\nLoaded from: %02x\r\nVdd33_Const: %02x\r\n", system_get_sdk_version(), system_get_userbin_addr(), (VDDADCByte[0] & 0xff));
//Turn off LED
gpio_output_set((1 << 2), 0, 0, 0);
//Start os task
//system_os_task(loop, user_procTaskPrio, user_procTaskQueue, user_procTaskQueueLen); //Task to Signal for later
}Code: Select all
LOCAL void ICACHE_FLASH_ATTR uart_config(uint8 uart_no, void * callback(uint8))
os_printf("uart_config:%d", uart_no);
if (uart_no == UART1)
PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO2_U, FUNC_U1TXD_BK);
else
/* UART0 */
ETS_UART_INTR_ATTACH(uart0_rx_intr_handler, callback);
PIN_PULLUP_DIS(PERIPHS_IO_MUX_U0TXD_U);
PIN_FUNC_SELECT(PERIPHS_IO_MUX_U0TXD_U, FUNC_U0TXD);
//Enable RxD pin
//PIN_PULLUP_EN(PERIPHS_IO_MUX_U0RXD_U);
//PIN_FUNC_SELECT(PERIPHS_IO_MUX_U0RXD_U, FUNC_GPIO3);
//PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDO_U, FUNC_U0RTS);
uart_div_modify(uart_no, UART_CLK_FREQ / (UartDev.baut_rate));
//UART 1 always 8 N 1
WRITE_PERI_REG(UART_CONF0(uart_no), CALC_UARTMODE(EIGHT_BITS, NONE_BITS, ONE_STOP_BIT));
else
//WRITE_PERI_REG(UART_CONF0(uart_no), CALC_UARTMODE(UartDev.data_bits, UartDev.parity, UartDev.stop_bits));
WRITE_PERI_REG(UART_CONF0(uart_no), CALC_UARTMODE(UartDev.data_bits, NONE_BITS, UartDev.stop_bits)); //Override default settings
//clear rx and tx fifo,not ready
SET_PERI_REG_MASK(UART_CONF0(uart_no), UART_RXFIFO_RST | UART_TXFIFO_RST);
CLEAR_PERI_REG_MASK(UART_CONF0(uart_no), UART_RXFIFO_RST | UART_TXFIFO_RST);
//set rx fifo trigger
// WRITE_PERI_REG(UART_CONF1(uart_no),
// ((UartDev.rcv_buff.TrigLvl & UART_RXFIFO_FULL_THRHD) << UART_RXFIFO_FULL_THRHD_S) |
// ((96 & UART_TXFIFO_EMPTY_THRHD) << UART_TXFIFO_EMPTY_THRHD_S) |
// UART_RX_FLOW_EN);
if (uart_no == UART0)
//set rx fifo trigger to receive 0x01 byte for each call
WRITE_PERI_REG(UART_CONF1(uart_no), ((0x01 & UART_RXFIFO_FULL_THRHD) << UART_RXFIFO_FULL_THRHD_S) | ((0x01 & UART_RX_FLOW_THRHD) << UART_RX_FLOW_THRHD_S) | UART_RX_FLOW_EN | (0x02 & UART_RX_TOUT_THRHD) << UART_RX_TOUT_THRHD_S | UART_RX_TOUT_EN);
//WRITE_PERI_REG(UART_CONF1(uart_no), ((0x01 & UART_RXFIFO_FULL_THRHD) << UART_RXFIFO_FULL_THRHD_S) | ((0x01 & UART_RX_FLOW_THRHD) << UART_RX_FLOW_THRHD_S) | UART_RX_FLOW_EN);
//SET_PERI_REG_MASK(UART_INT_ENA(uart_no), UART_RXFIFO_TOUT_INT_ENA | UART_FRM_ERR_INT_ENA); //This worked
//Clear pending interrupts
WRITE_PERI_REG(UART_INT_CLR(UART0), 0xffff);
//enable rx_interrupt
SET_PERI_REG_MASK(UART_INT_ENA(UART0), UART_RXFIFO_FULL_INT_ENA);
else
WRITE_PERI_REG(UART_CONF1(uart_no), ((UartDev.rcv_buff.TrigLvl & UART_RXFIFO_FULL_THRHD) << UART_RXFIFO_FULL_THRHD_S));
//clear all interrupt
WRITE_PERI_REG(UART_INT_CLR(uart_no), 0xffff);
SET_PERI_REG_MASK(UART_INT_ENA(uart_no), UART_RXFIFO_FULL_INT_ENA);
