Hey AgentSmithers,
Thanks for your interest !
I post below the very same code I use (I made it minimalistic so that it is easier to post). I simply replaced the user_main.c of the NONOS_SDK_2.2.0/examples/IoTDemo project by this one, and I build it with ./gen_misc.sh without any errors, using the procedure describe in Espressif's documentation ("ESP8266 SDKGetting Started Guide"), using the virtual machine and environment provided by Espressif.
I compiled version 1 and 2 of this same application with the options:
SPI Speed : 40MHz
SPI Mode : QIO
I flashed boot_v1.7.bin first at address 0x00000, then the user1.app (originally named user1.4096.new.4.bin, I gave it a shorter nickname
) at 0x01000.
On a local machine (actually a Raspeberry PI) where I put the binaries user1.app and user2.app, I run the very useful and simple Python HTTP server, listenning on port 8070:
And here I'm still wroking on how to get clues...
NB1: A function from the SDK prints "server do not support HEAD method now send GET message". However the SimpleHTTPServer does support HEAD requests: a HEAD request with curl complete successfully with no error, and the logs of the server indicate a successful answer to the ESP... Could the problem be here ?
NB2: You said
The process of SPIWriting the Data is specific to your code
Do you mean I must write "manually" each bytes of the new app to the SPI flash with the SPI functions ? If so, what are the OTA upgrade functions for ? I though they were already supposed to manage it.
NB3: I saw you already spent a large amount of time helping other people on this forum (and sometimes on others websites
), that's very appreciable and kind. Thanks. Really.
Here is my code, if you want to give it a try:
* FOTA test code: once it's connected to Wifi, it starts the FOTA process:
* it connects to a local server to retrieve the new bin to flash and upgrades. That's all.
* Core code based on https://harizanov.com/2015/06/firmware-over-the-air-fota-for-esp8266-soc/
#include "ets_sys.h"
#include "osapi.h"
#include "gpio.h"
#include "os_type.h"
#include "user_interface.h"
#include "mem.h"
#include "upgrade.h"
#include "ip_addr.h"
#include "espconn.h"
uint32 priv_param_start_sec;
char ssid[32] = "MyWifiSSID";
char password[64] = "superpassword";
* @brief Was present in IoT_Demo/user/user_main.c on which this code is based...
uint32 ICACHE_FLASH_ATTR user_rf_cal_sector_set(void)
uint32 rf_cal_sec = 0;
switch (size_map) {
rf_cal_sec = 128 - 5;
priv_param_start_sec = 0x3C;
break;
rf_cal_sec = 256 - 5;
priv_param_start_sec = 0x7C;
break;
rf_cal_sec = 512 - 5;
break;
priv_param_start_sec = 0xFC;
break;
rf_cal_sec = 1024 - 5;
break;
break;
rf_cal_sec = 2048 - 5;
break;
rf_cal_sec = 4096 - 5;
break;
default:
rf_cal_sec = 0;
priv_param_start_sec = 0;
break;
return rf_cal_sec;
* @brief Was present in IoT_Demo/user/user_main.c on wich this code is based...
void ICACHE_FLASH_ATTR user_rf_pre_init(void)
* @brief Callback function called when the upgrade process ended, because of
* timeout or upgrade finished ?
static void OtaFinishedCallback(void *arg)
struct upgrade_server_info *update = arg;
if (update->upgrade_flag == true)
os_printf("[OTA] Success, now rebooting!\n");
system_upgrade_reboot();
else
os_printf("[OTA] Failed!\n");
* @brief Start the OTA upgrade process.
static void HandleUpgrade(const uint8 *server_ip, uint16_t port, const char *path)
const char* file;
uint8_t userBin = system_upgrade_userbin_check();
/* Check wich slot/bin is currently running to determine the new bin to download */
switch(userBin)
case UPGRADE_FW_BIN1: file = "user2.app"; break;
case UPGRADE_FW_BIN2: file = "user1.app"; break;
default:
os_printf("[OTA] Invalid userbin number! \n");
return;
/* Set the info about source server and upgrade process properties */
struct upgrade_server_info* update = (struct upgrade_server_info *)os_zalloc(sizeof(struct upgrade_server_info));
os_memcpy(update->ip, server_ip, 4);
update->pespconn = (struct espconn *)os_zalloc(sizeof(struct espconn));
update->port = port;
update->check_cb = OtaFinishedCallback;
update->check_times = 60000;
update->url = (uint8 *)os_zalloc(512);
os_sprintf((char*)update->url, "GET %s%s HTTP/1.0\r\nHost: "IPSTR":%d\r\nConnection: close\r\n\r\n",
path, file, IP2STR(update->ip), update->port);
os_printf("[OTA] Server "IPSTR":%d. Path: %s%s\n", IP2STR(update->ip), update->port, path, file);
os_printf("Request: %s \n", update->url);
/* Debug */
if (system_upgrade_start(update) == false) os_printf("[OTA] Could not start upgrade\n");
else os_printf("[OTA] Started upgrading...\n");
* @brief Callback function called when the wifi connection is fully operational.
* Launch the OTA upgrade.
void WifiConnectedCb(System_Event_t *event)
/* Run OTA process only when we are fully connected to WiFi */
if(event->event == EVENT_STAMODE_GOT_IP)
os_printf("Connected to Wifi (EVENT_STAMODE_GOT_IP) \n");
os_printf("Now Testing FOTA... \n");
uint8 serverIp[] = {192, 168, 0, 106};
uint16 port = 8070;
char path[] = "pato/espOtaTest/";
HandleUpgrade(serverIp, port, path);
* @brief Called when system is fully initialized. Here we do our custom initialization
* like connecting to wifi and setting timers.
void PostInitCb()
/* Connect to WiFi */
os_printf("I'm version 1 ! \n");
os_printf("Setting up the Esp as a Wifi station... \n");
struct station_config stationConfig;
os_memcpy(stationConfig.ssid, ssid, 32);
os_memcpy(stationConfig.password, password, 64);
wifi_station_set_config(&stationConfig);
wifi_set_event_handler_cb(WifiConnectedCb);
wifi_station_connect();
os_printf("Connecting to WiFi... \n");
* @brief Main entry point of our programm
void user_init()
system_init_done_cb(PostInitCb);
