.irom.text will not fit in region irom0_0_seg
Postby crosofg » Thu Aug 27, 2015 8:41 pm
Hi
I am trying to compile the mesh example provided by espressif using virtual box. However i am getting irom0.text will not fit in region Error.
/opt/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: .output/eagle/debug/image/eagle.app.v6.out section `.irom0.text' will not fit in region `irom0_0_seg'
How do I resolve this ?
Re: .irom.text will not fit in region irom0_0_seg
Postby ESP_Faye » Thu Aug 27, 2015 9:00 pm
What is the size of your Flash ?
And which option did you choose when compiling ?
1. Use a larger Flash.
2. Or you could refer to this topic http://bbs.espressif.com/viewtopic.php?f=61&t=166
Postby crosofg » Thu Aug 27, 2015 11:10 pm
flash size is 512Kb. I am not even able to generate eagle.flash.bin + size of eagle.irom0text.bin. So I cant say about the total size. I must be doing something wrong.
I downloaded the mesh_sample code (containing app_switch,app_light and app_controller) in the app folder of the iot esh sdk.
I then ran Make from the app folder. I am using Virtual box as the development env.
Am I doing anything wrong. If so, please correct me.
marhc_seven
Postby marhc_seven » Fri Nov 06, 2015 7:05 pm
Espressif_Faye wrote:Hi,
Hi i have already enlarge the flash as 8M
but it also showing error!!!
1> c:/sysgcc/esp8266/bin/../lib/gcc/xtensa-lx106-elf/5.2.0/../../../../xtensa-lx106-elf/bin/ld.exe: Debug/HTTPserver.elf section `.irom0.text' will not fit in region `irom0_0_seg'
1> c:/sysgcc/esp8266/bin/../lib/gcc/xtensa-lx106-elf/5.2.0/../../../../xtensa-lx106-elf/bin/ld.exe: region `irom0_0_seg' overflowed by 999 bytes
