After reviewing a couple documents
https://wiki.wemos.cc/products:retired: ... pro_v1.1.0
https://wiki.wemos.cc/_media/products:d ... v1.1.0.pdf
https://github.com/espressif/ESP8266_MP ... ster.h#L39
I am coming to the conclusion that GPIO 7 and 8 are required for UART1 so with this chip sending data over UART1 just isn't possible with this breakout board without doing a hackjob and soldering to the ESP chip pin's itself which is basically impossible for me.
Just wanted to confirm before I throw in the towel.
Thanks!
-Agent
Does the Wemos D1 Mini Pro V1 only support UART0 and not UART1
AgentSmithers
- Contact:
Postby AgentSmithers » Sun Jun 17, 2018 5:25 am
AgentSmithers
- Contact:
Re: Does the Wemos D1 Mini Pro V1 only support UART0 and not UART1
Postby AgentSmithers » Thu Jun 21, 2018 1:47 am
Okay, I don't have my code on me at this moment but what I ended up doing was viewing this link.
In this link I see a few GPIO's are pin'ed out on the breakout board.
Then I went to here
To find that GPIO2 can also function as a UART1_TXD backup.
I used FUNC_SELECT on that pin to assign GPIO2 to be FUNC_UART1_TXD_BK and BAM, I can now use it as UART1 to send Debug Data.
#define PERIPHS_IO_MUX_GPIO2_U (PERIPHS_IO_MUX + 0x38)
#define FUNC_GPIO2 0
#define FUNC_I2SO_WS 1
#define FUNC_U1TXD_BK 2
#define FUNC_UART1_TXD_BK 2
#define FUNC_U0TXD_BK 4
#define FUNC_UART0_TXD_BK 4
The UART1RXPin I do not have on the Wemos has it requires GPIO 11/08/06 and none are available on this board. But for just sending debug data. Perfect.
Now with UART_SWAP swaping the pins for RX/TX to RTS and CTS, I need to find a function to send UART data from those to make the message appear in the "SCREEN" command console. Haven't tested it to see if it would work but fingers crossed
Then I went to here
Users browsing this forum: No registered users and 296 guests
