Fatal exception (29) while switching to SOFTAP mode from Station
paritosharya007
Postby paritosharya007 » Mon Aug 31, 2015 4:27 pm
I have run into an strange problem where my ESP throws Fatal Exception(29) error while switching the mode from station to softap when the user provides wrong password during connection.
My logic is that the ESP would try connecting to an Access Point as station for 5 times. It 5 connection attempts fail (wrong password or any other reason), it would switch over to SoftAP mode. Here's my code:
#define WIFI_STATUS_NAME(status)                                    \
   (STATION_IDLE          == status ?  "STATION_IDLE"            :          \
   (STATION_CONNECTING    == status ?  "STATION_CONNECTING"      :          \
   (STATION_WRONG_PASSWORD == status ?  "STATION_WRONG_PASSWORD"   :          \
   (STATION_NO_AP_FOUND    == status ?  "STATION_NO_AP_FOUND"      :          \
   (STATION_CONNECT_FAIL    == status ?  "STATION_CONNECT_FAIL"      :          \
   (STATION_GOT_IP       == status ?  "STATION_GOT_IP"         : "Unknown"    ))))))
 * FunctionName : wifi_event_handler
 * Description  : handles the event of wifi connection state change
 * Parameters   : System_Event_t
 * Returns      : none
void ICACHE_FLASH_ATTR
wifi_event_handler(System_Event_t *evt) {
   uint8 wifi_status = wifi_station_get_connect_status();
   switch (evt->event) {
      case EVENT_STAMODE_DISCONNECTED: {
         os_printf("-> wifi status : (%d) - ", wifi_status );
         switch (wifi_status) {
            case STATION_CONNECTING: {
               wifi_connect_tries++;
               if ( wifi_connect_tries >= wifi_connect_max_tries ) {
                  os_printf("STATION_CONNECTING..timeout!!!\n");
                  if (wifi_get_opmode()==STATION_MODE) {
                     wifi_set_opmode(SOFTAP_MODE);
                     wifi_connect_tries = 0;
                  else if (wifi_get_opmode()==STATIONAP_MODE) {
               else
                  os_printf("STATION_CONNECTING..%d\n", wifi_connect_tries);
               break;
            default: {
               os_printf("-> %s\n",WIFI_STATUS_NAME(wifi_status));
               break;
         break;
      }   // end EVENT_STAMODE_DISCONNECTED
      case EVENT_STAMODE_GOT_IP: {
         if (wifi_get_opmode() != STATION_MODE) {      // get current mode, if not station
            wifi_set_opmode(STATION_MODE);             // set current mode to station and save to flash
         break;
The error I get is
mode : sta(18:fe:34:9d:2b:b3) + softAP(1a:fe:34:9d:2b:b3)
add if1
pm close 7 0 0/175059131
bcn 100
f 0, beacon timeout
state: 5 -> 0 (1)
-> wifi status : (4) - -> STATION_CONNECT_FAIL
scandone
del if0
mode : softAP(1a:fe:34:9d:2b:b3)
Fatal exception (29):
epc1=0x4025ca65, epc2=0x00000000, epc3=0x400043e6, excvaddr=0x000000b8, depc=0x00000000
ets Jan 8 2013,rst cause:1, boot mode:(1,7)
ets Jan 8 2013,rst cause:4, boot mode:(1,7)
wdt reset
The same code works on my home wifi network, but throws exception on other wifi networks.
Any pointers or clue will be much appreciated.
Re: Fatal exception (29) while switching to SOFTAP mode from Station
Postby ESP_Faye » Thu Sep 10, 2015 10:25 am
Please have a try with this attachment based on esp_iot_sdk_v1.3.0.
SDK1.3.0_ChangeMode_patch01.zip
(166.01 KiB) Downloaded 440 times
