Deep sleep option 4 - RF works/current consumption is normal after wake up
jakasi2
Postby jakasi2 » Tue Sep 01, 2015 2:31 pm
hey,
I connected GPIO16 to RST and wrote a simple program that sends data over WiFi. I am using Arduino IDE so I tried the API calls in the package. I tried:
  • Code: Select all
    ESP.deepSleep(10*1000000, RF_DISABLED);
  • Code: Select all
    ESP.deepSleep(10*1000000, WAKE_RF_DISABLED);
... and it didn't work. Power consumption drops when the device enters deep sleep mode but goes back to normal when it returns from it. RF also works and I can send data over WiFi.
Then I tried ESP8266 SDK calls. I imported ..
extern "C" {
  #include "user_interface.h"
.. and called ..
system_deep_sleep_set_option(4);
system_deep_sleep(10*1000000);
.. and the behaviour is the same.
How can I wake up the chip with RF turned off (lower power consumption)?
ESP_Alfred
Re: Deep sleep option 4 - RF works/current consumption is normal after wake up
Postby ESP_Alfred » Thu Sep 10, 2015 8:34 pm
jakasi2 wrote:hey,
  • Code: Select all
  • Code: Select all
extern "C" {
.. and called ..
hi,
When "deep sleep option == 4", RF disabled after deep-sleep wake up, the device is not able to transmit or receive data after wake up.
Could you give me a test demo using 8266 SDK ?
