have we detailed docu in SDIO 1.1 / SDIO 2.0 ?
if GPIO15 goes high, there is an other bootloader waiting for what?
why in this mode - if GPIO 0 goes LOW and reboot, no bootloader for SPI Flash is come,
allways a "new face of a NEW Bootloader" ?
can we boot raw data adressed like SPI flash in this mode from SD Card ?
must it be raw data or can it be FAT / FAT16 / FAT32 formated ?
where must write the boot cfg at which adress for this ?
how is the format of this cfg ?
which SD cards are supported generally? SD / SDHC / SDHX ?
1,8 MByte/s in SDIO2 Mode will be verry welcome to boot officially from SD Card
have we document for supply SDIO Components example LAN Module, High Sensoric Video , other SDIO Module?
thank you for your efforts!
best wishes
rudi
refer:
ESP8266ex Specifications
802.11 b/g/n
WiFi Direct (P2P), soft-AP
Integrated TCP/IP protocol stack
Integrated TR switch, balun, LNA, power amplifier and matching network
Integrated PLLs, regulators, DCXO and power management units
+19.5dBm output power in 802.11b mode
Power down leakage current of <10uA
Integrated low power 32-bit CPU could be used as application processor
>>>>> SDIO 1.1/2.0, <<<<<<<< SPI, UART
STBC, 1×1 MIMO, 2×1 MIMO
A-MPDU & A-MSDU aggregation & 0.4ms guard interval
Wake up and transmit packets in < 2ms
Standby power consumption of < 1.0mW (DTIM3)
