ESP8266 sniffer sample
Postby azarubkin » Wed Sep 02, 2015 6:22 pm
I'm trying to compile a simple packet sniffer. I took it here: https://github.com/davruet/esp8266-sniffer. I've compiled it with SDK 1.3.0 succesfully (using esp-open-sdk). However, after flashing it just hops from one channel to the next one, and does not display any captured packets.
I have Wi-Fi router installed in the same room, so there should be some output. I switched the router to b/g mode without encryption, but got no result.
Do you have any ideas why the code does not work? Do you have a working sample code for sniffer?
Any help would be appreciated.
koltegirish97
Re: ESP8266 sniffer sample
Postby koltegirish97 » Fri Sep 04, 2015 7:24 pm
azarubkin wrote:Okay, after contacting Espressif they emailed me the sources for sniffer example which works with SDK 1.3.0.
Can you mail me on trendchaster@gmail.com Me to working on it.Thanks in advance
Postby uts » Thu Sep 10, 2015 4:08 pm
Could you also send me the file. I am working on a similar project. busybee.utsav@gmail.com
Postby pulkin » Sat Sep 26, 2015 3:01 am
I have put an example for esp8266 sniffer+injection on GitHub:
https://github.com/pulkin/esp8266-injection-example
Requires SDK 1.4.0. Enjoy!
Postby jead » Wed Oct 28, 2015 3:40 am
Hello, pulkin.
Great work! Thank you for share with us.
I tested your code and sniffer capability worked very well. But in injection tests, I had no success unfortunately. When I check the value of parameter returned by the "wifi_send_pkt_freedom" function, it is always negative (-1), so, failed to send. I'm using SDK 1.4.0.
Could you help me?
Thank you so much.
Could you help me?
Thank you so much.
