[Solved] IGMP missing in lwip RTOS sdk version
EliteScientist
Re: IGMP missing in lwip RTOS sdk version
Postby EliteScientist » Mon Nov 30, 2015 8:39 am
Postby ESP_Faye » Mon Nov 30, 2015 2:15 pm
Sorry for the inconvenience.
Please have a try with the lib as the attachment.
- Attachments
- liblwip.zip
- (132.05 KiB) Downloaded 699 times
EliteScientist
Postby EliteScientist » Mon Nov 30, 2015 3:42 pm
Postby ESP_Faye » Tue Dec 01, 2015 10:38 am
So sorry that there are more libs which are needed.
Please have a try with this new attachment.
- Attachments
- lib_support_igmp.zip
- (295.99 KiB) Downloaded 699 times
EliteScientist
Postby EliteScientist » Tue Dec 01, 2015 12:05 pm
EliteScientist
Re: [Solved] IGMP missing in lwip RTOS sdk version
Postby EliteScientist » Wed Dec 02, 2015 1:37 pm
scandone
state: 0 -> 2 (b0)
state: \0xa6\0xc9\0x02\0x9a\0x02B\0x82Jj
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
scandone
state: 0 -> 2 (b0)
state:\0x802 -> 3 (0)
wdt reset
Occasionally it will connect and run but will crash shortly after. When it connects I get:
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 3
pm open phy_2,type:2 0 0
cnt
connected with Elite Scientist, channel 4
dhcp client start...
Here are what the crashes look like:
Fatal exception (0):
epc1=0x40215090
epc2=0x40100070
epc3=0x40101798
epcvaddr=0x0000000c
depc=0x40100052
rtn_add=0x40101712
low_level_init
add if0
f r-40, scandone
state: 0 -> 2 (b0)
state:\0x002 -> 3 (0)
Fatal exception (28):
epc1=0x4000deed
epc2=0x40100070
epc3=0x40103861
epcvaddr=0x0000000c
depc=0x40100059
rtn_add=0x400018dc
\0xea
After So many crashes I will see this and it will stop running completely:
low_level_init
add if0
f r-1, scandone
state: 0 -> 2 (b0)
sta
Postby jhinkle » Sun Apr 24, 2016 7:05 am
I found that IGMP was not working so I search this site for potential answers.
I downloaded the 4 libraries noteed earlier in this thread --- and igmp started to work. --- OR I Thought.
My simple test program has 2 tasks. Task1 creates a UDP socket and issues a recv request which blocks until a UDP message on the specified port arrives.
Task2 waits for a counting semaphore which is incremented upon Task1 receiving a message. Task2 waits for a counting semaphore and has a timeout of 30 seconds. Upon returning from a TimeOut -- Task2 posts a os_printf message stating that no message was received from Task1.
My test does NOT send any UDP messages so expected behavior is to see a os_printf post every 30 seconds --- forever.
It DOES post forever with the current RTOS SDK but igmp is not working.
Re complied and linked the 4 libs stated earlier in this post ... test if a multicast message is received ,--- all work OK.
Restart the ESP --- don't send any messages and expect to see os_printf posts forever -- WRONG.
The os_printf posts STOP showing up about 10 minutes after the ESP is started.
As another note --- I'm using the GDBstub and with the 4 libs noted ... I have received a SIGEMT: Emulation Trap and a SIGILL: illegal instruction.
It appears that the 4 libs posted earlier to resolve the missing igmp issue has created bugs of their own.
Is there any way to get a good RTOS SDK with igmp working?
Thanks -- and if I can supply anything to help debug the issue I have presented her -- please say so.
Thanks in advance for looking into this.
- raspberrypidmx
- Contact:
Postby raspberrypidmx » Thu Oct 06, 2016 11:16 pm
void ICACHE_FLASH_ATTR handle_udp_join_group(void) {
printf("handle_udp_join_group\n");
struct ip_addr ipgroup;
struct ip_info local_ip;
const WIFI_MODE mode = wifi_get_opmode();
if (mode & STATION_MODE) {
wifi_get_ip_info(STATION_IF, &local_ip);
} else {
wifi_get_ip_info(SOFTAP_IF, &local_ip);
ipaddr_aton("239.255.0.1", &ipgroup);
const uint8_t iret = igmp_joingroup(&local_ip.ip,(struct ip_addr *)(&ipgroup));
if (iret != ERR_OK) {
printf("Could not join\n");
}The full code can be found here -> https://github.com/vanvught/rpidmx512/tree/master/esp8266_rtos_sdk_rpi
