SDK 0.9.5 b1 - enable PROMISCUOUS causes reset
reaper7
Postby reaper7 » Fri Dec 26, 2014 4:27 am
when I'm trying execute function:
wifi_promiscuous_enable(1);
esp resets:
 ets Jan  8 2013,rst cause:4, boot mode:(3,6)
wdt reset
load 0x40100000, len 612, room 16
tail 4
chksum 0x12
load 0x3ffe8000, len 788, room 4
tail 0
chksum 0x50
load 0x3ffe8314, len 264, room 8
tail 0
chksum 0x4a
csum 0x4a
2nd boot version : 1.1
  SPI Speed      : 40MHz
  SPI Mode       : QIO
  SPI Flash Size : 4Mbit
jump to run user1
Re: SDK 0.9.5 b1 - enable PROMISCUOUS causes reset
Postby ESP_Faye » Fri Dec 26, 2014 3:49 pm
Hi,can you offer more information?
I tried on sdk_0.9.5 b1 . it's fine..
mode : sta(18:fe:34:97:d5:7b)
add if0
scandone
ssid A, channel 1, authmode 0, rssi -41
ssid JSInfo, channel 1, authmode 4, rssi -59
ssid ESP_97EF81, channel 1, authmode 0, rssi -50
ssid ESP_781700, channel 1, authmode 0, rssi -45
ssid ESP_97F01D, channel 1, authmode 0, rssi -51
ssid ESP_775200, channel 1, authmode 0, rssi -46
ssid ChinaNet-HG526V2_T, channel 1, authmode 0, rssi -33
ssid iTV-Kinv, channel 1, authmode 4, rssi -40
ssid huayanedu, channel 1, authmode 4, rssi -67
ssid YITOU, channel 1, authmode 4, rssi -69
ssid Ledage|WiFi, channel 1, authmode 4, rssi -60
ssid UNCONNECTED, channel 2, authmode 4, rssi -49
reaper7
Postby reaper7 » Sat Dec 27, 2014 6:47 pm
please look at example (all tests with blank.bin flashed)
prom_test.zip
(8.78 KiB) Downloaded 728 times
this code works OK on 0.9.3 and 0.9.4
but resets on 0.9.5 b1
whats I'm doing wrong?
Postby ESP_Faye » Tue Dec 30, 2014 12:41 pm
Sorry for this issue, we have replicated it , we are working on it now.. Thanks for the report .
