I just got some ESP12Es (node mcu devkit v1) from China. And this board have following error when I build & flash user2. SDK is version 1.3. Please share your idea about this. Thank so much.
I have tried on may flash size options (0->6) and got the same result.
UART log for each reset:
tail 4
chksum 0x89
tail 4
chksum 0xe8
tail 8
chksum 0xc0
csum 0xc0
2nd boot version : 1.4(b1)
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size & Map: 4Mbit(256KB+256KB)
jump to run user1 @ 1000
error magic!
first boot failed, reboot to try backup bin
wdt reset
tail 4
chksum 0x89
tail 4
chksum 0xe8
tail 8
chksum 0xc0
csum 0xc0
SPI Speed : 40MHz
SPI Mode : QIO
error magic!
backup boot failed.
user code doneMy code for user_main.c
#include "ets_sys.h"
#include "osapi.h"
#include "user_interface.h"
void user_rf_pre_init(void)
void user_init(void)
}The build log:
$ ./gen_misc.sh
gen_misc.sh version 20150511
enter(0/1/2, default 2):
1
boot mode: new
enter (0/1/2, default 0):
2
generate bin: user2.bin
enter (0/1/2/3, default 2):
spi speed: 40 MHz
enter (0/1/2/3, default 0):
spi mode: QIO
0= 512KB( 256KB+ 256KB)
2=1024KB( 512KB+ 512KB)
3=2048KB( 512KB+ 512KB)
4=4096KB( 512KB+ 512KB)
5=2048KB(1024KB+1024KB)
6=4096KB(1024KB+1024KB)
spi size: 512KB
spi ota map: 256KB + 256KB
start...
make COMPILE=gcc BOOT=new APP=2 SPI_SPEED=40 SPI_MODE=QIO SPI_SIZE_MAP=0
make[1]: Entering directory `d:/esp8266/esp_iot_sdk_v1.3.0/smart_config/user'
DEPEND: xtensa-lx106-elf-gcc -M -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcal
ls -mtext-section-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I .
./include -I ../../include -I ../../include/eagle user_main.c
make[1]: Leaving directory `d:/esp8266/esp_iot_sdk_v1.3.0/smart_config/user'
xtensa-lx106-elf-gcc -Os -g -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-s
ection-literals -ffunction-sections -fdata-sections -DICACHE_FLASH -I include -I ./ -I ../../include/ets -I ../includ
e -I ../../include -I ../../include/eagle -o .output/eagle/debug/obj/user_main.o -c user_main.c
xtensa-lx106-elf-ar ru .output/eagle/debug/lib/libuser.a .output/eagle/debug/obj/user_main.o
xtensa-lx106-elf-gcc -L../lib -nostdlib -T../ld/eagle.app.v6.new.512.app2.ld -Wl,--no-check-sections -u call_user_start
-Wl,-static -Wl,--start-group -lc -lgcc -lhal -lphy -lpp -lnet80211 -llwip -lwpa -lmain -ljson -lssl -lupgrade -lsmartc
onfig user/.output/eagle/debug/lib/libuser.a -Wl,--end-group -o .output/eagle/debug/image/eagle.app.v6.out
-1452428288
1452428287
Support boot_v1.2 and +
mv: replace `../bin/upgrade/user2.512.new.0.bin', overriding mode 0666? y
Generate user2.512.new.0.bin successully in folder bin/upgrade.
boot.bin------------>0x00000
user2.512.new.0.bin--->0x41000
!!!I have use ESP download tool v1.2 with following options:
- 4Mbit flash size
- boot_v1.4(b1).bin --- 0x0
- user2.512.new.0.bin --- 0x41000
- blank.bin --- 0x7E000
