从user2.bin升级到user1.bin失败
luyifan
Postby luyifan » Mon Sep 07, 2015 12:42 pm
问题描述:自己在本地搭了一个服务器,从user1.bin升级到user2.bin没问题,不过升级重启后从user2.bin升级到user1.bin无法成功,user2.bin没法下载user1.bin,然后重启后就当机了。我看大家以前的帖子也提到这个问题了,不过说是make clean后就可以解决问题,我每次编译前都会make clean一下,step1选1,step5选2,按照教程分别烧录了
0xFC000 esp_init_data_default.bin
0xFE000 blank.bin
0x00000 boot_v1.2.bin
0x01000 user1.1024.new.2.bin
把user1.bin和user2.bin都上传到了自己的服务器上,大家谁还遇到过一样的问题,求指教!
我选择的是1024KB,还需要在代码哪里设置一下吗?
另外,我看有人提到boot区分正常模式和增强模式,请问如何设置boot进入不同的模式?
system_upgrade_start-----------------------------------------------------user1.bin开始升级
upgrade_connect
Updateing...
upgrade_connect_cb
GET /?version=v0.19&filename=user2.bin&action=download_rom HTTP/1.1
Host: 192.168.150.10
Connection: keep-alive
Cache-Control: no-cache
User-Agent: Mozilla/5.0 (Windows NT 5.1) AppleWebKit/537.36 (KHTML, like Gec ko) Chrome/30.0.1599.101 Safari/537.36
Accept: */*
Accept-Language: zh-CN,eb-US;q=0.8
sumlength = 208308
upgrade file download start.
totallen = 2646
totallen = 208308
flash_crc = 598032996
img_crc = 598032996
upgrade_check
user_esp_platform_upgrade_successful------------------------------------下载完成升级成功
reboot to use2
state: 5 -> 0 (0)
rm 0
del if0
bcn 0
del if1
usl
sul 0 0
tail 0
chksum 0x8d
tail 12
chksum 0xcf
ho 0 tail 12 room 4
tail 4
chksum 0xcf
csum 0xcf
2nd boot version : 1.2
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size : 4Mbit
jump to run user2
\0x10\0xf2\0xfb\0x03\0xff\0xd4\0xff\0xff\0xff\0x80
mode : sta(18:fe:34:f3:18:8c) + softAP(1a:fe:34:f3:18:8c)------------------------------------开始运行user2.bin
add if0
add if1
bcn 100
system_upgrade_start......................................................user2.bin开始升级
upgrade_connect
Updateing...
upgrade_connect_cb
GET /?version=v0.19&filename=user1.bin&action=download_rom HTTP/1.1
Accept: */*
sumlength = 208308 ------------------------------------------------卡住了,没有下载
wdt reset
tail 0
chksum 0x8d
tail 12
chksum 0xcf
ho 0 tail 12 room 4
tail 4
chksum 0xcf
csum 0xcf
SPI Speed : 40MHz
SPI Mode : QIO
jump to run user2-------------------------------------------------------重启后运行user2.bin,之后就挂掉了
Fatal exception (0):
epc1=0x40281768, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
Re: 从user2.bin升级到user1.bin失败
Postby ESP_Faye » Thu Sep 10, 2015 2:02 pm
SPI Speed : 40MHz
SPI Mode : QIO
jump to run user2
您好,
1. 建议您使用最新版本的 boot,目前最新的版本是 boot_v1.4(b1).bin,新版本的 boot 在 user2 无法运行时,会跳回 user1 运行。
2. 从您提供的 log 看来,您的 flash size 是 4Mbit=512KB,但您编译时 Step 5 选择的却是1024KB。如果您确认您的 Flash size 实际为 1024KB,请您使用 Espressif 官方的 flash download tool,烧录时选择 Flash size 8Mbit.
如果您的问题仍未解决,麻烦提供烧录时的 flash download tool 截图,和运行时异常的 log,以供分析。
感谢您对 ESP8266 的关注!
