ESP8266 RTOS版SDK是否支持SSL/TLS?
zsf518
Postby zsf518 » Wed Sep 09, 2015 8:22 am
hi all,
请问ESP8266 RTOS版本的SDK的SSL/TLS是怎么应用的?
有没有对应的文档或者demo可以参考?
谢谢啦。
zsf518
Re: ESP8266 RTOS版SDK是否支持SSL/TLS?
Postby zsf518 » Thu Sep 10, 2015 10:11 am
使用论坛里面一个例子,这个例子本身也不正确。
unsigned char *default_certificate;
unsigned int default_certificate_len = 0;
unsigned char *default_private_key;
unsigned int default_private_key_len = 0;
void ICACHE_FLASH_ATTR
ssl_task( void *param )
int res;
//uint32_t options = SSL_SERVER_VERIFY_LATER|SSL_DISPLAY_CERTS;
uint32_t options = SSL_NO_DEFAULT_KEY|SSL_SERVER_VERIFY_LATER|SSL_DISPLAY_CERTS;
int sslclient_fd;
struct sockaddr_in sslserver_addr;
int reconnect = 5;
uint32_t sin_addr;
SSL_CTX *ssl_ctx;
SSL *ssl = NULL;
uint8_t session_id[SSL_SESSION_ID_SIZE];
struct ip_info ipconfig;
while (ipconfig.ip.addr == 0)
vTaskDelay(500 / portTICK_RATE_MS);
printf("ipconfig.ip.addr = %x\n",ipconfig.ip.addr);
// This is where the interesting stuff happens. Up until now we've
// just been setting up sockets etc. Now we do the SSL handshake.
sslclient_fd = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);
memset(&sslserver_addr, 0, sizeof(sslserver_addr));
sslserver_addr.sin_family = AF_INET;
sslserver_addr.sin_addr.s_addr = inet_addr("59.37.116.101"); //dnspod
sslserver_addr.sin_port = htons(443);
if (connect(sslclient_fd, (struct sockaddr *)&sslserver_addr,sizeof(sslserver_addr)) < 0)
printf("connect failed \n");
return;
printf("init ssl ctx\n");
if ((ssl_ctx = ssl_ctx_new(options, SSL_DEFAULT_CLNT_SESS)) == NULL)
printf("Error: ssl_ctx_newt is invalid\n");
return;
printf("ready to ssl handshake \n");
tryagain:
// Try session resumption?
if (reconnect)
while (reconnect--)
ssl = ssl_client_new(ssl_ctx, sslclient_fd, session_id, sizeof(session_id));
printf("%x, %d, %d, %x, %d, %x, %d, %d \n",ssl->flag,
ssl->need_bytes,
ssl->got_bytes,
ssl->record_type,
ssl->version,
ssl->bm_read_index,
ssl->next_state,
ssl->hs_status);
if ((res = ssl_handshake_status(ssl)) != SSL_OK)
printf("ssl handshake failed res = %d\n", res);
ssl_free(ssl);
//display_session_id(ssl);
memcpy(session_id, ssl_get_session_id(ssl), SSL_SESSION_ID_SIZE);
if (reconnect)
ssl_free(ssl);
close(sslclient_fd);
connect(sslclient_fd, (struct sockaddr *)&sslserver_addr,sizeof(sslserver_addr));
else
ssl = ssl_client_new(ssl_ctx, sslclient_fd, NULL, 0);
if(ssl == NULL)
printf("ssl_client_new failed \n");
goto tryagain;
// check the return status
ssl_free(ssl);
//goto EXIT;
goto tryagain;
while(1)
uint8_t *read_buf;
res = ssl_read(ssl, &read_buf);
if (res > 0)
printf("read: %s \n", read_buf);
vTaskDelay(1000 / portTICK_RATE_MS);
ssl_ctx_free(ssl_ctx);
打印错误信息:
260011, 4051, 0, 16, 50, 0, 11, -261
ssl handshake failed res = -261
260011, 52992, 0, 0, 50, 0, 2, -261
请帮忙看看 RTOS SDK下怎么使用SSL/TLS。
谢谢啦
zsf518
Postby zsf518 » Thu Sep 10, 2015 1:49 pm
错误打印信息:260011, 4051, 0, 16, 50, 0, 11, -261
最后的打印错误代码为 -261,SSL代码里面定义:
#define SSL_ERROR_INVALID_PROT_MSG -261
返回这个错误代码的地方(ssl_tls1.c):
/* do we violate the spec with the message size? */
if (ssl->need_bytes > RT_MAX_PLAIN_LENGTH+RT_EXTRA-BM_RECORD_OFFSET)
ret = SSL_ERROR_INVALID_PROT_MSG;
goto error;
打印信息第二个就是ssl->need_bytes,这里是4051,大于RT_MAX_PLAIN_LENGTH+RT_EXTRA-BM_RECORD_OFFSET,所以出错。
具体原因是什么就不知道了。
请帮忙分析一下。
谢谢。
zsf518
Postby zsf518 » Thu Sep 10, 2015 3:22 pm
如果设置 uint32_t options = 0;
ssl_ctx_new()这里立即崩溃:
init ssl ctx
Fatal exception (28):
epc1=0x4023704a
epc2=0x00000000
epc3=0x4020578b
epcvaddr=0x00000000
depc=0x00000000
rtn_add=0x40234abb
2nd boot version : 1.4(b1)
SPI Speed : 20MHz
SPI Mode : QIO
jump to run user1 @ 1000
tail 4
chksum 0x89
tail 4
chksum 0xe8
tail 8
chksum 0xc0
csum 0xc0
hark
Postby hark » Wed Apr 13, 2016 5:50 pm
Hi 请问你的问题解决了吗?
