通过ESP8266 I2C驱动MPU6050当将SCL(GPIO 14)如例程中配置为开漏模式时程序出现无法得到ACK信号
gpio_output_set(BIT14, 0, BIT14, 0)[img]ets Jan 8 2013,rst cause:2, boot mode:(3,7)
load 0x40100000, len 32468, room 16
tail 4
chksum 0x75
load 0x3ffe8000, len 2888, room 4
tail 4
chksum 0x90
load 0x3ffe8b50, len 6980, room 4
tail 0
chksum 0xd8
csum 0xd8
I2C No ACK......
I2C No ACK......
I2C No ACK......
I2C从机地址设置错误,请将AD0端口接地 ID is 255
1.DMP Init ......2
I2C No ACK......
I2C No ACK......
I2C No ACK......
I2C No ACK......
I2C No ACK......
I2C No ACK......
[/img]
[img]
tail 4
chksum 0x75
tail 4
chksum 0x90
tail 0
chksum 0xd8
csum 0xd8
I2C ACK Ok......
I2C ACK Ok......
I2C ACK Ok......
MPU ID is 104
I2C ACK Ok......
I2C ACK Ok......
I2C ACK Ok......
I2C ACK Ok......
I2C ACK Ok......
I2C ACK Ok......
I2C ACK Ok......
I2C ACK Ok......
[/img]
[img]
tail 4
chksum 0x51
tail 4
chksum 0x7f
tail 0
chksum 0x37
csum 0x37
MPU ID is 104
1.DMP Init ......0
2.DMP设置传感器成功
3.设置FIFO成功
4.DMP设置采样率成功
5.DMP加载运动驱动固件成功
6.DMP完成设置初始方向设定偏差
7.DMP使能成功
8.DMP设置FIFO速率成功
result is 3
9.Dm韄辑p玴l 瑦*\p玴l 犟+P?禇h?〥r
SDK ver: 1.3.0 compiled @ Aug 7 2015 19:17:30
phy ver: 41201, pp ver: 9.0
SDK version:1.3.0
IOT VERSION = v1.0.5t23701(a)
reset reason: 6
MPU ID is 104
1.DMP Init ......0
2.DMP设置传感器成功
3.设置FIFO成功
4.DMP设置采样率成功
5.DMP加载运动驱动固件成功
6.DMP完成设置初始方向设定偏差
[/img]
以下是程序代码
#include "user_interface.h"
#if debug==0
#include "driver/anbt_i2c.h"
#else
#include "driver/i2c_master.h"
#endif
//#include "driver/anbt_i2c.h"
//#include "driver/i2c_master.h"
#define I2C_MASTER_SDA_MUX PERIPHS_IO_MUX_GPIO2_U
#define I2C_MASTER_SCL_MUX PERIPHS_IO_MUX_MTMS_U
#define I2C_MASTER_SDA_GPIO 2
#define I2C_MASTER_SCL_GPIO 14
#define I2C_MASTER_SDA_FUNC FUNC_GPIO2
#define I2C_MASTER_SCL_FUNC FUNC_GPIO14
#define I2C_MASTER_SDA_HIGH_SCL_HIGH() \
gpio_output_set(1<<I2C_MASTER_SDA_GPIO | 1<<I2C_MASTER_SCL_GPIO, 0, 1<<I2C_MASTER_SDA_GPIO | 1<<I2C_MASTER_SCL_GPIO, 0)
#define ANBT_I2C_NOP os_delay_us(10)
#define I2C_Direction_Transmitter ((u8)0x00)
#define I2C_Direction_Receiver ((u8)0x01)
//#define debug
#if debug==0
#define ANBT_I2C_SCL_0 gpio_output_set(0, BIT14, BIT14, 0) //SCL=0;
#define ANBT_I2C_SCL_1 gpio_output_set(0,0,0,BIT14) //SCL=1;BIT14, 0, BIT14, 0)
#define ANBT_I2C_SDA_0 gpio_output_set(0,BIT2, BIT2, 0) //SDA=0;
#define ANBT_I2C_SDA_1 gpio_output_set(BIT2, 0, BIT2, 0) //SDA=1;
#define ANBT_I2C_SDA_STATE GPIO_INPUT_GET(GPIO_ID_PIN(I2C_MASTER_SDA_GPIO))
static void ICACHE_FLASH_ATTR
gpio_init_i2c(gpio)
uint32_t pin = GPIO_PIN_ADDR(GPIO_ID_PIN(gpio));
/* set to open drain */
GPIO_REG_WRITE(pin, GPIO_REG_READ(pin) | GPIO_PIN_PAD_DRIVER_SET(GPIO_PAD_DRIVER_ENABLE));
gpio_output_set(1 << gpio, 0, 1 << gpio, 0);
ANBT_I2C_Configuration(void)
ETS_GPIO_INTR_DISABLE() ;
// ETS_INTR_LOCK();
PIN_FUNC_SELECT(I2C_MASTER_SDA_MUX, I2C_MASTER_SDA_FUNC);
PIN_FUNC_SELECT(I2C_MASTER_SCL_MUX, I2C_MASTER_SCL_FUNC);
//GPIO_REG_WRITE(GPIO_PIN_ADDR(GPIO_ID_PIN(I2C_MASTER_SDA_GPIO)), GPIO_REG_READ(GPIO_PIN_ADDR(GPIO_ID_PIN(I2C_MASTER_SDA_GPIO))) | GPIO_PIN_PAD_DRIVER_SET(GPIO_PAD_DRIVER_ENABLE)); //open drain;
//GPIO_REG_WRITE(GPIO_ENABLE_ADDRESS, GPIO_REG_READ(GPIO_ENABLE_ADDRESS) | (1 << I2C_MASTER_SDA_GPIO));
gpio_init_i2c(I2C_MASTER_SDA_GPIO);
//GPIO_REG_WRITE(GPIO_PIN_ADDR(GPIO_ID_PIN(I2C_MASTER_SCL_GPIO)), GPIO_REG_READ(GPIO_PIN_ADDR(GPIO_ID_PIN(I2C_MASTER_SCL_GPIO))) | GPIO_PIN_PAD_DRIVER_SET(GPIO_PAD_DRIVER_ENABLE)); //open drain;
//GPIO_REG_WRITE(GPIO_ENABLE_ADDRESS, GPIO_REG_READ(GPIO_ENABLE_ADDRESS) | (1 << I2C_MASTER_SCL_GPIO));
gpio_init_i2c(I2C_MASTER_SCL_GPIO);
I2C_MASTER_SDA_HIGH_SCL_HIGH();
ETS_GPIO_INTR_ENABLE() ;
u8 ICACHE_FLASH_ATTR
ANBT_I2C_START(void)
ANBT_I2C_SDA_1;
ANBT_I2C_NOP;
ANBT_I2C_SCL_1;
ANBT_I2C_NOP;
if(!ANBT_I2C_SDA_STATE)
os_printf("I2C Bus Is Busy\n");
return ANBT_I2C_BUS_BUSY;
ANBT_I2C_SDA_0;
ANBT_I2C_NOP;
ANBT_I2C_SCL_0;
ANBT_I2C_NOP;
if(ANBT_I2C_SDA_STATE)
os_printf("I2C Bus Is Err\n");
return ANBT_I2C_BUS_ERROR;
return ANBT_I2C_READY;
ANBT_I2C_STOP(void)
ANBT_I2C_SDA_0;
ANBT_I2C_NOP;
ANBT_I2C_SCL_1;
ANBT_I2C_NOP;
ANBT_I2C_SDA_1;
ANBT_I2C_NOP;
ANBT_I2C_SendACK(void)
ANBT_I2C_SDA_0;
ANBT_I2C_NOP;
ANBT_I2C_SCL_1;
ANBT_I2C_NOP;
ANBT_I2C_SCL_0;
ANBT_I2C_NOP;
ANBT_I2C_SendNACK(void)
ANBT_I2C_SDA_1;
ANBT_I2C_NOP;
ANBT_I2C_SCL_1;
ANBT_I2C_NOP;
ANBT_I2C_SCL_0;
ANBT_I2C_NOP;
ANBT_I2C_SendByte(u8 anbt_i2c_data)
u8 i;
ANBT_I2C_SCL_0;
for(i=0;i<8;i++)
if(anbt_i2c_data&0x80)
ANBT_I2C_SDA_1;
else
ANBT_I2C_SDA_0;
anbt_i2c_data<<=1;
ANBT_I2C_NOP;
ANBT_I2C_SCL_1;
ANBT_I2C_NOP;
ANBT_I2C_SCL_0;
ANBT_I2C_NOP;
ANBT_I2C_SDA_1;
ANBT_I2C_NOP;
ANBT_I2C_SCL_1;
ANBT_I2C_NOP;
ANBT_I2C_SCL_0;
os_printf("I2C No ACK......\n");
return ANBT_I2C_NACK;
else
ANBT_I2C_SCL_0;
os_printf("I2C ACK Ok......\n");
return ANBT_I2C_ACK;
ANBT_I2C_ReceiveByte(void)
u8 i,anbt_i2c_data;
ANBT_I2C_SDA_1;
ANBT_I2C_SCL_0;
anbt_i2c_data=0;
for(i=0;i<8;i++)
ANBT_I2C_SCL_1;
ANBT_I2C_NOP;
anbt_i2c_data<<=1;
if(ANBT_I2C_SDA_STATE) anbt_i2c_data|=0x01;
ANBT_I2C_SCL_0;
ANBT_I2C_NOP;
ANBT_I2C_SendNACK();
return anbt_i2c_data;
ANBT_I2C_ReceiveByte_WithACK(void)
u8 i,anbt_i2c_data;
ANBT_I2C_SDA_1;
ANBT_I2C_SCL_0;
anbt_i2c_data=0;
for(i=0;i<8;i++)
ANBT_I2C_SCL_1;
ANBT_I2C_NOP;
anbt_i2c_data<<=1;
ANBT_I2C_SCL_0;
ANBT_I2C_NOP;
ANBT_I2C_SendACK();
#else
#define ANBT_I2C_SDA_1 gpio_output_set(1<<I2C_MASTER_SDA_GPIO, 0, 1<<I2C_MASTER_SDA_GPIO, 0)
#define ANBT_I2C_SDA_0 gpio_output_set(0, 1<<I2C_MASTER_SDA_GPIO, 1<<I2C_MASTER_SDA_GPIO, 0)
#define ANBT_I2C_SCL_0 gpio_output_set(0, 1<<I2C_MASTER_SCL_GPIO, 1<<I2C_MASTER_SCL_GPIO, 0)
#define ANBT_I2C_SCL_1 gpio_output_set(1<<I2C_MASTER_SCL_GPIO, 0, 1<<I2C_MASTER_SCL_GPIO, 0)
//#define ANBT_I2C_SCL_0 gpio_output_set(0, BIT14, BIT14, 0); //SCL=0;
//#define ANBT_I2C_SCL_1 gpio_output_set(BIT14, 0, BIT14, 0); //SCL=1;
//#define ANBT_I2C_SDA_0 gpio_output_set(0,BIT2, BIT2, 0); //SDA=0;
//#define ANBT_I2C_SDA_1 gpio_output_set(BIT2, 0, BIT2, 0); //SDA=1;
#define ANBT_I2C_STOP i2c_master_stop
#define ANBT_I2C_START i2c_master_start
#define ANBT_I2C_SendACK i2c_master_send_ack
#define ANBT_I2C_SendNACK i2c_master_send_nack
#define ANBT_I2C_ReceiveByte_WithACK i2c_master_checkAck
#define ANBT_I2C_SendByte i2c_master_writeByte
#define ANBT_I2C_ReceiveByte i2c_master_readByte
#endif
ANBT_I2C_Receive6Bytes(u8 *anbt_i2c_data_buffer)
u8 i,j;
u8 anbt_i2c_data;
for(j=0;j<5;j++)
ANBT_I2C_SDA_1;
ANBT_I2C_SCL_0;
anbt_i2c_data=0;
for(i=0;i<8;i++)
ANBT_I2C_SCL_1;
ANBT_I2C_NOP;
anbt_i2c_data<<=1;
ANBT_I2C_SCL_0;
ANBT_I2C_NOP;
anbt_i2c_data_buffer[j]=anbt_i2c_data;
ANBT_I2C_SendACK();
ANBT_I2C_SDA_1;
ANBT_I2C_SCL_0;
anbt_i2c_data=0;
for(i=0;i<8;i++)
ANBT_I2C_SCL_1;
ANBT_I2C_NOP;
anbt_i2c_data<<=1;
ANBT_I2C_SCL_0;
ANBT_I2C_NOP;
anbt_i2c_data_buffer[5]=anbt_i2c_data;
ANBT_I2C_Receive12Bytes(u8 *anbt_i2c_data_buffer)
u8 i,j;
u8 anbt_i2c_data;
for(j=0;j<11;j++)
ANBT_I2C_SDA_1;
ANBT_I2C_SCL_0;
anbt_i2c_data=0;
for(i=0;i<8;i++)
ANBT_I2C_SCL_1;
ANBT_I2C_NOP;
anbt_i2c_data<<=1;
ANBT_I2C_SCL_0;
ANBT_I2C_NOP;
ANBT_I2C_SendACK();
ANBT_I2C_SDA_1;
ANBT_I2C_SCL_0;
anbt_i2c_data=0;
for(i=0;i<8;i++)
ANBT_I2C_SCL_1;
ANBT_I2C_NOP;
anbt_i2c_data<<=1;
ANBT_I2C_SCL_0;
ANBT_I2C_NOP;
anbt_i2c_data_buffer[11]=anbt_i2c_data;
ANBT_I2C_Receive14Bytes(u8 *anbt_i2c_data_buffer)
u8 i,j;
u8 anbt_i2c_data;
for(j=0;j<13;j++)
ANBT_I2C_SDA_1;
ANBT_I2C_SCL_0;
anbt_i2c_data=0;
for(i=0;i<8;i++)
ANBT_I2C_SCL_1;
ANBT_I2C_NOP;
anbt_i2c_data<<=1;
ANBT_I2C_SCL_0;
ANBT_I2C_NOP;
ANBT_I2C_SendACK();
ANBT_I2C_SDA_1;
ANBT_I2C_SCL_0;
anbt_i2c_data=0;
for(i=0;i<8;i++)
ANBT_I2C_SCL_1;
ANBT_I2C_NOP;
anbt_i2c_data<<=1;
ANBT_I2C_SCL_0;
ANBT_I2C_NOP;
anbt_i2c_data_buffer[13]=anbt_i2c_data;
AnBT_DMP_Delay_us(u32 dly)
u8 i;
while(dly--) for(i=0;i<10;i++);
AnBT_DMP_I2C_Write(u8 anbt_dev_addr, u8 anbt_reg_addr, u8 anbt_i2c_len, u8 *anbt_i2c_data_buf)
u8 i;
ANBT_I2C_START();
ANBT_I2C_SendByte(anbt_dev_addr << 1 | I2C_Direction_Transmitter); //发送陀螺仪写地址
ANBT_I2C_SendByte(anbt_reg_addr); //发送陀螺仪PWM地址
for (i=0;i<anbt_i2c_len;i++) ANBT_I2C_SendByte(anbt_i2c_data_buf[i]); //发送陀螺仪PWM值
ANBT_I2C_STOP();
return 0x00;
AnBT_DMP_I2C_Read(u8 anbt_dev_addr, u8 anbt_reg_addr, u8 anbt_i2c_len, u8 *anbt_i2c_data_buf)
ANBT_I2C_START();
ANBT_I2C_SendByte(anbt_reg_addr); //发送陀螺仪ID地址
ANBT_I2C_START();
ANBT_I2C_SendByte(anbt_dev_addr << 1 | I2C_Direction_Receiver); //圆点博士:发送陀螺仪读地址
while (anbt_i2c_len)
if (anbt_i2c_len==1) *anbt_i2c_data_buf =ANBT_I2C_ReceiveByte();
else *anbt_i2c_data_buf =ANBT_I2C_ReceiveByte_WithACK();
anbt_i2c_data_buf++;
anbt_i2c_len--;
ANBT_I2C_STOP();
return 0x00;
AnBT_DMP_Delay_ms(u32 dly)
os_delay_us(dly*1000);
//while(dly--) AnBT_DMP_Delay_us(1000);
[/code]
MPU6050驱动
//License:
//Copyright (C) 2011-2012 InvenSense Corporation, All Rights Reserved.
//See included License.txt for License information.
//* @addtogroup DRIVERS Sensor Driver Layer
//* @brief Hardware drivers to communicate with sensors via I2C.
//* @file inv_mpu_dmp_motion_driver.c
//* @brief DMP image and interface functions.
//* @details All functions are preceded by the dmp_ prefix to
//* differentiate among MPL and general driver function calls.
#include "anbt_dmp_mpu6050.h"
#include "anbt_dmp_driver.h"
#include "anbt_dmp_fun.h"
#define q30 1073741824.0f
long anbt_mpu6050_quat_data[4];
short gyro[3], accel[3], sensors;
unsigned char more;
unsigned long sensor_timestamp;
const struct gyro_reg_s reg= {
0x75, //who_am_i
0x19, //rate_div
0x1A, //lpf
0x0C, //prod_id
0x6A, //user_ctrl
0x23, //fifo_en
0x1B, //gyro_cfg
0x1C, //accel_cfg
0x1F, // motion_thr
0x20, // motion_dur
0x72, // fifo_count_h
0x74, // fifo_r_w
0x43, // raw_gyro
0x3B, // raw_accel
0x41, // temp
0x38, // int_enable
0x39, // dmp_int_status
0x3A, // int_status
0x6B, // pwr_mgmt_1
0x6C, // pwr_mgmt_2
0x37, // int_pin_cfg
0x6F, // mem_r_w
0x06, // accel_offs
0x24, // i2c_mst
0x6D, // bank_sel
0x6E, // mem_start_addr
0x70 // prgm_start_h
const struct hw_s hw={
0x68, //addr
1024, //max_fifo
118, //num_reg
340, //temp_sens
-521, //temp_offset
256 //bank_size
const struct test_s test={
32768/250, //gyro_sens
32768/16, // accel_sens
0, // reg_rate_div
1, // reg_lpf
0, // reg_gyro_fsr
0x18, // reg_accel_fsr
50, // wait_ms
5, // packet_thresh
10.0f, // min_dps
105.0f, // max_dps
0.14f, // max_gyro_var
0.3f, // min_g
0.95f, // max_g
0.14f // max_accel_var
static struct gyro_state_s st={
&hw,
{0},
&test
int ICACHE_FLASH_ATTR
mpu_set_gyro_fsr(unsigned short fsr)
unsigned char data;
if (!(st.chip_cfg.sensors))
return -1;
switch (fsr) {
case 250:
data = INV_FSR_250DPS << 3;
break;
case 500:
data = INV_FSR_500DPS << 3;
break;
case 1000:
data = INV_FSR_1000DPS << 3;
break;
case 2000:
data = INV_FSR_2000DPS << 3;
break;
default:
return -1;
if (st.chip_cfg.gyro_fsr == (data >> 3))
return 0;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->gyro_cfg, 1, &data))
return -1;
st.chip_cfg.gyro_fsr = data >> 3;
return 0;
mpu_set_accel_fsr(unsigned char fsr)
unsigned char data;
return -1;
switch (fsr) {
case 2:
data = INV_FSR_2G << 3;
break;
case 4:
data = INV_FSR_4G << 3;
break;
case 8:
data = INV_FSR_8G << 3;
break;
case 16:
data = INV_FSR_16G << 3;
break;
default:
return -1;
if (st.chip_cfg.accel_fsr == (data >> 3))
return 0;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->accel_cfg, 1, &data))
return -1;
st.chip_cfg.accel_fsr = data >> 3;
return 0;
mpu_set_lpf(unsigned short lpf)
unsigned char data;
return -1;
if (lpf >= 188)
data = INV_FILTER_188HZ;
else if (lpf >= 98)
data = INV_FILTER_98HZ;
else if (lpf >= 42)
data = INV_FILTER_42HZ;
else if (lpf >= 20)
data = INV_FILTER_20HZ;
else if (lpf >= 10)
data = INV_FILTER_10HZ;
else
data = INV_FILTER_5HZ;
if (st.chip_cfg.lpf == data)
return 0;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->lpf, 1, &data))
return -1;
st.chip_cfg.lpf = data;
return 0;
mpu_set_int_latched(unsigned char enable)
unsigned char tmp;
if (st.chip_cfg.latched_int == enable)
return 0;
if (enable)
tmp = BIT_LATCH_EN | BIT_ANY_RD_CLR;
else
tmp = 0;
if (st.chip_cfg.bypass_mode)
tmp |= BIT_BYPASS_EN;
if (st.chip_cfg.active_low_int)
tmp |= BIT_ACTL;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->int_pin_cfg, 1, &tmp))
return -1;
st.chip_cfg.latched_int = enable;
return 0;
static int ICACHE_FLASH_ATTR
set_int_enable(unsigned char enable)
unsigned char tmp;
if (st.chip_cfg.dmp_on) {
if (enable)
tmp = BIT_DMP_INT_EN;
else
tmp = 0x00;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->int_enable, 1, &tmp))
return -1;
st.chip_cfg.int_enable = tmp;
} else {
if (!st.chip_cfg.sensors)
return -1;
if (enable && st.chip_cfg.int_enable)
return 0;
if (enable)
tmp = BIT_DATA_RDY_EN;
else
tmp = 0x00;
return -1;
return 0;
mpu_reset_fifo(void)
unsigned char data;
return -1;
data = 0;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->int_enable, 1, &data))
return -1;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->fifo_en, 1, &data))
return -1;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->user_ctrl, 1, &data))
return -1;
data = BIT_FIFO_RST | BIT_DMP_RST;
return -1;
AnBT_DMP_Delay_ms(50);
data = BIT_DMP_EN | BIT_FIFO_EN;
if (st.chip_cfg.sensors & INV_XYZ_COMPASS)
data |= BIT_AUX_IF_EN;
return -1;
if (st.chip_cfg.int_enable)
data = BIT_DMP_INT_EN;
else
data = 0;
return -1;
data = 0;
return -1;
} else {
data = BIT_FIFO_RST;
return -1;
if (st.chip_cfg.bypass_mode || !(st.chip_cfg.sensors & INV_XYZ_COMPASS))
data = BIT_FIFO_EN;
else
data = BIT_FIFO_EN | BIT_AUX_IF_EN;
return -1;
data = BIT_DATA_RDY_EN;
else
data = 0;
return -1;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->fifo_en, 1, &st.chip_cfg.fifo_enable))
return -1;
return 0;
* @brief Select which sensors are pushed to FIFO.
* @e sensors can contain a combination of the following flags:
* \n INV_X_GYRO, INV_Y_GYRO, INV_Z_GYRO
* \n INV_XYZ_GYRO
* \n INV_XYZ_ACCEL
* @param[in] sensors Mask of sensors to push to FIFO.
* @return 0 if successful.
mpu_configure_fifo(unsigned char sensors)
unsigned char prev;
int result = 0;
sensors &= ~INV_XYZ_COMPASS;
return 0;
else {
return -1;
prev = st.chip_cfg.fifo_enable;
st.chip_cfg.fifo_enable = sensors & st.chip_cfg.sensors;
if (st.chip_cfg.fifo_enable != sensors)
result = -1;
else
result = 0;
if (sensors || st.chip_cfg.lp_accel_mode)
set_int_enable(1);
else
set_int_enable(0);
if (sensors) {
if (mpu_reset_fifo()) {
st.chip_cfg.fifo_enable = prev;
return -1;
return result;
mpu_lp_accel_mode(unsigned char rate)
unsigned char tmp[2];
if (rate > 40)
return -1;
if (!rate) {
mpu_set_int_latched(0);
tmp[0] = 0;
tmp[1] = BIT_STBY_XYZG;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->pwr_mgmt_1, 2, tmp))
return -1;
st.chip_cfg.lp_accel_mode = 0;
return 0;
mpu_set_int_latched(1);
tmp[0] = BIT_LPA_CYCLE;
if (rate == 1) {
tmp[1] = INV_LPA_1_25HZ;
mpu_set_lpf(5);
} else if (rate <= 5) {
tmp[1] = INV_LPA_5HZ;
mpu_set_lpf(5);
} else if (rate <= 20) {
tmp[1] = INV_LPA_20HZ;
mpu_set_lpf(10);
} else {
tmp[1] = INV_LPA_40HZ;
mpu_set_lpf(20);
tmp[1] = (tmp[1] << 6) | BIT_STBY_XYZG;
return -1;
st.chip_cfg.sensors = INV_XYZ_ACCEL;
st.chip_cfg.clk_src = 0;
st.chip_cfg.lp_accel_mode = 1;
mpu_configure_fifo(0);
return 0;
mpu_set_sample_rate(unsigned short rate)
unsigned char data;
return -1;
return -1;
else {
if (st.chip_cfg.lp_accel_mode) {
if (rate && (rate <= 40)) {
/* Just stay in low-power accel mode. */
mpu_lp_accel_mode(rate);
return 0;
/* Requested rate exceeds the allowed frequencies in LP accel mode,
* switch back to full-power mode.
mpu_lp_accel_mode(0);
if (rate < 4)
rate = 4;
else if (rate > 1000)
rate = 1000;
data = 1000 / rate - 1;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->rate_div, 1, &data))
return -1;
st.chip_cfg.sample_rate = 1000 / (1 + data);
/* Automatically set LPF to 1/2 sampling rate. */
mpu_set_lpf(st.chip_cfg.sample_rate >> 1);
return 0;
mpu_set_bypass(unsigned char bypass_on)
unsigned char tmp;
if (st.chip_cfg.bypass_mode == bypass_on)
return 0;
if (bypass_on) {
if (AnBT_DMP_I2C_Read(st.hw->addr, st.reg->user_ctrl, 1, &tmp))
return -1;
tmp &= ~BIT_AUX_IF_EN;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->user_ctrl, 1, &tmp))
return -1;
AnBT_DMP_Delay_ms(3);
tmp = BIT_BYPASS_EN;
tmp |= BIT_ACTL;
if (st.chip_cfg.latched_int)
tmp |= BIT_LATCH_EN | BIT_ANY_RD_CLR;
return -1;
} else {
/* Enable I2C master mode if compass is being used. */
return -1;
tmp |= BIT_AUX_IF_EN;
else
return -1;
tmp = BIT_ACTL;
else
tmp = 0;
return -1;
st.chip_cfg.bypass_mode = bypass_on;
return 0;
mpu_set_sensors(unsigned char sensors)
unsigned char data;
if (sensors & INV_XYZ_GYRO)
data = INV_CLK_PLL;
else if (sensors)
data = 0;
else
data = BIT_SLEEP;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->pwr_mgmt_1, 1, &data)) {
st.chip_cfg.sensors = 0;
return -1;
st.chip_cfg.clk_src = data & ~BIT_SLEEP;
data = 0;
if (!(sensors & INV_X_GYRO))
data |= BIT_STBY_XG;
if (!(sensors & INV_Y_GYRO))
data |= BIT_STBY_YG;
if (!(sensors & INV_Z_GYRO))
data |= BIT_STBY_ZG;
if (!(sensors & INV_XYZ_ACCEL))
data |= BIT_STBY_XYZA;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->pwr_mgmt_2, 1, &data)) {
return -1;
if (sensors && (sensors != INV_XYZ_ACCEL))
/* Latched interrupts only used in LP accel mode. */
st.chip_cfg.sensors = sensors;
return 0;
mpu_set_dmp_state(unsigned char enable)
unsigned char tmp;
if (st.chip_cfg.dmp_on == enable)
return 0;
if (enable)
if (!st.chip_cfg.dmp_loaded)
return -1;
/* Disable data ready interrupt. */
set_int_enable(0);
/* Disable bypass mode. */
mpu_set_bypass(0);
/* Keep constant sample rate, FIFO rate controlled by DMP. */
mpu_set_sample_rate(st.chip_cfg.dmp_sample_rate);
/* Remove FIFO elements. */
tmp = 0;
AnBT_DMP_I2C_Write(st.hw->addr, 0x23, 1, &tmp);
st.chip_cfg.dmp_on = 1;
/* Enable DMP interrupt. */
set_int_enable(1);
mpu_reset_fifo();
else
/* Disable DMP interrupt. */
set_int_enable(0);
/* Restore FIFO settings. */
tmp = st.chip_cfg.fifo_enable;
st.chip_cfg.dmp_on = 0;
mpu_reset_fifo();
return 0;
mpu_get_gyro_fsr(unsigned short *fsr)
switch (st.chip_cfg.gyro_fsr) {
case INV_FSR_250DPS:
fsr[0] = 250;
break;
case INV_FSR_500DPS:
fsr[0] = 500;
break;
case INV_FSR_1000DPS:
fsr[0] = 1000;
break;
case INV_FSR_2000DPS:
fsr[0] = 2000;
break;
default:
fsr[0] = 0;
break;
return 0;
mpu_get_accel_fsr(unsigned char *fsr)
switch (st.chip_cfg.accel_fsr) {
case INV_FSR_2G:
fsr[0] = 2;
break;
case INV_FSR_4G:
fsr[0] = 4;
break;
case INV_FSR_8G:
fsr[0] = 8;
break;
case INV_FSR_16G:
fsr[0] = 16;
break;
default:
return -1;
if (st.chip_cfg.accel_half)
fsr[0] <<= 1;
return 0;
mpu_get_lpf(unsigned short *lpf)
switch (st.chip_cfg.lpf) {
case INV_FILTER_188HZ:
lpf[0] = 188;
break;
case INV_FILTER_98HZ:
lpf[0] = 98;
break;
case INV_FILTER_42HZ:
lpf[0] = 42;
break;
case INV_FILTER_20HZ:
lpf[0] = 20;
break;
case INV_FILTER_10HZ:
lpf[0] = 10;
break;
case INV_FILTER_5HZ:
lpf[0] = 5;
break;
case INV_FILTER_256HZ_NOLPF2:
case INV_FILTER_2100HZ_NOLPF:
default:
lpf[0] = 0;
break;
return 0;
mpu_get_sample_rate(unsigned short *rate)
return -1;
else
rate[0] = st.chip_cfg.sample_rate;
return 0;
mpu_get_fifo_config(unsigned char *sensors)
sensors[0] = st.chip_cfg.fifo_enable;
return 0;
get_st_biases(long *gyro, long *accel, unsigned char hw_test)
unsigned char data[MAX_PACKET_LENGTH];
unsigned char packet_count, ii;
unsigned short fifo_count;
data[0] = 0x01;
data[1] = 0;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->pwr_mgmt_1, 2, data))
return -1;
AnBT_DMP_Delay_ms(200);
data[0] = 0;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->int_enable, 1, data))
return -1;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->fifo_en, 1, data))
return -1;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->pwr_mgmt_1, 1, data))
return -1;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->i2c_mst, 1, data))
return -1;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->user_ctrl, 1, data))
return -1;
data[0] = BIT_FIFO_RST | BIT_DMP_RST;
return -1;
AnBT_DMP_Delay_ms(15);
data[0] = st.test->reg_lpf;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->lpf, 1, data))
return -1;
data[0] = st.test->reg_rate_div;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->rate_div, 1, data))
return -1;
if (hw_test)
data[0] = st.test->reg_gyro_fsr | 0xE0;
else
data[0] = st.test->reg_gyro_fsr;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->gyro_cfg, 1, data))
return -1;
if (hw_test)
data[0] = st.test->reg_accel_fsr | 0xE0;
else
data[0] = test.reg_accel_fsr;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->accel_cfg, 1, data))
return -1;
if (hw_test)
/* Fill FIFO for test.wait_ms milliseconds. */
data[0] = BIT_FIFO_EN;
return -1;
data[0] = INV_XYZ_GYRO | INV_XYZ_ACCEL;
return -1;
AnBT_DMP_Delay_ms(test.wait_ms);
data[0] = 0;
return -1;
if (AnBT_DMP_I2C_Read(st.hw->addr, st.reg->fifo_count_h, 2, data))
return -1;
fifo_count = (data[0] << 8) | data[1];
packet_count = fifo_count / MAX_PACKET_LENGTH;
gyro[0] = gyro[1] = gyro[2] = 0;
accel[0] = accel[1] = accel[2] = 0;
for (ii = 0; ii < packet_count; ii++) {
short accel_cur[3], gyro_cur[3];
if (AnBT_DMP_I2C_Read(st.hw->addr, st.reg->fifo_r_w, MAX_PACKET_LENGTH, data))
return -1;
accel_cur[0] = ((short)data[0] << 8) | data[1];
accel_cur[1] = ((short)data[2] << 8) | data[3];
accel_cur[2] = ((short)data[4] << 8) | data[5];
accel[0] += (long)accel_cur[0];
accel[1] += (long)accel_cur[1];
accel[2] += (long)accel_cur[2];
gyro_cur[0] = (((short)data[6] << 8) | data[7]);
gyro_cur[1] = (((short)data[8] << 8) | data[9]);
gyro_cur[2] = (((short)data[10] << 8) | data[11]);
gyro[0] += (long)gyro_cur[0];
gyro[1] += (long)gyro_cur[1];
gyro[2] += (long)gyro_cur[2];
gyro[0] = (long)(((long long)gyro[0]<<16) / test.gyro_sens / packet_count);
gyro[1] = (long)(((long long)gyro[1]<<16) / test.gyro_sens / packet_count);
gyro[2] = (long)(((long long)gyro[2]<<16) / test.gyro_sens / packet_count);
accel[0] = (long)(((long long)accel[0]<<16) / test.accel_sens /
packet_count);
accel[1] = (long)(((long long)accel[1]<<16) / test.accel_sens /
packet_count);
accel[2] = (long)(((long long)accel[2]<<16) / test.accel_sens /
packet_count);
/* Don't remove gravity! */
if (accel[2] > 0L)
accel[2] -= 65536L;
else
accel[2] += 65536L;
return 0;
get_accel_prod_shift(float *st_shift)
unsigned char tmp[4], shift_code[3], ii;
if (AnBT_DMP_I2C_Read(st.hw->addr, 0x0D, 4, tmp))
return 0x07;
shift_code[0] = ((tmp[0] & 0xE0) >> 3) | ((tmp[3] & 0x30) >> 4);
shift_code[1] = ((tmp[1] & 0xE0) >> 3) | ((tmp[3] & 0x0C) >> 2);
shift_code[2] = ((tmp[2] & 0xE0) >> 3) | (tmp[3] & 0x03);
for (ii = 0; ii < 3; ii++) {
if (!shift_code[ii]) {
st_shift[ii] = 0.f;
continue;
/* Equivalent to..
* st_shift[ii] = 0.34f * powf(0.92f/0.34f, (shift_code[ii]-1) / 30.f)
st_shift[ii] = 0.34f;
while (--shift_code[ii])
st_shift[ii] *= 1.034f;
return 0;
mpu_get_gyro_sens(float *sens)
sens[0] = 131.f;
break;
sens[0] = 65.5f;
break;
sens[0] = 32.8f;
break;
sens[0] = 16.4f;
break;
default:
return -1;
return 0;
mpu_get_accel_sens(unsigned short *sens)
case INV_FSR_2G:
sens[0] = 16384;
break;
case INV_FSR_4G:
sens[0] = 8092;
break;
case INV_FSR_8G:
sens[0] = 4096;
break;
case INV_FSR_16G:
sens[0] = 2048;
break;
default:
return -1;
sens[0] >>= 1;
return 0;
accel_self_test(long *bias_regular, long *bias_st)
int jj, result = 0;
float st_shift[3], st_shift_cust, st_shift_var;
get_accel_prod_shift(st_shift);
for(jj = 0; jj < 3; jj++) {
st_shift_cust = labs(bias_regular[jj] - bias_st[jj]) / 65536.f;
if (st_shift[jj]) {
st_shift_var = st_shift_cust / st_shift[jj] - 1.f;
if (fabs(st_shift_var) > test.max_accel_var)
result |= 1 << jj;
} else if ((st_shift_cust < test.min_g) ||
(st_shift_cust > test.max_g))
result |= 1 << jj;
return result;
gyro_self_test(long *bias_regular, long *bias_st)
int jj, result = 0;
unsigned char tmp[3];
float st_shift, st_shift_cust, st_shift_var;
if (AnBT_DMP_I2C_Read(st.hw->addr, 0x0D, 3, tmp))
return 0x07;
tmp[0] &= 0x1F;
tmp[1] &= 0x1F;
tmp[2] &= 0x1F;
for (jj = 0; jj < 3; jj++) {
if (tmp[jj]) {
st_shift = 3275.f / test.gyro_sens;
while (--tmp[jj])
st_shift *= 1.046f;
st_shift_var = st_shift_cust / st_shift - 1.f;
if (fabs(st_shift_var) > test.max_gyro_var)
result |= 1 << jj;
} else if ((st_shift_cust < test.min_dps) ||
(st_shift_cust > test.max_dps))
result |= 1 << jj;
return result;
mpu_run_self_test(long *gyro, long *accel)
const unsigned char tries = 2;
long gyro_st[3], accel_st[3];
unsigned char accel_result, gyro_result;
int ii;
int result;
unsigned char accel_fsr, fifo_sensors, sensors_on;
unsigned short gyro_fsr, sample_rate, lpf;
unsigned char dmp_was_on;
mpu_set_dmp_state(0);
dmp_was_on = 1;
} else
dmp_was_on = 0;
/* Get initial settings. */
mpu_get_gyro_fsr(&gyro_fsr);
mpu_get_accel_fsr(&accel_fsr);
mpu_get_lpf(&lpf);
mpu_get_sample_rate(&sample_rate);
sensors_on = st.chip_cfg.sensors;
mpu_get_fifo_config(&fifo_sensors);
/* For older chips, the self-test will be different. */
for (ii = 0; ii < tries; ii++)
if (!get_st_biases(gyro, accel, 0))
break;
if (ii == tries) {
/* If we reach this point, we most likely encountered an I2C error.
* We'll just report an error for all three sensors.
result = 0;
goto restore;
if (!get_st_biases(gyro_st, accel_st, 1))
break;
if (ii == tries) {
/* Again, probably an I2C error. */
result = 0;
goto restore;
accel_result = accel_self_test(accel, accel_st);
gyro_result = gyro_self_test(gyro, gyro_st);
result = 0;
if (!gyro_result)
result |= 0x01;
if (!accel_result)
result |= 0x02;
restore:
/* Set to invalid values to ensure no I2C writes are skipped. */
st.chip_cfg.gyro_fsr = 0xFF;
st.chip_cfg.accel_fsr = 0xFF;
st.chip_cfg.lpf = 0xFF;
st.chip_cfg.sample_rate = 0xFFFF;
st.chip_cfg.sensors = 0xFF;
st.chip_cfg.fifo_enable = 0xFF;
st.chip_cfg.clk_src = INV_CLK_PLL;
mpu_set_gyro_fsr(gyro_fsr);
mpu_set_accel_fsr(accel_fsr);
mpu_set_lpf(lpf);
mpu_set_sample_rate(sample_rate);
mpu_set_sensors(sensors_on);
mpu_configure_fifo(fifo_sensors);
if (dmp_was_on) mpu_set_dmp_state(1);
return result;
run_self_test(void)
int result;
// char test_packet[4] = {0};
long gyro[3], accel[3];
result = mpu_run_self_test(gyro, accel);
// if (result == 0x7)
if (result == 0x3)
/* Test passed. We can trust the gyro data here, so let's push it down
* to the DMP.
float sens;
unsigned short accel_sens;
mpu_get_gyro_sens(&sens);
gyro[0] = (long)(gyro[0] * sens);
gyro[1] = (long)(gyro[1] * sens);
gyro[2] = (long)(gyro[2] * sens);
dmp_set_gyro_bias(gyro);
mpu_get_accel_sens(&accel_sens);
accel[0] *= accel_sens;
accel[1] *= accel_sens;
accel[2] *= accel_sens;
dmp_set_accel_bias(accel);
os_printf("result is %d\n",result);
mpu_write_mem(unsigned short mem_addr, unsigned short length, unsigned char *data)
if (!data)
return -1;
return -1;
tmp[0] = (unsigned char)(mem_addr >> 8);
tmp[1] = (unsigned char)(mem_addr & 0xFF);
/* Check bank boundaries. */
if (tmp[1] + length > st.hw->bank_size)
return -1;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->bank_sel, 2, tmp))
return -1;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->mem_r_w, length, data))
return -1;
return 0;
mpu_read_mem(unsigned short mem_addr, unsigned short length, unsigned char *data)
if (!data)
return -1;
return -1;
return -1;
return -1;
if (AnBT_DMP_I2C_Read(st.hw->addr, st.reg->mem_r_w, length, data))
return -1;
return 0;
mpu_read_fifo_stream(unsigned short length, unsigned char *data, unsigned char *more)
if (!st.chip_cfg.dmp_on)
return -1;
return -1;
if (AnBT_DMP_I2C_Read(st.hw->addr, st.reg->fifo_count_h, 2, tmp))
return -1;
fifo_count = (tmp[0] << 8) | tmp[1];
if (fifo_count < length) {
more[0] = 0;
return -1;
if (fifo_count > (st.hw->max_fifo >> 1)) {
/* FIFO is 50% full, better check overflow bit. */
if (AnBT_DMP_I2C_Read(st.hw->addr, st.reg->int_status, 1, tmp))
return -1;
if (tmp[0] & BIT_FIFO_OVERFLOW) {
mpu_reset_fifo();
return -2;
if (AnBT_DMP_I2C_Read(st.hw->addr, st.reg->fifo_r_w, length, data))
return -1;
more[0] = fifo_count / length - 1;
return 0;
mpu_load_firmware(unsigned short length, const unsigned char *firmware,unsigned short start_addr, unsigned short sample_rate)
unsigned short ii;
unsigned short this_write;
/* Must divide evenly into st.hw->bank_size to avoid bank crossings. */
#define LOAD_CHUNK (16)
unsigned char cur[LOAD_CHUNK], tmp[2];
if (st.chip_cfg.dmp_loaded)
/* DMP should only be loaded once. */
return -1;
if (!firmware)
return -1;
for (ii = 0; ii < length; ii += this_write) {
this_write = min(LOAD_CHUNK, length - ii);
if (mpu_write_mem(ii, this_write, (unsigned char*)&firmware[ii]))
return -1;
if (mpu_read_mem(ii, this_write, cur))
return -1;
if (memcmp(firmware+ii, cur, this_write))
return -2;
/* Set program start address. */
tmp[0] = start_addr >> 8;
tmp[1] = start_addr & 0xFF;
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->prgm_start_h, 2, tmp))
return -1;
st.chip_cfg.dmp_loaded = 1;
st.chip_cfg.dmp_sample_rate = sample_rate;
return 0;
static unsigned short ICACHE_FLASH_ATTR
inv_row_2_scale(const signed char *row)
unsigned short b;
if (row[0] > 0) b = 0;
else if (row[0] < 0) b = 4;
else if (row[1] > 0) b = 1;
else if (row[1] < 0) b = 5;
else if (row[2] > 0) b = 2;
else if (row[2] < 0) b = 6;
else b = 7; // error
return b;
inv_orientation_matrix_to_scalar(const signed char *mtx)
unsigned short scalar;
XYZ 010_001_000 Identity Matrix
XZY 001_010_000
YXZ 010_000_001
YZX 000_010_001
ZXY 001_000_010
ZYX 000_001_010
scalar = inv_row_2_scale(mtx);
scalar |= inv_row_2_scale(mtx + 3) << 3;
scalar |= inv_row_2_scale(mtx + 6) << 6;
return scalar;
AnBT_DMP_MPU6050_DEV_CFG(void)
unsigned char anbt_dmp_data[6], anbt_dmp_rev;
//检验WHO AM I
if (AnBT_DMP_I2C_Read(st.hw->addr, st.reg->who_am_i, 1, &(anbt_dmp_data[0])))
return 1;
if (anbt_dmp_data[0]!=PRODUCT_WHOAMI)
os_printf("I2C从机地址设置错误,请将AD0端口接地 ID is %d\n",anbt_dmp_data[0]);
//AnBT_Uart1_Send_Num(anbt_dmp_data[0]);
return 2;
else
os_printf("MPU ID is %d\n",anbt_dmp_data[0]);
anbt_dmp_data[0] = 0x80; //etootle: BIT_RESET, Reset device 重设器件
if (AnBT_DMP_I2C_Write(st.hw->addr, st.reg->pwr_mgmt_1, 1, &(anbt_dmp_data[0])))
return 3;
AnBT_DMP_Delay_ms(100);
anbt_dmp_data[0] = 0x00; //etootle: Wake up chip 唤醒
return 4;
if (AnBT_DMP_I2C_Read(st.hw->addr, st.reg->accel_offs, 6, anbt_dmp_data))
return 5; //etootle:Check product revision 检查产品修正
anbt_dmp_rev = ((anbt_dmp_data[5] & 0x01) << 2) | ((anbt_dmp_data[3] & 0x01) << 1) | (anbt_dmp_data[1] & 0x01);
if (anbt_dmp_rev) //Congrats, these parts are better
if (anbt_dmp_rev == 1)
st.chip_cfg.accel_half = 1;
else
if (anbt_dmp_rev == 2)
st.chip_cfg.accel_half = 0;
else
os_printf("Unsupported version=1.0/n");
return 6;
else
if (AnBT_DMP_I2C_Read(st.hw->addr, st.reg->prod_id, 1, &(anbt_dmp_data[0]))) return 7;
anbt_dmp_rev = anbt_dmp_data[0] & 0x0F;
if (!anbt_dmp_rev)
os_printf("Product ID error/n"); //产品编号错误
return 5;
else
if (anbt_dmp_rev == 4)
os_printf("Half Sensitivity Part/n");
else
st.chip_cfg.bypass_mode = 0xFF;
/* mpu_set_sensors always preserves this setting. */
/* Handled in next call to mpu_set_bypass. */
st.chip_cfg.active_low_int = 1;
st.chip_cfg.latched_int = 0;
st.chip_cfg.int_motion_only = 0;
memset(&st.chip_cfg.cache, 0, sizeof(st.chip_cfg.cache));
st.chip_cfg.dmp_loaded = 0;
st.chip_cfg.dmp_sample_rate = 0;
if (mpu_set_gyro_fsr(2000)) return 0x10;
if (mpu_set_accel_fsr(2)) return 0x11;
if (mpu_set_lpf(42)) return 0x12;
if (mpu_set_sample_rate(50)) return 0x13;
if (mpu_configure_fifo(0)) return 0x14;
/* Already disabled by setup_compass. */
if (mpu_set_bypass(0)) return 0x15; //不同点
mpu_set_sensors(0);
return 0;
AnBT_DMP_MPU6050_Init(void)
u8 err;
err = AnBT_DMP_MPU6050_DEV_CFG(); //etootle: init the mpu6050 chip
os_printf("1.DMP Init ......%d\n",err); //完成初始化
if(!mpu_set_sensors(INV_XYZ_GYRO | INV_XYZ_ACCEL)) os_printf("2.DMP设置传感器成功\n"); //完成传感去设定
else os_printf("2.DMP设置传感器错误\n");
if(!mpu_configure_fifo(INV_XYZ_GYRO | INV_XYZ_ACCEL)) os_printf("3.设置FIFO成功\n"); //完成fifo设置
else os_printf("3.设置FIFO失败\n");
if(!mpu_set_sample_rate(DEFAULT_MPU_HZ))os_printf("4.DMP设置采样率成功\n"); //完成DMP采样率设置
else os_printf("4.DMP设置采样率失败\n");
if(!dmp_load_motion_driver_firmware()) os_printf("5.DMP加载运动驱动固件成功\n"); //开启DMP功能
else os_printf("5.DMP加载运动驱动固件失败\n");
if(!dmp_set_orientation(inv_orientation_matrix_to_scalar(gyro_orientation))) os_printf("6.DMP完成设置初始方向设定偏差\n"); //初始方向设定偏差
else os_printf("6.DMP设置初始方向设定偏差出错\n");
if(!dmp_enable_feature(DMP_FEATURE_6X_LP_QUAT | DMP_FEATURE_TAP |
DMP_FEATURE_ANDROID_ORIENT | DMP_FEATURE_SEND_RAW_ACCEL | DMP_FEATURE_SEND_CAL_GYRO |
DMP_FEATURE_GYRO_CAL)) os_printf("7.DMP使能成功\n"); //DMP使能
else os_printf("7.DMP使能出错\n");
if(!dmp_set_fifo_rate(DEFAULT_MPU_HZ)) os_printf("8.DMP设置FIFO速率成功\n"); //DMP fifo速度
else os_printf("8.DMP设置FIFO速率失败\n");
run_self_test();
//system_soft_wdt_feed();//喂狗
err = mpu_set_dmp_state(1);
if(!err) os_printf("9.Dmp启动成功......%d\n",err); //DMP成功开启
else os_printf("9.Dmp启动失败......%d\n",err); //Dmp启动失败
os_printf("9.Dmp......%d\n",err);
return 0;
AnBT_DMP_MPU6050_SEND_DATA_FUN(void) //dmp读取函数
dmp_read_fifo(gyro, accel, anbt_mpu6050_quat_data, &sensor_timestamp, &sensors, &more);
MPU6050_OUT_Da(void)
//unsigned char more;
//unsigned long sensor_timestamp;
//short gyro[3], accel[3], sensors;//陀螺仪存放数组,加速度存放数组,返回状态量
long quat[4];//四元数存放数组
float Yaw=0.00,Roll,Pitch;//欧拉角
float q0=1.0f,q1=0.0f,q2=0.0f,q3=0.0f;//计算姿态过程用到的变量
AnBT_DMP_MPU6050_SEND_DATA_FUN();
//dmp_read_fifo(gyro, accel, quat, &sensor_timestamp, &sensors,&more);
if(sensors&INV_WXYZ_QUAT)
q0=quat[0] / q30;
q1=quat[1] / q30;
q2=quat[2] / q30;
q3=quat[3] / q30;
Pitch = asin(-2 * q1 * q3 + 2 * q0* q2)* 57.3; // pitch
Roll = atan2(2 * q2 * q3 + 2 * q0 * q1, -2 * q1 * q1 - 2 * q2* q2 + 1)* 57.3; // roll
Yaw = atan2(2*(q1*q2 + q0*q3),q0*q0+q1*q1-q2*q2-q3*q3) * 57.3;
// printf("pitch: %.2f roll:%.2f yaw:%.2f\r\n",Pitch,Roll,Yaw); //普通串口输出
//Data_Send_Status(Pitch,Roll,Yaw,gyro,accel);
//delay_init(72);
