ESP as a AP
anupak
ESP as a AP
Postby anupak » Wed Sep 09, 2015 10:39 pm
I am trying to use the ESP-01 as an AP (with AUTH_WPA_WPA2_PSK) authorization. I have based my code off the sample code. The ESP does behave as a AP, but with no authentication (i.e. open network). Am I missing something?
My code is as follows:
/* Setup the Acess point settings */
void ICACHE_FLASH_ATTR user_set_ap_config(void)
    struct softap_config config;
    wifi_set_opmode(0x02);
    wifi_softap_get_config(&config); // Get config first.
    os_memset(config.ssid, 0, 32);
    os_memset(config.password, 0, 64);
    os_memcpy(config.ssid, SSID, os_strlen(SSID)); // Changes from sample
    os_memcpy(config.password, PASSWORD, os_strlen(PASSWORD));  // Changes from sample
    config.ssid_len = 0;// or its actual length
    config.max_connection = 4; // how many stations can connect to ESP8266 softAP at most.
    wifi_softap_set_config(&config);// Set ESP8266 softap config .
FYI: I am using an android phone to connect to ESP.
Regards
Anupak
Re: ESP as a AP
Postby ESP_Faye » Fri Sep 18, 2015 2:46 pm
What a strange problem !
Maybe you could provide your bin files and I'll test it .
