[Resolved]wifi_station_set_config() fails sporadically.
robertfoss
Postby robertfoss » Thu Sep 10, 2015 5:32 am
About 50% of the calls to wifi_station_set_config() fail. Which are the possible failure modes of wifi_station_set_config()?
  struct station_config cnf;
  c_memset(&cnf, 0, sizeof(struct station_config));
  dns_hijack_http_urldecode(cnf.ssid, name_str_start, name_str_len);
  dns_hijack_http_urldecode(cnf.password, pwd_str_start, pwd_str_len);
  c_printf("\n");
  c_printf("WiFi Credentials Stored\n");
  c_printf("-----------------------\n");
  c_printf("name: \"%s\"\n", cnf.ssid);
  c_printf("pass: \"%s\"\n", cnf.password);
  c_printf("bssid_set: %u\n", cnf.bssid_set);
  c_printf("bssid: \"%s\"\n", cnf.bssid);
  c_printf("-----------------------\n\n");
  wifi_station_disconnect();
  while (wifi_station_set_config(&cnf) == FALSE)
    c_printf("dns_hijack_http_handle_credentials failed. Unable to set STATION mode config.\n");
Produces:
pass: "sweetlove"
bssid_set: 0
bssid: ""
Re: wifi_station_set_config() fails sporadically.
Postby ESP_Faye » Thu Sep 10, 2015 1:53 pm
Did you call “wifi_set_opmode(STATION_MODE)” first ?
Here is an example of wifi_station_set_config http://bbs.espressif.com/viewtopic.php?f=31&t=228
robertfoss
Postby robertfoss » Thu Sep 10, 2015 11:04 pm
That does work better! Thank you.
It would have been nice if that was documented in the SDK or if there was a failure code describing the failure better.
blubb
Postby blubb » Fri Sep 11, 2015 1:13 am
It is documented. In the manual it says: "This API can be called only if ESP8266 station is enabled."
Of course, it would be better to be able to set the config in every mode. But I guess there are technical reasons.
