spi_flash_write and / or spi_flash_read not work above 0x80000
septijo
Postby septijo » Fri Sep 11, 2015 8:00 pm
Hi all,
I've encountered weird problem upon (erase+)write and read it back, on SPI flash above 0x80000,
no matter which option i choose when compiling :
* make COMPILE=gcc BOOT=none APP=0 SPI_SPEED=40 SPI_MODE=QIO SPI_SIZE_MAP=6
>> i flashed :
** "eagle.flash.bin" @ 0x00000
** "eagle.irom0text.bin" @ 0x40000
* make COMPILE=gcc BOOT=new APP=1 SPI_SPEED=40 SPI_MODE=QIO SPI_SIZE_MAP=6
>> i flashed :
** "boot_v1.4(b1).bin" @ 0x00000
** "upgrade\user1.4096.new.6.bin" @ 0x01000
if i (erase+)write the data to SPI Flash @ 0x3C000 (i've also tried 0x7C000), i can read it back successfully.
but when i try to (erase+)write the data @ 0x8C000, i can not read it back (the data returned is not my previously saved).
my sourcecode :
//#define PRIV_PARAM_START_SEC      0x3C // >> ok
//#define PRIV_PARAM_START_SEC      0x7C // >> ok
#define PRIV_PARAM_START_SEC      0x8C // >> fail
struct structConfigData {
  char magic[16];
  uint8_t switch1_mode;
  uint8_t switch1_timerHourOn1;
  uint8_t switch1_timerMinuteOn1;
  uint8_t switch1_timerHourOff1;
  uint8_t switch1_timerMinuteOff1;
  uint8_t switch1_timerRandomMinute1;
  uint8_t wifi_mode; // 0 = none, 1=AP, 2=Station 3=Both
  char wifi_station_SSID[32];
  char wifi_station_password[64];
  char wifi_softAP_SSID[32];
  char wifi_softAP_password[64];
  uint8 wifi_softAP_channel;
  AUTH_MODE wifi_softAP_authMode;
  uint8 wifi_softAP_SSID_hidden;
struct structConfigData npConfigData;
// save data to flash
spi_flash_erase_sector(PRIV_PARAM_START_SEC + PRIV_PARAM_SAVE);
spi_flash_write((PRIV_PARAM_START_SEC + PRIV_PARAM_SAVE) * SPI_FLASH_SEC_SIZE,
  (uint32 *) &npConfigData, sizeof(struct structConfigData));
// read it back, i can get my previously saved data, only if i set the sector below 0x80000
spi_flash_read((PRIV_PARAM_START_SEC + PRIV_PARAM_SAVE) * SPI_FLASH_SEC_SIZE,
here is my flash downlaod tools screenshoot
any advice ? anyone ?
pvvx
Re: spi_flash_write and / or spi_flash_read not work above 0x80000
Postby pvvx » Sun Sep 13, 2015 8:08 am
septijo wrote:Hi all,
extern SpiFlashChip * flashchip; // in RAM-BIOS: 0x3fffc714
uint32 save_chip_size = flashchip->chip_size;
flashchip->chip_size = 0x01000000; // Open all 16Mbytes
flashchip->chip_size = save_chip_size;
septijo
Postby septijo » Fri Sep 18, 2015 10:51 am
dear pvvx,
tried your code with no luck, fatal exception happened in this line :
the "fatal exception thingy" even happened when i just only try to peek the flashchip->chip_size using this code :
printf("flashchip->chip_size=%d\n",save_chip_size);
//flashchip->chip_size = 0x01000000; // Open all 16Mbytes
( i just only peek the var, not even alter it -- already commented the line below the printf(bla bla) )
Fatal exception (9):
epc1=0x4027200a
epc2=0x00000000
epc3=0x00000000
epcvaddr=0x001640f3
depc=0x00000000
rtn_add=0x40271fff
nb:
i use RTOS SDK v 2015-Aug-21 ( system_get_sdk_version() return "1.1.0(6009786)"), so the first time i try your code, the compiler gave me error :
error: unknown type name 'SpiFlashChip'
in order to make it compiled, i have to overwrite the spi_flash.h file at the include/espressif folder (of the RTOS SDK) with the spi_flash.h file from the NON RTOS SDK (version 2015-Aug-08).
best regards,
gustavo
Postby gustavo » Tue May 24, 2016 5:25 pm
Dear septijo,
did you find the problem with the flash?
I'm having the same issue.
Postby ESP_Faye » Fri May 27, 2016 5:08 pm
Sorry that we can not reproduce your problem.
Here is our test code
void user_init(void)
    uint32 temp[4]={0x05, 0x06, 0x07, 0x08};
    uint32 temp1[4]={0};
    spi_flash_erase_sector(0x8c);
    spi_flash_write(0x8c000, temp, sizeof(temp));
    spi_flash_read(0x8c000, temp1, sizeof(temp1));
    os_printf("read :%x, %x, %x, %x\n", temp1[0], temp1[1], temp1[2], temp1[3]);
If your problem is still unsolved, please provide your whole test project, we will help debug it.
gustavo
Postby gustavo » Mon May 30, 2016 11:15 pm
I used your code (added some more debug).
    int i = spi_flash_erase_sector(0x8c);
    printf("spi_flash_erase_sector: %d\n", i);
    int o = spi_flash_write(0x8c000, temp, sizeof(temp));
    printf("spi_flash_write: %d\n", o);
    int p = spi_flash_read(0x8c000, temp1, sizeof(temp1));
    printf("spi_flash_read: %d\n", p);
And I got the following output:
spi_flash_erase_sector: 1
spi_flash_write: 1
spi_flash_read: 1
read :0, 0, 0, 0
Which is SPI_FLASH_RESULT_ERR for all the calls.
I'm running the RTOS version of the SDK.
I also posted this as a discussion on the esp8266.com forum: http://www.esp8266.com/viewtopic.php?f=6&t=10116
My flash is marked BergMicro 25Q32ASSIG (32Mbits).
Postby ESP_Faye » Tue May 31, 2016 11:36 am
Sorry that we can not reproduce your problem. We tested the code you provided, it works fine.
Can you provide the datasheet of your flash (BergMicro 25Q32ASSIG) ?
gustavo
Postby gustavo » Tue May 31, 2016 5:38 pm
Yes.
You can find a copy in: http://www.darkwire.com.au/Downloads/BG25Q32A.pdf
I bought an ESP12E from eBay.
Postby ESP_Faye » Wed Jun 01, 2016 11:22 am
Please use the ESP Flash Download Tool to download your bin files into flash.
If your problem is still unsolved, please provide the captured picture of ESP Flash Download Tool while downloading, and your bin files, we will have a try.
gustavo
Postby gustavo » Wed Jun 01, 2016 6:02 pm
There you go.
bins.zip
(205.55 KiB) Downloaded 509 times
