Please make wifi_softap_set_config() usable in every mode
blubb
Postby blubb » Sun Sep 13, 2015 10:50 pm
During the last few days my thoughts were circling around this behavior... and I think Espressif should change wifi_softap_set_config() so that it can be used in station-only mode, too, i.e. STORING A NEW AP NAME IN THE FLASH.
Here is why:
Imagine a firmware which lets the user change the access point name (for example along with the host name). When in stationap mode this is no problem, wifi_softap_set_config() stores the new name in flash and returns true. Now, if we're in station-only mode, the new name will not be stored in flash and the function returns false.
So in order to store the new name in flash when in station-only mode we currently have two choices:
1st:
Every time we use wifi_set_opmode(2) or wifi_set_opmode(3) we need to call wifi_softap_set_config() afterwards ensuring the correct name is used.
For this to work we need to store the name in a separate config area, of course. So that it survives a reboot.
or
2nd:
Every time the user sets a new name, we need to call wifi_set_opmode(3) before wifi_softap_set_config() and restore the old mode with another wifi_set_opmode call afterwards. This, of course, will activate the ap for a short period of time even when not desired. I do not know whether there are even other side effects.
From a design perspective both choices are crude! In my opinion this is even is a bug (by design) since it needs workarounds where a clean solution would not.
blubb
Re: Please make wifi_softap_set_config() usable in every mode
Postby blubb » Mon Sep 21, 2015 5:38 pm
By the way, the same is true for wifi_station_set_config() in non-station mode!
Making both functions callable in every mode would lead to cleaner code.
