When composing a new topic or a reply to an existing topic there is a list of BBCode "buttons" above the edit window which, when clicked, insert some BBCode into the edit box. On the far right side are "hr", "table", "td" and "tr" but if you insert those in the edit window a preview doesn't expand them properly.
To observe, click the "table button", place the caret between the closing square bracket and the opening square bracket, click "tr", again place the caret between the inner close/open square brackets, click "td", again place the caret between the inner close/open square bracket and then type some text. Clicking "preview" should yield a table but it doesn't.
Table BBCode doesn't work
Re: Table BBCode doesn't work
Postby Admin » Wed Sep 23, 2015 9:58 am
Sorry, please try using
instead.
