[SOLVED]New router does not work with RTOS sdk
Postby masacate » Wed Sep 16, 2015 5:12 pm
thanks in advance
masacate
Re: New router does not work with RTOS sdk
Postby ESP_Faye » Thu Sep 17, 2015 5:25 pm
Here is an example of connecting to router http://bbs.espressif.com/viewtopic.php?f=31&t=228
Please notice to set "stationConf.bssid_set = 0;"
If your problem is still unsolved, you could provide your test code and UART logs, we will help debugging it.
Postby masacate » Sat Sep 19, 2015 3:21 am
It happens even with the simple example program without any special code in the tasks:
* Copyright 2013-2014 Espressif Systems (Wuxi)
* FileName: user_main.c
* Description: entry file of user application
* Modification history:
* 2014/12/1, v1.0 create this file.
#include "esp_common.h"
#include "freertos/task.h"
#include "lwip/sockets.h"
#include "lwip/dns.h"
#include "lwip/netdb.h"
void task2(void *pvParameters)
printf("Hello, welcome to task2!\r\n");
while (1) {
void task3(void *pvParameters)
printf("Hello, welcome to task3!\r\n");
while (1) {
* FunctionName : user_init
* Parameters : none
* Returns : none
void user_init(void)
/* need to set opmode before you set config */
struct station_config *config = (struct station_config *)zalloc(sizeof(struct station_config));
sprintf(config->ssid, "myWIFI");
sprintf(config->password, "myPassword");
//need not mac address
config->bssid_set = 0;
/* need to sure that you are in station mode first,
* otherwise it will be failed. */
wifi_station_set_config(config);
free(config);
xTaskCreate(task2, "tsk2", 256, NULL, 2, NULL);
xTaskCreate(task3, "tsk3", 256, NULL, 2, NULL);
My debug log says that is continuosly trying to reconnect because of some problem:
load 0x40100000, len 24728, room 16
tail 8
chksum 0x5c
load 0x3ffe8000, len 1156, room 0
tail 4
chksum 0xa1
load 0x3ffe8490, len 640, room 4
tail 12
chksum 0x4e
csum 0x4e
R Î"àŒ!•`1hM"üÚpp_task_hdl : 3ffef748, prio:13, stack:512
pm_task_hdl : 3fff0028, prio:1, stack:176
ApiMsgMutex created
tcpip_task_hdl : 3fff0440, prio:10,stack:512
wdt_task : 3fff0d00, prio:14, stack:176
idle_task_hdl : 3fff1870
tim_task_hdl : 3fff1c68
xPortStartScheduler
frc2_timer_task_hdl:3fff2578, prio:12, stack:512
OS SDK ver: 1.2.0(b900bd2) compiled @ Aug 28 2015 17:18:41
phy ver: 356, pp ver: 9.0
SDK version:1.2.0(b900bd2)
mode : sta(18:fe:34:9c:68:ea) + softAP(1a:fe:34:9c:68:ea)
add if0
add if1
bcn 100
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 4
cnt
ERRRRRR:256,137,137!!!!state: 5 -> 2 (ea0)
rm 0
reconnect
state: 2 -> 0 (0)
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 4
cnt
rm 0
reconnect
state: 2 -> 0 (0)
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 4
cnt
rm 0
reconnect
state: 2 -> 0 (0)
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 4
cnt
rm 0
reconnect
state: 2 -> 0 (0)
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 4
cnt
rm 0
reconnect
state: 2 -> 0 (0)
please some advice?
Postby eswarams » Mon Oct 26, 2015 12:50 pm
With the recent esp_iot_rtos master 1.2.0 the wifi station mode with WPA is broken. I will post a issue on the git now. For now you can set your wireless security to wep and use the chip
Re: [SOLVED]New router does not work with RTOS sdk
Postby kolban » Mon Nov 09, 2015 2:10 pm
while(1) {
tight loops. Surely if one of those tasks gets control it will never release it since I understand that the FreeRTOS is not preemptive ...?
Postby masacate » Fri Nov 13, 2015 4:00 pm
