[SDK Release] ESP8266_NONOS_SDK_V1.4.0_15_09_18
Admin
Site Admin
Postby Admin » Fri Sep 18, 2015 10:59 pm
请勿使用本旧版本 SDK,建议使用 最新发布 SDK。
ESP8266_NONOS_SDK_V1.4.0_15_09_18 Release
Important Links
Here are the links for this SDK release (version ESP8266_NONOS_SDK_V1.4.0_15_09_18):
  1. Bug Bounty Program
Release Notes
  1. Espconn may fail to download big chunk of data(FOTA).
  2. Invalid TCP data sent issue.
  3. Fatal exceptions occur when change WiFi mode in WiFi scan callback.
  4. WiFi compatibility problem of special network card.
  5. Deep sleep may appear high current under certain circumstances.
Optimization:
  1. Add a new method to check memory leaks (API : system_show_malloc).
  2. Add print information when exception happens.
  3. Resolve the problem of os_timer_disarm.
  4. Optimize DHCP server, add API to set up the lease time of DHCP server. More details are in the “Added APIs”.
  5. Add event “EVENT_STAMODE_DHCP_TIMEOUT” for the DHCP timeout handling mechanism.
  6. Optimize handling of the reception of data and ZWP message.
  7. Add new APIs to support SSL bidirectional authentication. More details are in the “Added APIs”.
  8. Add new APIs to set up SSL certificates and encryption keys. espconn_secure_set_default_certificate & espconn_secure_set_default_private_key should be called to set SSL certificate and secure key, if ESP8266 runs as SSL server. More details are in the “Added APIs”.
  9. Optimize the process of FOTA (firmware upgrade through Wi-Fi). Please update the \esp_iot_sdk\makefile and \esp_iot_sdk\app\gen_misc.
  10. Optimize mDNS, and resolve the problem that in certain case the ESP8266 softAP can not work in the sta+AP mode.
  11. Release mesh as a lib in the esp_iot_sdk, and do not provide SDK of the mesh version any more.
  12. Optimize mesh’s handling of UDP packets.
  13. Optimize checking of the validity of the mesh API’s parameters.
  14. Add an API to set up the largest hop of mesh. For detailed information, go to mesh instructions.
  15. Optimize the process of powering up and booting to shorten booting time by 20 ms.
  16. Optimize the function of automatic frequency offset calibration.
  17. Optimize the function of sniffer.
  18. Strengthen reliability of the checking of beacon timeout.
  19. Optimize Wi-Fi event mechanism, and add event “ EVENT_SOFTAPMODE_PROBEREQRECVED”, and reason for a failed connection.
  20. Optimize Wi-Fi callback function and strengthen reliability of the software.
  21. Add the function of data transferring between stations in the soft-AP mode.
  22. Update SmartConfig to the version of 2.5.1.
  23. Update esp_init_data_default.bin. Please use the newest esp_init_data_default.bin when burning.
  24. Modify the espconn pointer in the receive callback of UDP. Parameters remote_ip and remote_port in it are the remote IP and port set by espconn_create. If users want to obtain IP and ports of the current sender, please call espconn_get_connection_info to get relevant information.
Added APIs:
  1. System API
    system_show_malloc : for checking memory leak, to print the memory usage.
  2. DHCP server lease time related APIs
    wifi_softap_set_dhcps_lease_time:set ESP8266 softAP DHCP server lease time.
    wifi_softap_get_dhcps_lease_time:check ESP8266 softAP DHCP server lease time.
    wifi_softap_reset_dhcps_lease_time:reset ESP8266 softAP DHCP server lease time which is 120 minutes by default.
  3. wifi_station_dhcpc_set_maxtry:set the maximum number that ESP8266 station DHCP client will try to reconnect to the AP.
  4. Force sleep APIs
    wifi_fpm_open:enable force sleep function.
    wifi_fpm_close:disable force sleep function.
    wifi_fpm_do_sleep:force ESP8266 enter sleep mode.
    wifi_fpm_do_wakeup:wake ESP8266 up from force sleep.
    wifi_fpm_set_sleep_type:set sleep type of force sleep function.
    wifi_fpm_get_sleep_type:get sleep type of force sleep function.
  5. Send packet freedom APIs (to send user-define 802.11 packets)
    wifi_register_send_pkt_freedom_cb:register a callback for sending user-define 802.11 packets.
    wifi_unregister_send_pkt_freedom_cb:unregister the callback for sending user-define 802.11 packets.
    wifi_send_pkt_freedom:send user-define 802.11 packet.
  6. RFID LOCP APIs
    wifi_rfid_locp_recv_open:enable RFID LOCP to receive WDS packets.
    wifi_rfid_locp_recv_close:disable RFID LOCP.
    wifi_register_rfid_locp_recv_cb:register a callback of receiving WDS packets.
    wifi_unregister_rfid_locp_recv_cb:unregister the callback of receiving WDS packets.
  7. Rate Control APIs
    wifi_set_user_fixed_rate:set the fixed rate and mask of sending data from ESP8266
    wifi_get_user_fixed_rate:check the fixed rate and mask of ESP8266
    wifi_set_user_sup_rate:set the rate range supported by ESP8266 to limit the rate of sending packets from other devices.
    wifi_set_user_rate_limit:limit the rate of sending data from ESP8266.
    wifi_set_user_limit_rate_mask:set the interfaces of ESP8266 whose rate of sending packets is limited by wifi_set_user_rate_limit.
    wifi_get_user_limit_rate_mask:get the interfaces of ESP8266 whose rate of sending packets is limited by wifi_set_user_rate_limit.
  8. Espconn APIs
    espconn_sendto:send UDP data.
    espconn_secure_cert_req_enable:enable certificates verification function when ESP8266 runs as SSL client.
    espconn_secure_cert_req_disable:disable certificates verification function when ESP8266 runs as SSL client.
    espconn_secure_set_default_certificate:set the certificate when ESP8266 runs as SSL server.
    espconn_secure_set_default_private_key:set the encryption key when ESP8266 runs as SSL server.
  9. SmartConfig API
    smartconfig_set_type: set the protocol type of SmartConfig.
Have fun!
ESP8266_NONOS_SDK_V1.4.0_15_09_18发布
相关下载
    以下是最新SDK的相关下载链接 (版本 ESP8266_NONOS_SDK_V1.4.0_15_09_18):
  1. 您可以继续参与 Bug Bounty 计划。
发布说明
修正问题(符合乐鑫 Bug 赏金计划):
  1. OTA 下载文件可能失败。
  2. TCP 传输时可能出现无效数据。
  3. 在 scan 完成的回调函数中切换模式,可能导致系统崩溃。
  4. 特殊网卡的兼容性问题。
  5. deep sleep 在某些情况下可能出现电流较高的问题。
优化:
  1. 新增查证内存泄露问题的方法(system_show_malloc)。
  2. 增加 exception 发生时的打印信息。
  3. 修正关闭软件定时器有时出现异常的问题。
  4. 优化 DHCP server,增加设置 DHCP server 租约时间的软件接口,详见新增 API 说明。
  5. 增加 DHCP 超时处理机制,增加事件 EVENT_STAMODE_DHCP_TIMEOUT。
  6. 优化数据接收处理和 ZWP 报文处理。
  7. 新增接口支持 SSL 双向认证,详见新增 API 说明。
  8. 新增接口设置 SSL 证书和密钥,ESP8266 作为 SSL server 时,必须调用 espconn_secure_set_default_certificate 和
    espconn_secure_set_default_private_key 设置证书及密钥
    ,详见新增 API 说明。
  9. 优化 OTA 升级流程。请注意更新 \esp_iot_sdk\makefile 和 \esp_iot_sdk\app\gen_misc。
  10. 优化 mDNS,修复在 sta+AP 模式下,softAP 接口工作异常的问题。
  11. mesh 作为 esp_iot_sdk 中的一个库文件发布,不再单独提供 mesh 版本的 SDK。
  12. 优化 mesh 对 UDP 包的处理。
  13. 优化 mesh API 的参数合法性检验。
  14. 增加设置 mesh 最大 hop 的 API,详见 mesh 说明文档。
  15. 优化上电启动流程,缩短上电启动耗时 20 ms。
  16. 优化自动频偏校准功能。
  17. 优化 sniffer 功能。
  18. 增强 beacon timeout 检测的可靠性。
  19. 优化 Wi-Fi event 机制,新增事件 EVENT_SOFTAPMODE_PROBEREQRECVED,以及连接失败原因。
  20. 优化 Wi-Fi 回调函数,增强软件的可靠性。
  21. 新增支持 soft-AP 模式下,station 之间的数据转发。
  22. 更新 SmartConfig 至版本 2.5.1。
  23. 更新了 esp_init_data_default.bin,烧录时,请使用新版本的 esp_init_data_default.bin。
  24. 修改 UDP 收包回调中的 espconn 指针,其中的 remote_ip 和 remote_port 参数为最初调用 espconn_create 创建的远端 IP 和端口,如需获取当前收到包的发包方 IP 和端口,请调用 espconn_get_connection_info 查询。
新增 APIs:
  1. System API
    system_show_malloc : 用于查证内存泄露问题。
  2. DHCP server 租约时间 APIs
    wifi_softap_set_dhcps_lease_time:设置 ESP8266 softAP DHCP server 租约时间。
    wifi_softap_get_dhcps_lease_time:查询 ESP8266 softAP DHCP server 租约时间。
    wifi_softap_reset_dhcps_lease_time:复位 ESP8266 softAP DHCP server 租约时间,恢复为默认值 120 分钟。
  3. wifi_station_dhcpc_set_maxtry:设置 DHCP client 最大重连次数。
  4. 强制休眠 APIs
    wifi_fpm_open:开启强制休眠功能。
    wifi_fpm_close:关闭强制休眠功能。
    wifi_fpm_do_sleep:进入强制休眠。
    wifi_fpm_do_wakeup:从强制休眠中唤醒。
    wifi_fpm_set_sleep_type:设置强制休眠的休眠类型。
    wifi_fpm_get_sleep_type:查询强制休眠的休眠类型。
  5. freedom 发包 APIs,用于发送用户自定义 802.11 的包
    wifi_register_send_pkt_freedom_cb:注册 freedom 发包的回调函数。
    wifi_unregister_send_pkt_freedom_cb:注销 freedom 发包的回调函数。
    wifi_send_pkt_freedom:freedom 发包函数。
  6. RFID LOCP APIs,用于 WDS 收包。
    wifi_rfid_locp_recv_open:开启 RFID LOCP 功能,用于接收 WDS 包。
    wifi_rfid_locp_recv_close:关闭 RFID LOCP 功能。
    wifi_register_rfid_locp_recv_cb:注册 RFID LOCP 收包回调函数。
    wifi_unregister_rfid_locp_recv_cb:注销 RFID LOCP 收包回调函数。
    wifi_set_user_fixed_rate:设置发包固定速率。
    wifi_get_user_fixed_rate:查询发包固定速率。
    wifi_set_user_sup_rate:设置 ESP8266 支持速率的范围,用于限制通信对方的发包速率。
    wifi_set_user_rate_limit:设置限制 ESP8266 发包速率范围。
    wifi_set_user_limit_rate_mask:设置发包速率受限制的 ESP8266 接口。
    wifi_get_user_limit_rate_mask:查询发包速率受限制的 ESP8266 接口。
  8. Espconn APIs
    espconn_sendto:UDP 发包函数。
    espconn_secure_cert_req_enable:使能 ESP8266 作为 SSL client 时的证书认证功能。
    espconn_secure_cert_req_disable:关闭 ESP8266 作为 SSL client 时的证书认证功能。
    espconn_secure_set_default_certificate:设置 ESP8266 作为 SSL server 时的证书。
    espconn_secure_set_default_private_key:设置 ESP8266 作为 SSL server 时的密钥。
  9. SmartConfig API
    smartconfig_set_type: 设置 SmartConfig 的协议类型。
感谢您对 ESP8266 的关注!
esp_iot_sdk_v1.4.0_15_09_18.zip
(2.06 MiB) Downloaded 28290 times
