Migrating applications from SDK 1.3 to SDK 1.4
Postby kolban » Tue Sep 29, 2015 10:48 pm
If I switch the same code back to SDK 1.3 and clean build, all now works again.
So either there has been a regression from SDK 1.3 to SDK 1.4 or (which I believe is more likely) there has been some new set of changes that I now need to accommodate in the app to allow WiFi connections to work.
Has anyone found any obvious changes to their apps logic, flow or design that were needed for a 1.4 migration? Does an ESP have to be somehow "prepped" for SDK 1.4?
Neil
Re: Migrating applications from SDK 1.3 to SDK 1.4
Postby masacate » Wed Sep 30, 2015 12:41 am
I have also similar problem, I had to go back from sdk 1.4 to 1.3, my program that worked perfectly with the 1.3 version is continually trying to connect because of errors with the 1.4 version
masacate
Postby tve » Wed Sep 30, 2015 11:48 am
In the firmware that connects well, a scan looks like this:
15131> Wifi connect failed. Going into STA+AP mode..
15132> mode : sta(18:fe:34:a6:e8:8f) + softAP(1a:fe:34:a6:e8:8f)
15137> add if0
166158> scandone
166158> bss1: tve-home (-66)
166159> bss2: oc1 (-48)In the firmware that doesn't connect, a scan looks like this:
add if0
scandone
ssid: oc1
What could be different? I see that on one case the SDK prints "bss1:" in the other "ssid:"
Postby tve » Wed Sep 30, 2015 12:52 pm
Postby Triacon » Wed Sep 30, 2015 10:45 pm
viewtopic.php?f=66&t=697
Regarding bssid) vs ssid that's probably because what it listed is actually ssids and not bss(id).
BSSID is the (unique)MAC of the AP found, multiple APs can have the same SSID
Postby masacate » Wed Nov 04, 2015 3:27 pm
thanks
