SSL Connect.
SSL Connect.
Postby younger » Sun Jan 04, 2015 10:59 am
Hi ,
I have connected to a ssl server, but it is always failed. The ip and port is 111.206.227.37:2001.
I want to have SSL_connect succeed even if verifying the server fails and reducing security, may like "SSL_CTX_set_verify(ctx, SSL_VERIFY_NONE, 0)" in cyassl.
How to do like this in ESP8266 sdk ?
Re: SSL Connect.
Postby younger » Sun Jan 04, 2015 2:09 pm
Espressif_Faye wrote:It seems that SSL certificate of your server is not correct, so the connecting fails.
What do you want to do?
The server is JD-Cloud server ,I just use ESP8266 to connect it,but it is fail.
But another code in cyassl "CyaSSL_CTX_set_verify(ctx, SSL_VERIFY_NONE, 0)" will be OK, and the SSL_VERIFY_NONE seems ignored the verify result to ensure the connect suuceed.
In ESP8266 use axtls for ssl, how can I achieve it for SSL_VERIFY_NONE? Maybe I must transplant cyassl instead of axtls in ESP8266?
Re: SSL Connect.
Postby younger » Mon Jan 05, 2015 10:20 am
Espressif_Faye wrote:Please try this:
Hi Espressif_Faye,
Does it work after modify this code?
I have tried this but still fail.
ip:192.168.1.126,mask:255.255.255.0,gw:192.168.1.1
user_esp_platform_dns_found 111.206.227.37
user_esp_platform_connect
espconn_ssl_connect 0x3fff5a00 0x3fff59a0 0x00006338 1073699992
client handshake start.
espconn_ssl_client ssl_ctx 0x3fff5cf0
send_raw_packet pkt_size 56
send_raw_packet Length 56
espconn_ssl_csent 0x3fff5a00 0x3fff5dbc 56
espconn_ssl_crecv 409 0x3fff5d90 0x3fff5978
do_clnt_handshake: 107 2
do_clnt_handshake: 107 11
Error: Invalid X509 ASN.1 file (X509 not ok)
send_raw_packet pkt_size 7
send_raw_packet Length 7
client handshake failed
espconn_ssl_cclose 0
espconn_ssl_cclose_cb 10 0
user_esp_platform_discon_cb
user_esp_platform_reconnectRe: SSL Connect.
Postby ESP_Faye » Mon Jan 05, 2015 2:04 pm
Sorry.. Please change it back..
int ICACHE_FLASH_ATTR asn1_validity(const uint8_t *cert, int *offset, X509_CTX *x509_ctx)
return (asn1_next_obj(cert, offset, ASN1_SEQUENCE) < 0 ||
asn1_get_utc_time(cert, offset, &x509_ctx->not_before) ||
asn1_get_utc_time(cert, offset, &x509_ctx->not_after));
And try this..
- Attachments
- ssl_modify_2.png (16.99 KiB) Viewed 11793 times
Re: SSL Connect.
Postby younger » Mon Jan 05, 2015 2:15 pm
Espressif_Faye wrote::o![]()
And try this..
