I have a problem with my ESP01 and AT v0.50.
I can flash with AT V0.50, send AT commands etc, but if I change the baudrate to 19200 and send AT+RST or power off/on the ESP, the baudrate return to 115200
Flashing:
Info:
AT+GMR
AT version:0.50.0.0(Sep 18 2015 20:55:38)
SDK version:1.4.0
compile time:Sep 18 2015 21:32:07
OKI do not have this problem with a 8Mbit version.
The eagle.flash.bin / eagle.irom0text.bin and blank.bin are in correct "position" ? (0xYYYYYY)
(I have tested with several esp, and the result is the same...)
Thanks for your help
