Help on OTA failure SDK 1.4.0
agudallago
Postby agudallago » Thu Oct 15, 2015 12:49 am
Hello guys,
This is my first post here so I apologize in advance if this is not the correct board or something like that.
I have spent two days trying to update OTA the firmware on the ESP_TEST board that is mentioned here: (http://tech.scargill.net/esp8266-test-board/) . It has a 2MB spi flash memory.
My code is a modified version of a sample code I got from the web and seems to be ok. The code is the following:
#include "ets_sys.h"
#include "osapi.h"
#include "user_interface.h"
#include "smartconfig.h"
#include "upgrade.h"
#include "os_type.h"
#include "mem.h"
#include "gpio.h"
#include "espconn.h"
static void ICACHE_FLASH_ATTR ota_finished_callback(void *arg)
   struct upgrade_server_info *update = arg;
   if (update->upgrade_flag == true)
      os_printf("[OTA]success; rebooting!\n");
      system_upgrade_reboot();
   else
      os_printf("[OTA]failed!\n");
   os_free(update->pespconn);
   os_free(update->url);
   os_free(update);
#define pheadbuffer "Connection: keep-alive\r\n\
Cache-Control: no-cache\r\n\
\r\n"
static void ICACHE_FLASH_ATTR handleUpgrade(uint8_t serverVersion, const char *server_ip, uint16_t port, const char *path)
   const char* file;
   uint8_t userBin = system_upgrade_userbin_check();
   switch (userBin)
      case UPGRADE_FW_BIN1: file = "user2.2048.new.3.bin"; break;
      case UPGRADE_FW_BIN2: file = "user1.2048.new.3.bin"; break;
      default:
      os_printf("[OTA]Invalid userbin number!\n");
      return;
   uint16_t version=1;
   if (serverVersion <= version)
      os_printf("[OTA]No update. Server version:%d, local version %d\n", serverVersion, version);
      return;
   os_printf("[OTA]Upgrade available version: %d\n", serverVersion);
   struct upgrade_server_info* update = (struct upgrade_server_info *)os_zalloc(sizeof(struct upgrade_server_info));
   update->pespconn = (struct espconn *)os_zalloc(sizeof(struct espconn));
   os_memcpy(update->ip, server_ip, 4);
   update->port = port;
   os_printf("[OTA]Server "IPSTR":%d. Path: %s%s\n", IP2STR(update->ip), update->port, path, file);
   update->check_cb = ota_finished_callback;
   update->check_times = 10000;
   update->url = (uint8 *)os_zalloc(512);
   os_sprintf((char*)update->url,
   "GET %s%s HTTP/1.1\r\n"
   "Host: "IPSTR":%d\r\n"
   pheadbuffer,
   path, file, IP2STR(update->ip), update->port);
    if (system_upgrade_start(update) == false) {
      os_printf("[OTA]Could not start upgrade\n");
      os_free(update);
   else
      os_printf("[OTA]Upgrading...\n");
void user_rf_pre_init(void)
void wifi_handle_event_cb(System_Event_t *evt)
    os_printf("event %x\n", evt->event);
    switch (evt->event) {
        case EVENT_STAMODE_CONNECTED:
            os_printf("connected to ssid %s, channel %d\n",
            evt->event_info.connected.ssid,
            evt->event_info.connected.channel);
            break;
        case EVENT_STAMODE_DISCONNECTED:
            os_printf("disconnected from ssid %s, reason %d\n",
            evt->event_info.disconnected.ssid,
            evt->event_info.disconnected.reason);
            break;
        case EVENT_STAMODE_AUTHMODE_CHANGE:
            os_printf("mode: %d -> %d\n",
            evt->event_info.auth_change.old_mode,
            evt->event_info.auth_change.new_mode);
            break;
        case EVENT_STAMODE_GOT_IP:
            os_printf("ip:" IPSTR ",mask:" IPSTR ",gw:" IPSTR,
            IP2STR(&evt->event_info.got_ip.ip),
            IP2STR(&evt->event_info.got_ip.mask),
            IP2STR(&evt->event_info.got_ip.gw));
            os_printf("\n");
               char ip[4] = {192, 168, 100, 15};
            os_printf("LLAMANDO!!\n");
            handleUpgrade(2, ip, 8000, "/upgrade/");
            break;
        case EVENT_SOFTAPMODE_STACONNECTED:
            os_printf("station: " MACSTR "join, AID = %d\n",
            MAC2STR(evt->event_info.sta_connected.mac),
            evt->event_info.sta_connected.aid);
            break;
        case EVENT_SOFTAPMODE_STADISCONNECTED:
            os_sprintf("station: " MACSTR "leave, AID = %d\n",
            MAC2STR(evt->event_info.sta_disconnected.mac),
            evt->event_info.sta_disconnected.aid);
            break;
        default:
        break;
user_set_station_config(void)
   char ssid[32] = "MYSSID";
   char password[64] = "MYPASS";
   stationConf.bssid_set = 0; //need not check MAC address of AP
void user_init(void)
    os_printf("ASDF\n");
   os_printf("HOLASDK version:%s\n\n", system_get_sdk_version());
    wifi_set_event_handler_cb(wifi_handle_event_cb);
   ///smartconfig_set_type(SC_TYPE_ESPTOUCH); //SC_TYPE_ESPTOUCH,SC_TYPE_AIRKISS,SC_TYPE_ESPTOUCH_AIRKISS
    //smartconfig_start(smartconfig_done);
   user_set_station_config();
I am using the 1.4.0 IOT SDK with bootloader 1.4(b1) and flashing to the following locations:
boot_v1.4(b1).bin to 0x00000
esp_init_data_default.bin to 0x1fc000
blank.bin to 0x1fe000
user1.2048.new.3.bin 0x01000
user2.2048.new.3.bin 0x81000
(NOTE> I tried flashing the 1MB flash version firmwares too, but same result...)
My log was:
 ets Jan  8 2013,rst cause:1, boot mode:(3,2)
tail 4
chksum 0x89
tail 4
chksum 0xe8
tail 8
chksum 0xc0
csum 0xc0
2nd boot version : 1.4(b1)
  SPI Speed      : 40MHz
  SPI Mode       : QIO
jump to run user1 @ 1000
SDK ver: 1.4.0 compiled @ Sep 18 2015 20:55:49
phy ver: 484, pp ver: 9.5
ASDF
HOLASDK version:1.4.0
mode : sta(18:fe:34:a1:32:8a)
add if0
f r0, scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 3
cnt
connected with Belkin_Enhanced_Wireless_E53473, channel 1
dhcp client start...
event 0
connected to ssid Belkin_Enhanced_Wireless_E53473, channel 1
ip:192.168.100.39,mask:255.255.255.0,gw:192.168.100.1
event 3
LLAMANDO!!
[OTA]Upgrade available version: 2
[OTA]Server 192.168.100.15:8000. Path: /upgrade/user2.2048.new.3.bin
upgrade_connect
[OTA]Upgrading...
upgrade_connect_cb
GET /upgrade/user2.2048.new.3.bin HTTP/1.1
Host: 192.168.100.15:8000
HEAD /upgrade/user2.2048.new.3.bin HTTP/1.1
Connection: close
pusrdata = HTTP/1.0 200 OK
server do not support HEAD method now send GET message
pusrdata = Server: SimpleHTTP/0.6 Python/2.7.8
Date: Wed, 14 Oct 2015 16:11:33 GMT
Content-type: application/octet-stream
Content-Length: 218100
Last-Modified: Wed, 14 Oct 2015 16:07:56 GMT
Access-Control-Allow-Origin: *
sumlength = 218100
sec_block 54
......................................................upgrade_get_sum_disconcb
erase sector=129 ok
erase sector=130 ok
erase sector=131 ok
erase sector=132 ok
erase sector=133 ok
erase sector=134 ok
erase sector=135 ok
erase sector=136 ok
erase sector=137 ok
erase sector=138 ok
erase sector=139 ok
erase sector=140 ok
erase sector=141 ok
erase sector=142 ok
erase sector=143 ok
erase sector=144 ok
erase sector=145 ok
erase sector=146 ok
erase sector=147 ok
erase sector=148 ok
erase sector=149 ok
erase sector=150 ok
erase sector=151 ok
erase sector=152 ok
erase sector=153 ok
erase sector=154 ok
erase sector=155 ok
erase sector=156 ok
erase sector=157 ok
erase sector=158 ok
erase sector=159 ok
erase sector=160 ok
erase sector=161 ok
erase sector=162 ok
erase sector=163 ok
erase sector=164 ok
erase sector=165 ok
erase sector=166 ok
erase sector=167 ok
erase sector=168 ok
erase sector=169 ok
erase sector=170 ok
erase sector=171 ok
erase sector=172 ok
erase sector=173 ok
erase sector=174 ok
erase sector=175 ok
erase sector=176 ok
erase sector=177 ok
erase sector=178 ok
erase sector=179 ok
erase sector=180 ok
erase sector=181 ok
erase sector=182 ok
ALL=54 sectors erase ok!
upgrade_connect_cb
Connection: close
totallen = 17
totallen = 1477
totallen = 2937
totallen = 4397
totallen = 5857
totallen = 7317
totallen = 8777
totallen = 10237
totallen = 11697
totallen = 13157
totallen = 14617
totallen = 16077
totallen = 17537
totallen = 18997
totallen = 20457
totallen = 21917
totallen = 23377
totallen = 24837
totallen = 26297
totallen = 27757
totallen = 29217
totallen = 30677
totallen = 32137
totallen = 33597
totallen = 35057
totallen = 36517
totallen = 37977
totallen = 39437
totallen = 40897
totallen = 42357
totallen = 43817
totallen = 45277
totallen = 46737
totallen = 48197
totallen = 49657
totallen = 51117
totallen = 52577
totallen = 54037
totallen = 55497
totallen = 56957
totallen = 58417
totallen = 59877
totallen = 61337
totallen = 62797
totallen = 64257
totallen = 65717
totallen = 67177
totallen = 68637
totallen = 70097
totallen = 71557
totallen = 73017
totallen = 74477
totallen = 75937
totallen = 77397
totallen = 78857
totallen = 80317
totallen = 81777
totallen = 83237
totallen = 84697
totallen = 86157
totallen = 87617
totallen = 89077
totallen = 90537
totallen = 91997
totallen = 93457
totallen = 94917
totallen = 96377
totallen = 97837
totallen = 99297
totallen = 100757
totallen = 102217
totallen = 103677
totallen = 105137
totallen = 106597
totallen = 108057
totallen = 109517
totallen = 110977
totallen = 112437
totallen = 113897
totallen = 115357
totallen = 116817
totallen = 118277
totallen = 119737
totallen = 121197
totallen = 122657
totallen = 124117
totallen = 125577
totallen = 127037
totallen = 128497
totallen = 129957
totallen = 131417
totallen = 132877
totallen = 134337
totallen = 135797
totallen = 137257
totallen = 138717
totallen = 140177
totallen = 141637
totallen = 143097
totallen = 144557
totallen = 146017
totallen = 147477
totallen = 148937
totallen = 150397
totallen = 151857
totallen = 153317
totallen = 154777
totallen = 156237
totallen = 157697
totallen = 159157
totallen = 160617
totallen = 162077
totallen = 163537
totallen = 164997
totallen = 166457
totallen = 167917
totallen = 169377
totallen = 170837
totallen = 172297
totallen = 173757
totallen = 175217
totallen = 176677
totallen = 178137
totallen = 179597
totallen = 181057
totallen = 182517
totallen = 183977
totallen = 185437
totallen = 186897
totallen = 188357
totallen = 189817
totallen = 191277
totallen = 192737
totallen = 194197
totallen = 195657
totallen = 197117
totallen = 198577
totallen = 200037
totallen = 201497
totallen = 202957
totallen = 204417
totallen = 205877
totallen = 207337
totallen = 208797
totallen = 210257
totallen = 211717
totallen = 213177
totallen = 214637
totallen = 216097
totallen = 217557
totallen = 218335
pm open phy_2,type:2 0 0
upgrade_check
[OTA]failed!
I am using the ESP FLASH DOWNLOAD TOOL V1.2.
I thank you in advance for any help or input you could give on this. It has been really frustrating and don't know what else to do.
Re: Help on OTA failure SDK 1.4.0
Postby ESP_Faye » Fri Oct 16, 2015 10:11 am
Documentation about OTA :http://bbs.espressif.com/viewtopic.php?f=51&t=413
"update->check_times = 10000;" is the timeout which means that if the OTA does not finish in 10000 ms, it failed.
You can enlarge the value of "update->check_times", or use a 4G mobile phone as AP to OTA.
cmo
Postby cmo » Tue Feb 09, 2016 9:18 am
I'm having a similar problem. I can get it to upgrade once, but after that it corrupt on the second pass.
I'm using sdk 1.4.1_15_10_27
Here's my code (about the same as the example above):
#include <ets_sys.h>
#include <osapi.h>
#include <os_type.h>
#include <mem.h>
#include <espconn.h>
#include <upgrade.h>
#include "ota.h"
#include "gpio.h"
   else
   os_free(update);
\r\n"
void ICACHE_FLASH_ATTR handleUpgrade(char *server_ip, int port, char *path){
//static void ICACHE_FLASH_ATTR handleUpgrade(const char *server_ip, uint16_t port, const char *path)
   const char* file;
   switch (userBin)
      case UPGRADE_FW_BIN1: file = "user2.4096.new.4.bin"; break;
      case UPGRADE_FW_BIN2: file = "user1.4096.new.4.bin"; break;
      default:
      return;
   os_printf("\n\nUser bin #: %d\n\n\n",userBin);
   //uint16_t version=1;
   //if (serverVersion <= version)
   //   os_printf("[OTA]No update. Server version:%d, local version %d\n", serverVersion, version);
   //   return;
   //os_printf("[OTA]Upgrade available version: %d\n", serverVersion);
   update->check_times = 100000;
   pheadbuffer,
      os_free(update);
   else
I flashed the device with:
/opt/Expressif/ESP8266_SDK/project_upgrade_demo$ sudo /opt/esp-open-sdk/esptool/esptool.py --port /dev/ttyUSB0  write_flash -fs 32m 0x00000 $FPATH/boot_v1.4b1.bin 0x01000 $FPATH/upgrade/user1.4096.new.4.bin 0x3FC000 $FPATH/esp_init_data_default.bin 0x3FE000 $FPATH/blank.bin
Here's the first good response:
[OTA]Server 192.168.1.54:80. Path: /user2.4096.new.4.bin
upgrade_connect 49000
[OTA]Upgrading...
upgrade_connect_cb
GET /user2.4096.new.4.bin HTTP/1.1
Host: 192.168.1.54:80
HEAD /user2.4096.new.4.bin HTTP/1.1
Connection: close
pusrdata = HTTP/1.1 200 OK
Content-Length: 218820
Last-Modified: Tue, 09 Feb 2016 01:03:17 GMT
Accept-Ranges: bytes
ETag: "e1655da9d562d11:0"
Server: Microsoft-IIS/10.0
Date: Tue, 09 Feb 2016 01:06:03 GMT
Connection: close
sumlength = 218820
sec_block 54
......................................................upgrade_get_sum_disconcb 46680
erase sector=129 ok
erase sector=130 ok
erase sector=131 ok
erase sector=132 ok
erase sector=133 ok
erase sector=134 ok
erase sector=135 ok
erase sector=136 ok
erase sector=137 ok
erase sector=138 ok
erase sector=139 ok
erase sector=140 ok
erase sector=141 ok
erase sector=142 ok
erase sector=143 ok
erase sector=144 ok
erase sector=145 ok
erase sector=146 ok
erase sector=147 ok
erase sector=148 ok
erase sector=149 ok
erase sector=150 ok
erase sector=151 ok
erase sector=152 ok
erase sector=153 ok
erase sector=154 ok
erase sector=155 ok
erase sector=156 ok
erase sector=157 ok
erase sector=158 ok
erase sector=159 ok
erase sector=160 ok
erase sector=161 ok
erase sector=162 ok
erase sector=163 ok
erase sector=164 ok
erase sector=165 ok
erase sector=166 ok
erase sector=167 ok
erase sector=168 ok
erase sector=169 ok
erase sector=170 ok
erase sector=171 ok
erase sector=172 ok
erase sector=173 ok
erase sector=174 ok
erase sector=175 ok
erase sector=176 ok
erase sector=177 ok
pm open,type:2 0
erase sector=178 ok
erase sector=179 ok
erase sector=180 ok
erase sector=181 ok
erase sector=182 ok
upgrade_connect_cb
Connection: close
sumlength = 218820
upgrade file download start.
totallen = 2677
totallen = 4137
totallen = 5597
totallen = 7057
totallen = 8517
totallen = 9977
totallen = 11437
totallen = 12897
totallen = 14357
totallen = 15817
totallen = 17277
totallen = 18737
totallen = 20197
totallen = 21657
totallen = 23117
totallen = 24577
totallen = 26037
totallen = 27497
totallen = 28957
totallen = 30417
totallen = 31877
totallen = 33337
totallen = 34797
totallen = 36257
totallen = 37717
totallen = 39177
totallen = 40637
totallen = 42097
totallen = 43557
totallen = 45017
totallen = 46477
totallen = 47937
totallen = 49397
totallen = 50857
totallen = 52317
totallen = 53777
totallen = 55237
totallen = 56697
totallen = 58157
totallen = 59617
totallen = 61077
totallen = 62537
totallen = 63997
totallen = 65457
totallen = 66917
totallen = 68377
totallen = 69837
totallen = 71297
totallen = 72757
totallen = 74217
totallen = 75677
totallen = 77137
totallen = 78597
totallen = 80057
totallen = 81517
totallen = 82977
totallen = 84437
totallen = 85897
totallen = 87357
totallen = 88817
totallen = 90277
totallen = 91737
totallen = 93197
totallen = 94657
totallen = 96117
totallen = 97577
totallen = 99037
totallen = 100497
totallen = 101957
totallen = 103417
totallen = 104877
totallen = 106337
totallen = 107797
totallen = 109257
totallen = 110717
totallen = 112177
totallen = 113637
totallen = 115097
totallen = 116557
totallen = 118017
totallen = 119477
totallen = 120937
totallen = 122397
totallen = 123857
totallen = 125317
totallen = 126777
totallen = 128237
totallen = 129697
totallen = 131157
totallen = 132617
totallen = 134077
totallen = 135537
totallen = 136997
totallen = 138457
totallen = 139917
totallen = 141377
totallen = 142837
totallen = 144297
totallen = 145757
totallen = 147217
totallen = 148677
totallen = 150137
totallen = 151597
totallen = 153057
totallen = 154517
totallen = 155977
totallen = 157437
totallen = 158897
totallen = 160357
totallen = 161817
totallen = 163277
totallen = 164737
totallen = 166197
totallen = 167657
totallen = 169117
totallen = 170577
totallen = 172037
totallen = 173497
totallen = 174957
totallen = 176417
totallen = 177877
totallen = 179337
totallen = 180797
totallen = 182257
totallen = 183717
totallen = 185177
totallen = 186637
totallen = 188097
totallen = 189557
totallen = 191017
totallen = 192477
totallen = 193937
totallen = 195397
totallen = 196857
totallen = 198317
totallen = 199777
totallen = 201237
totallen = 202697
totallen = 204157
totallen = 205617
totallen = 207077
totallen = 208537
totallen = 209997
totallen = 211457
totallen = 212917
totallen = 214377
totallen = 215837
totallen = 217297
totallen = 218757
totallen = 218820
flash_crc = 1884328849
img_crc = 1884328849
upgrade_check
reboot to use2
state: 5 -> 0 (0)
rm 0
pm close 7
del if0
Here's what happens on the second pass. It corrupts on "erase sector=1 ok"
[OTA]Server 192.168.1.54:80. Path: /user1.4096.new.4.bin
[OTA]Upgrading...
upgrade_connect_cb
GET /user1.4096.new.4.bin HTTP/1.1
HEAD /user1.4096.new.4.bin HTTP/1.1
Connection: close
Last-Modified: Tue, 09 Feb 2016 01:03:15 GMT
ETag: "8a15f7a7d562d11:0"
Date: Tue, 09 Feb 2016 01:06:20 GMT
Connection: close
sumlength = 218820
sec_block 54
erase sector=1 ok
Any idea what's going on or what I can do? I've tried this with numerous different SPI_SIZE_MAP's and file servers. Your help is very much appreciated. Thanks in advance.
Regards,
Postby ESP_Faye » Tue Feb 16, 2016 7:55 pm
Please download the bin files into flash through ESP Flash Download Tool http://bbs.espressif.com/viewtopic.php?f=57&t=433, selecting the corresponding flash size.
If your problem is still unsolved, please provide the captured picture of ESP flash download tool while downloading, and the log since ESP8266 power on for debugging.
sers
Postby sers » Sat Mar 04, 2017 7:29 am
I had the same issue with second pass. spi_flash_erase_sector could not erase sector 1. Although system_upgrade_userbin_check() returned 1 (you are running from user2.bin) actually user1.bin was used. I.e., the program couldn't erase itself.
To resolve the issue you need to execute
> make clean
compile user1.bin
> make clean
compile user2.bin
user1.bin and user2.bin are not the same files and shall have different CRC checksum (last 4 bytes)!
AgentSmithers
Contact:
Postby AgentSmithers » Fri May 12, 2017 6:25 am
Hi Guys! Were is the Makefile located that you used to create the User1.bin and User2.bin?
Users browsing this forum: No registered users and 317 guests
