关于ICACHE_FLASH_ATTR的用法
Paulwu
Postby Paulwu » Thu Oct 22, 2015 9:19 am
看见很多函数前加了void ICACHE_FLASH_ATTR,这句是什么意思?什么情况下需要加上ICACHE_FLASH_ATTR。TKS!
Re: 关于ICACHE_FLASH_ATTR的用法
Postby ESP_Faye » Fri Oct 23, 2015 3:50 pm
您好,
请参考帖子:http://bbs.espressif.com/viewtopic.php?f=61&t=366。
感谢您对 ESP8266 的关注!
mariuszb
Postby mariuszb » Thu Dec 10, 2015 7:03 pm
I would like to understand it well:
1. Functions with ICACHE_FLASH_ATTR are in FLASH and downloaded to IRAM "on execution demand"
2. Functions without ICACHE_FLASH_ATTR are from the beginning in the IRAM
Questions to point 2:
- Are they there permanently ?
- or in the absence of memory erased and then re-loaded like ICACHE_FLASH_ATTR ?
- if they are still in memory and will be a lot of such functions does not run out of cache for ICACHE_FLASH_ATTR function ?
or the only difference is that the functions are loaded into the cache at the beginning and further there is no difference between functions with and without attribute ICACHE_FLASH_ATTR ?
Thanks for ansver :)
Postby ESP_Faye » Fri Dec 11, 2015 3:03 pm
Please refer to this topic http://bbs.espressif.com/viewtopic.php?f=7&t=1183&start=10#p5000.
jinhucn
Postby jinhucn » Fri Dec 25, 2015 3:15 pm
另外两个帖子我都看了,只是说不加ICACHE_FLASH_ATTR的函数在boot时预载到ram。但是没有解释是否永久驻留ram,还是不用的时候会从内存中置换出去。
Postby ESP_Faye » Mon Dec 28, 2015 2:36 pm
您好,
ICACHE_FLASH_ATTR 是 ESP8266_NONOS_SDK 才需要添加的宏,ESP8266_RTOS_SDK 默认使用这个宏,无需特别添加。
如果是一开始就加载到 RAM 的函数,将始终在 RAM 中。在 CACHE 中的函数,才是仅调用时才加载到 CACHE 中。
感谢您对 ESP8266 的关注!
jinhucn
Postby jinhucn » Tue Jan 05, 2016 4:39 pm
Espressif_Faye wrote:您好,
感谢您对 ESP8266 的关注!
加载到CACHE中的函数应该是用完了就会被置换出去的吧,那么user_rf_pre_init和user_init通常只需要运行一次,为什么你们给的例子中没有使用ICACHE_FLASH_ATTR?
Postby ESP_Faye » Tue Jan 05, 2016 5:59 pm
您好,
user_rf_pre_init 和 user_init 可以添加 ICACHE_FLASH_ATTR 宏,如果您有相关需求,自行添加即可。
感谢您对 ESP8266 的关注!
