sent and recieve "simultaneously"?
CCP1CON
Postby CCP1CON » Fri Oct 23, 2015 4:31 am
if I send this to the ESP and set it to transmit
AT+CWMODE_CUR=2\r\n
AT+CIPSTART=\"TCP\",\"192.168.10.11\",900\r\n
AT+CIPMODE=1\r\n
AT+CIPSEND\r\n
will it still be able to receive data and send them out through UART to my MCU?
Thanks for your advice.
Re: sent and recieve "simultaneously"?
Postby ESP_Faye » Mon Oct 26, 2015 11:50 am
You have set the ESP8266 enter UART <-> WiFi passthrough mode.
Remote <-network-> ESP8266 <-UART-> MCU
Data received from the network will be sent to your MCU by UART.
And data recerved from MCU through UART will be sent to remote device through network.
tj4shee
Postby tj4shee » Wed Oct 28, 2015 4:51 am
I must not be understanding something.... I am new to the ESP8266.....
Here is my UART Stream.....
AT+CIPSTART="TCP","192.168.1.102",80
CONNECT
CLOSED
CONNECT
AT+CIPSEND=28
busy s...
Recv 28 bytes
SEND OK
+IPD,298:<!DOCTYPE html>
<html>
<head>
   <title></title>
</head>
<body style="font-size:2.0em;text-align:center;">
   <br><br>
   This page is no longer available.
   <br><br>
   For BASTools use this link:
   <br>
   <a href="http://www.ibmanalyticsservice.com/bastools">www.ibmanalyticsservice.com</a>
</body>
</html>
CLOSED
AT+CIPCLOSE
ERROR
AT+CIPMODE?
+CIPMODE:0
AT+CIPMODE=1
CONNECT
AT+CIPSEND=16
IPMODE=1
ERROR
If +CIPMODE = 0, I can send data ....... MCU UART->ESP8266->network->Server
and it sends data back...
But, if I change CIPMODE to 1...... it won't let me send data from the MCU out.....
Isn't this backwards from the AT+CIPMODE instructions documented ?
Postby ESP_Faye » Wed Oct 28, 2015 10:35 am
Here is a guide, 4B-ESP8266__AT Command Examples.
Please refer to Chapter 4 in the documentation for UART - WiFi passthrough mode.
