how could using UART0 in RTOS SDK???
marhc_seven
Postby marhc_seven » Mon Oct 26, 2015 4:23 pm
it seems that there is not any uart sending string funtion in RTOS SDK?
how could i send string output from the UART0 ????
BR
BR
marhc_seven
Re: how could using UART0 in RTOS SDK???
Postby marhc_seven » Mon Oct 26, 2015 5:03 pm
i am using the os_printf but there is nothing output from the uart!!!!!
/* NOTE: don't use printf_opt in irq handler, for test */
#define os_printf(fmt, ...) do { \
static const char flash_str[] ICACHE_RODATA_ATTR STORE_ATTR = fmt; \
printf(flash_str, ##__VA_ARGS__); \
} while(0)
#endif /* __LIBC_H__ */
the uart0 always put 0x00 ~~~~~
static void RAMFUNC LEDBlinkTask(void *pvParameters)
PIN_FUNC_SELECT(PERIPHS_IO_MUX_U0TXD_U, FUNC_GPIO1);
for (int tick = 0;; tick++)
vTaskDelay(s_LEDPeriod / portTICK_RATE_MS);
gpio_output_conf(0, BIT1, BIT1, 0);
gpio_output_conf(BIT1, 0, BIT1, 0);
os_printf("aaaaaa\n");
}/* NOTE: don't use printf_opt in irq handler, for test */
} while(0)
marhc_seven
Postby marhc_seven » Mon Oct 26, 2015 7:07 pm
i have creat a task ! which could be blink the led again and again.
and i have always add the uart0 sending function in it, but it doesn't work
gpio_output_conf(0, BIT2, BIT2, 0);
gpio_output_conf(BIT2, 0, BIT2, 0);
os_putc(0x09); //no work !!!
//uart_tx_one_char(UART0, 'a'); // no work !!!
//os_printf("aaaaaa\n"); // No work !!!
marhc_seven
Postby marhc_seven » Tue Oct 27, 2015 3:11 pm
sorry, i need to sending the data from uart0 !!!
be aware of no only printf for debug!!!
