How to correctly stop a TCP server from listening?
User avatar
kolban
Postby kolban » Tue Oct 27, 2015 12:05 pm
I am using the SDK to create a socket server within my ESP8266. To accomplish this, I use the SDK API called espconn_accept(). This works great. However, in my application I also want to stop the server from listening ... and this is where I am confused.
What API should I use to stop the socket from listening any further?
I thought maybe that it might have been espconn_delete(), however when I call that, I get a return code of -5 (ESPCONN_INPROGRESS) and the socket is still listening for new connections.
Re: How to correctly stop a TCP server from listening?
Postby ESP_Faye » Fri Oct 30, 2015 12:12 pm
Returning code of -5 (ESPCONN_INPROGRESS) means that there are still TCP clients connected to TCP server.
You could call espconn_disconnect to disconnect the clients first, then call espconn_delete to delete the server.
User avatar
kolban
Postby kolban » Fri Oct 30, 2015 12:35 pm
Thank you for the response. This opens up a whole new set of considerations. I think you are telling me that if I configure an ESP8266 to listen on a particular port for client connections then once client connections start to arrive, I can't simply "close" the server listener without first closing all the client connections. This is an important semantic that I don't think I ever saw documented or discussed.
It now begs some new questions:
1) For a given socket listener, is there a way to determine which client connections are "associated" with that listener? It seems in order to close the socket listener, I need to close clients that were created when they connected to that server port ... am I supposed to track those myself?
2) What if I wish to suspend the arrival of new server connection requests while I process the clients I already have? I had assumed that I could "stop" a TCP server for listening when I had accumulated my limit of client connections. Since I don't seem to be able to do this without first closing the previous client connections that I am not yet finished with, I appear to be at an impass.
Postby ESP_Faye » Mon Nov 02, 2015 11:16 am
Thanks for your valuable advice ! We will add it in the documentation.
1. espconn_get_connection_info can get the information of connections, here is an example in tcp_server_mutli_sent http://bbs.espressif.com/viewtopic.php?f=31&t=763.
2. espconn_tcp_set_max_con_allow can set the maximum number of TCP clients that allowed to connect to the server.
