How to fix the UART message -"chg_A3:0" and "chg_A3:-180" in SDK v1.4.1_pre5_15_10_27
pcbass
Postby pcbass » Thu Oct 29, 2015 5:56 pm
When I use SDK v1.4.0_15_09_18, I found that UART interface will occurred below message.
chg_A3:0
chg_A3:-180
chg_A3:0
chg_A3:-180
chg_A3:0
chg_A3:-180
chg_A3:0
chg_A3:-180
chg_A3:0
chg_A3:-180
I check the forum that found someone has the same issue (http://bbs.espressif.com/viewtopic.php?f=7&t=1257&p=4191&hilit=chg_A3#p4191, the offical's reply only mentions that asking user to user new SDK v1.4.1_pre5_15_10_27. But I use this new SDK and still have the same UART message.
Could anyone know how to remove this UART message ?
Re: How to fix the UART message -"chg_A3:0" and "chg_A3:-180" in SDK v1.4.1_pre5_15_10_27
Postby ESP_Faye » Fri Oct 30, 2015 10:14 am
Regardless of the logs, can ESP8266 work well ?
In your case, can other stations connect to ESP8266 soft-AP ?
pcbass
Postby pcbass » Fri Oct 30, 2015 10:38 am
Yes, ESP8266 is work will, and statsion(like mobile phone) can connect to it.
mode : sta(12:34:56:78:90:ab) + softAP(16:34:56:78:90:ab)
add if0
add if1
dhcp server start:(ip:192.168.1.1,mask:255.255.255.0,gw:192.168.1.1)
bcn 100
chg_A3:-180
chg_A3:0
add 1
aid 1
station: 38:aa:3c:e7:73:4d join, AID = 1
But before station connection, the message "chg_A3:-180" will always show up. Could I disable or remove this UART message ?
(Thank you!)
Postby ESP_Faye » Fri Oct 30, 2015 5:09 pm
Could you please print the version information of the SDK to ensure that you are using the SDK_v1.4.1 patch ?
Richard
Postby Richard » Tue Dec 15, 2015 12:56 am
I am seeing these messages.
I see them with
esp_iot_sdk_v1.4.1_pre5_15_10_27 and pre7
and esp_iot_sdk_v1.5.0_15_11_27
Do you know what theses codes mean and how do you disable them.
Postby ESP_Faye » Thu Dec 17, 2015 11:12 am
"chg_A3:0" and "chg_A3:-180" means that ESP8266 is adjusting its frequency offset, it is not a problem, you can just ignore the logs.
Mario_
Postby Mario_ » Thu Dec 17, 2015 5:27 pm
But why is it doing so often? Won't some kind of calibration stop it doing that? Or is it normal and just being printed out unnecesarily (i.e. debug log not commented out).
Postby ESP_Faye » Fri Dec 18, 2015 3:10 pm
Please have a try with our latest ESP8266_NONOS_SDK_V1.5.0.
If it still outputs so often, please provide the UART logs for debugging.
