[SOLVED]FreeRTOS SDK : UART ISR compile error
knifey-spooney
Postby knifey-spooney » Sun Nov 01, 2015 12:26 pm
Hi All,
I am currently using the uart.c file from the FreeRTOS SDK git repository, to play around with the UART.
Unfortunately if I try to compile this file I get the following error :
uart.c: In function 'UART_intr_handler_register':
uart.c:270:5: error: too few arguments to function '_xt_isr_attach'
_xt_isr_attach(ETS_UART_INUM, fn);
In file included from /home/knifey-spooney/esp_stuff/esp_iot_rtos_sdk//include/freertos/portable.h:318:0,
from /home/knifey-spooney/esp_stuff/esp_iot_rtos_sdk//include/freertos/FreeRTOS.h:87,
from uart.c:8:
/home/knifey-spooney/esp_stuff/esp_iot_rtos_sdk//include/freertos/portmacro.h:185:13: note: declared here
void _xt_isr_attach (uint8 i, _xt_isr func, void *arg);
Just wondering if anyone could point me to the documentation on the _xt_isr code, and/or its source code?
Also if I remove this functionality from this file it compiles and works beautifully.
Apologies if this question has been asked before.
Many Thanks,
Andrew.
from uart.c:8:
Many Thanks,
Andrew.
Re: FreeRTOS SDK : UART ISR compile error
Postby kolban » Mon Nov 09, 2015 2:15 pm
Howdy Andrew,
I see that there is a new release of the RTOS SDK ... maybe have a try with that and see if there are any changes?
knifey-spooney
Postby knifey-spooney » Mon Nov 09, 2015 3:44 pm
Hi Kolban,
I just pulled the latest version of the RTOS sdk, and no changes.
I had a look at the header file that contains _xt_isr_attach (link: https://github.com/espressif/ESP8266_RTOS_SDK/blob/master/include/freertos/portmacro.h), and what I noticed is that there is a typedef for _xt_isr in the line above, which sets _xt_isr to be a pointer to a function that returns void and takes a void pointer as an argument.
Seeing this I changed the 'UART_intr_handler_register' function in uart.c to this:
With this change in place, the file compiles, but I do not know how well the isr handler actually works; so I'll go and do that now.
Any feedback on this change would be greatly appreciated.
Many Thanks,
Andrew.
void ICACHE_FLASH_ATTR
UART_intr_handler_register(void *fn)
_xt_isr func = fn;
_xt_isr_attach(ETS_UART_INUM, func, fn);
Many Thanks,
Andrew.
knifey-spooney
Postby knifey-spooney » Mon Nov 09, 2015 7:23 pm
Just found out that there was a pull request to fix this back in September : https://github.com/espressif/ESP8266_RTOS_SDK/pull/27/commits.
This fix works, as does mine.
Many Thanks,
Andrew Collins.
Many Thanks,
Andrew Collins.
