HSPI CLK管脚电压低
HSPI CLK管脚电压低
Postby zsf518 » Thu Nov 05, 2015 2:39 pm
hi,
将ESP-12 的HSPI配置为master模式,下面是初始化代码。
void ICACHE_FLASH_ATTR
spi_master_init(uint8 spi_no)
uint32 regvalue;
if(spi_no>1)
return; //handle invalid input number
printf("xxxxxx spi_no= %d \n", spi_no);
if(spi_no==SPI)
WRITE_PERI_REG(PERIPHS_IO_MUX, 0x005);
PIN_FUNC_SELECT(PERIPHS_IO_MUX_SD_CLK_U, 1);//configure io to spi mode
PIN_FUNC_SELECT(PERIPHS_IO_MUX_SD_CMD_U, 1);//configure io to spi mode
PIN_FUNC_SELECT(PERIPHS_IO_MUX_SD_DATA0_U, 1);//configure io to spi mode
PIN_FUNC_SELECT(PERIPHS_IO_MUX_SD_DATA1_U, 1);//configure io to spi mode
else if(spi_no==HSPI)
//WRITE_PERI_REG(PERIPHS_IO_MUX, 0x105);
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDI_U, 2);//configure io to spi mode
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTCK_U, 2);//configure io to spi mode
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTMS_U, 2);//configure io to spi mode
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDO_U, 2);//configure io to spi mode
printf("11111\n");
SET_PERI_REG_MASK(SPI_USER(spi_no), SPI_CS_SETUP|SPI_CS_HOLD|SPI_USR_COMMAND|SPI_USR_MOSI);
CLEAR_PERI_REG_MASK(SPI_USER(spi_no), SPI_FLASH_MODE);
printf("2222\n");
//clear Daul or Quad lines transmission mode
CLEAR_PERI_REG_MASK(SPI_CTRL(spi_no), SPI_QIO_MODE|SPI_DIO_MODE|SPI_DOUT_MODE|SPI_QOUT_MODE);
printf("3333\n");
WRITE_PERI_REG(SPI_CLOCK(spi_no),
((39 & SPI_CLKDIV_PRE) << SPI_CLKDIV_PRE_S) |
((3&SPI_CLKCNT_N)<<SPI_CLKCNT_N_S)|
((1&SPI_CLKCNT_H)<<SPI_CLKCNT_H_S)|
((3&SPI_CLKCNT_L)<<SPI_CLKCNT_L_S)); //clear bit 31,set SPI clock div
printf("4444\n");
//set 8bit output buffer length, the buffer is the low 8bit of register"SPI_FLASH_C0"
//WRITE_PERI_REG(SPI_USER1(spi_no),
// ((7&SPI_USR_MOSI_BITLEN)<<SPI_USR_MOSI_BITLEN_S)|
// ((7&SPI_USR_MISO_BITLEN)<<SPI_USR_MISO_BITLEN_S));
测试HSPI 的clk管脚输出大约1.5V左右的波形,导致slaver接收失败。
原来的配置里面有一行:WRITE_PERI_REG(PERIPHS_IO_MUX, 0x105); 不知道是做什么的。
如果不屏蔽这一行,程序执行到这里后会立即卡住,导致ESP-12模块的WIFI驱动加载出现问题,ESP-12模块就会超时重启。
请帮忙解答一下。
uint32 regvalue;
if(spi_no>1)
if(spi_no==SPI)
printf("11111\n");
printf("2222\n");
printf("3333\n");
printf("4444\n");
请帮忙解答一下。
Re: HSPI CLK管脚电压低
Postby foxxml » Tue Jun 07, 2016 4:06 pm
I have the same problem! I use the spi sample code downloaded here: viewtopic.php?f=31&t=1346
this is what i got:
yellow line is SPI_SCLK, blue line is MOSI (i changed to spi clk to 625khz)
when i zoom into the "mass" of the yellow line:
the freq is happened to match the core clk(80MHZ)
No doubt, with this clock waveform, the slave device won't work!
Lucky for me, i found here. It notify that the clk pin is only 1.5 vol,
and in my case the RMS of clk pin is 1.57v.
I then add this line to my code:
IT WORKS!
I read out the original PERIPHS_IO_MUX register:
it is : 0x205.
however I can't find a detail description of this register, especially bit above 7.
can @Espressif_Faye give us a description about this ? does it have any side effect?
we're doing some serious RD on 8266, using unknown code is dangerous!
this is what i got:
IT WORKS!
it is : 0x205.
void user_init(void)
os_printf("------------------start------------------\n\r");
set_data();
spi_master_init(HSPI);
spi_mast_byte_write(HSPI,0xAA);
GPIO_OUTPUT_SET(GPIO_ID_PIN(5), 1);
//spi_byte_write_espslave(HSPI,0xAA);
//spi_WR_espslave(HSPI);
os_printf("------------------done!------------------\n\r");
os_printf("\n\r");
os_printf("\n\r");
uint32 regvalue;
if(spi_no>1) {
os_printf("invalid spi number!\n\r");
return;
} //handle invalid input number
else if(spi_no==SPI){
}else if(spi_no==HSPI){
os_printf("spi_clk HSPI %08x\r\n",READ_PERI_REG(PERIPHS_IO_MUX));
//WRITE_PERI_REG(PERIPHS_IO_MUX, 0x001);
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDI_U, 2);//configure io to Hspi mode
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTCK_U, 2);//configure io to Hspi mode
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTMS_U, 2);//configure io to Hspi mode
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDO_U, 2);//configure io to Hspi mode
//SET_PERI_REG_MASK(SPI_USER(spi_no), SPI_CS_SETUP|SPI_CS_HOLD);
//CLEAR_PERI_REG_MASK(SPI_USER(spi_no), SPI_FLASH_MODE|SPI_USR_COMMAND);
SET_PERI_REG_MASK(SPI_USER(spi_no), SPI_CS_SETUP|SPI_CS_HOLD|SPI_USR_COMMAND);
((1&SPI_CLKDIV_PRE)<<SPI_CLKDIV_PRE_S)|
((63&SPI_CLKCNT_N)<<SPI_CLKCNT_N_S)|
((31&SPI_CLKCNT_H)<<SPI_CLKCNT_H_S)|
((63&SPI_CLKCNT_L)<<SPI_CLKCNT_L_S)); //clear bit 31,set SPI clock div
os_printf("spi_clk HSPI %08x\r\n",READ_PERI_REG(SPI_CLOCK(spi_no)));
//WRITE_PERI_REG(PERIPHS_IO_MUX_MTDO_U, READ_PERI_REG(PERIPHS_IO_MUX_MTDO_U) & 0x7F);
os_printf("spi_clk SPI %08x\r\n",READ_PERI_REG(SPI_CLOCK(SPI)));
os_printf("MTMO %08x\r\n", READ_PERI_REG(PERIPHS_IO_MUX_MTDO_U));Who is online
Users browsing this forum: No registered users and 286 guests
