ESP8266_RTOS_SDK V3 - No Partition - load at 0 and 0x20000
jhinkle
Postby jhinkle » Sun Sep 30, 2018 3:30 am
I'm porting an application from RTOS SDK V2 to V3 (IDF process).
There does not seem to be a menu selection to enable ESPtool to generate the old style bin files which load at 0x0000 and 0x20000.
Is it possible to create the old bin images using the new IDF process?
I need to old method since the app is embedded and the ESP8266 is programmed by another embedded processor -- not the esptool.
jhinkle
Re: ESP8266_RTOS_SDK V3 - No Partition - load at 0 and 0x20000
Postby jhinkle » Wed Oct 10, 2018 5:20 am
Remove and/or ignore this post.
Asked question well before I had a good understanding of the IDF process.
I implemented a Partition (Single Factory) and all is well.
This should be closed.
