epc1=0x40100088, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
Fatal exception (0):Thanks for your help.
Postby STcraft » Tue Nov 17, 2015 2:11 am
Fatal exception (0):Postby ESP_Faye » Wed Nov 18, 2015 3:21 pm
Postby Gaspar » Tue Jun 28, 2016 7:46 am
test baudrate: 115200
test baudrate selection: 4
test label: Download Panel 2
self.num: 2
init finished
_COM: 6
ESP_ROM_BAUD : 115200
EFUSE_MODE: 1
test baudrate: 46080
test baudrate selection: 2
test label: Download Panel 3
self.num: 3
init finished
_COM: 6
EFUSE_MODE: 1
test baudrate: 9600
test baudrate selection: 0
test label: Download Panel 4
self.num: 4
init finished
_COM: 6
EFUSE_MODE: 1
test baudrate: 9600
test label: Download Panel 5
self.num: 5
init finished
_COM: 6
EFUSE_MODE: 1
test baudrate: 9600
test label: Download Panel 6
self.num: 6
init finished
_COM: 6
EFUSE_MODE: 1
test baudrate: 9600
test label: Download Panel 7
self.num: 7
init finished
_COM: 6
EFUSE_MODE: 1
test baudrate: 9600
test label: Download Panel 8
self.num: 8
init finished
_COM: 6
EFUSE_MODE: 1
test baudrate: 9600
tout as adc
RF option applied...
test offset : 507904 0x7c000
case ok
test offset : 0 0x0
case ok
test offset : 516096 0x7e000
case ok
test offset : 262144 0x40000
case ok
(True, [[u'D:\\ESP_FLASH_TOOL\\ESP8266_NONOS_SDK\\bin\\at\\noboot\\eagle.flash.b
in', 0], [u'D:\\ESP_FLASH_TOOL\\ESP8266_NONOS_SDK\\bin\\at\\noboot\\eagle.irom0t
ext.bin', 262144], [u'D:\\ESP_FLASH_TOOL\\ESP8266_NONOS_SDK\\bin\\esp_init_data_
default.bin', 507904], [u'D:\\ESP_FLASH_TOOL\\ESP8266_NONOS_SDK\\bin\\blank.bin'
, 516096]])
rep_path : D:\archivos de programa\FLASH_DOWNLOAD_TOOLS_v2.4_150924\bin_tmp\down
loadPanel1
NOTE: BINARY CONFIG DISABLED,
JUST DOWNLOAD THE ORIGINAL BINARIES
test fpath: D:\ESP_FLASH_TOOL\ESP8266_NONOS_SDK\bin\at\noboot\_temp_by_dltool/do
wnloadPanel1
test fname: D:\ESP_FLASH_TOOL\ESP8266_NONOS_SDK\bin\at\noboot\_temp_by_dltool/do
wnloadPanel1\eagle.flash.bin_rep
mode : ☻ speed:
write bin : D:\ESP_FLASH_TOOL\ESP8266_NONOS_SDK\bin\at\noboot\_temp_by_dltool/d
ownloadPanel1\eagle.flash.bin_rep
test fpath: D:\ESP_FLASH_TOOL\ESP8266_NONOS_SDK\bin\_temp_by_dltool/downloadPane
l1
test fname: D:\ESP_FLASH_TOOL\ESP8266_NONOS_SDK\bin\_temp_by_dltool/downloadPane
l1\esp_init_data_default.bin_rep
mode : ☻ speed:
write bin : D:\ESP_FLASH_TOOL\ESP8266_NONOS_SDK\bin\_temp_by_dltool/downloadPan
el1\esp_init_data_default.bin_rep
test running : False
serial port open error
case ok
test offset : 0 0x0
case ok
case ok
case ok
, 516096]])
loadPanel1
wnloadPanel1
mode : ☻ speed:
l1
mode : ☻ speed:
case ok
test offset : 0 0x0
case ok
case ok
case ok
, 516096]])
loadPanel1
wnloadPanel1
mode : ☻ speed:
l1
mode : ☻ speed:
serial port opened
Connecting...
chip sync ok!
0x3ff00050: 30a50000
0x3ff00054: 02000d6b
0x3ff00058: 6400b000
0x3ff0005c: 005ccf7f
EFUSE MODE : 1
reg0:30a50000
reg1:02000d6b
reg2:6400b000
reg3:005ccf7f
check_err_0: 0b
check_err_1: 00
check_err_2: 00
check_err_3: 02
check_err_4: 0b
EFUSE NORMAL MODE
CRC IN MODE 1:
crc_calc_res: 100
target crc val: 100
CRC IN MODE 1:
crc_calc_res: 165
target crc val: 165
EFUSE LOG:
EFUSE LOG:
REG0:30A50000
REG1:02000D6B
REG2:6400b000
REG3:005CCF7F
EFUSE NORMAL MODE
EFUSE CHECK PASS...
reg2>>13: 5
48bit mac
debug:
5c cf 7f 0d 6b 30
ID FOR XM: 06 40 00 00 00 0A 50 00
XM_ID: 06400000000A5000
crc_efuse_4bit: 0
crc_calc_4bit: 6
48bit mac
MAC AP : 5E-CF-7F-0D-6B-30
MAC STA: 5C-CF-7F-0D-6B-30
get mac res: True
('tttest uuuuuuuuuuart : uart reg: ', 457)
(' baudrate: ', 115200)
get crystal: 26323200
head: 0 ;total: 0
erase size : 0
get flash id : 0xdb1440e0
manufacturer_id: 0xe0
device_id: 0x4014
vendor: 224
mode: 64
filename: D:\archivos de programa\FLASH_DOWNLOAD_TOOLS_v2.4_150924\bin_tmp\down
offset : 0
loadPanel1\eagle.irom0text.bin
offset : 262144
loadPanel1\esp_init_data_default.bin_rep
offset : 507904
loadPanel1\blank.bin
offset : 516096
Erasing flash...
head: 10 ;total: 10
erase size : 20480
Writing at 0x00009800... (9 %)
Leaving...
Erasing flash...
head: 16 ;total: 87
erase size : 290816
Writing at 0x00096000... (98 %)
Leaving...
Erasing flash...
head: 1 ;total: 1
erase size : 4096
Writing at 0x0007c000... (98 %)
Leaving...
Erasing flash...
head: 1 ;total: 1
erase size : 4096
Writing at 0x0007ec00... (99 %)
Leaving...
com closed
Postby ESP_Greg » Thu Jun 30, 2016 11:58 am
Postby pratik » Thu Jun 30, 2016 9:47 pm
