ESP-01 Bootup and AT Command
eso
Postby eso » Tue Nov 17, 2015 6:17 am
I just started to play with 5 new ESP-01 and tried to connect them via terminal.
What I got under coolterm is this:
*EMRDY: 1
*EMRDY: 1
atOK
at+gmrR2A07(R2A07)
at+rstERROR
at+gslpERROR
ateOK
at+cwmode=?ERROR
at+cipstart=?ERROR
at+cmd?ERROR
ateOK
ate1OK
at+rstERROR
So ... every AT command returns an error (except at, ate and at+gmr)
And the answer from gmr is quite strange, I didn't find any hint on the net.
Can you give me some hints? I don't believe all 5 chips are broken, they all behave the same way, so the mistake must be on my side.
Kind regards from Germany
Eric
Re: ESP-01 Bootup and AT Command
Postby ESP_Faye » Tue Nov 17, 2015 10:08 am
It should be "AT+GMR" "AT+RST", not "at+gmr" "at+rst".
There are documentations about AT commands: http://bbs.espressif.com/viewtopic.php?f=51&t=1022
eso
Postby eso » Wed Nov 18, 2015 4:14 am
Thank you for your reply!
I've tried this before but here are the responses from today:
AT+RSTERROR
AT+GMRR2A07(R2A07)
ATOK
ATEOK
ATE1OK
ATEOK
AT+CWMODE=?ERROR
AT+RESTOREERROR
AT+UART_CURERROR
AT+RFVDDERROR
It's just the same. I don't think it's that simple.
I obviously got a connection, but no basic AT command seems to work.
Flashing with an other FW doesn't work either.
Kind regards
Eric
Postby ESP_Faye » Wed Nov 18, 2015 11:11 am
It seems that you are not using the AT commands provided by our company, Espressif Systems.
Would you like to have a try with our AT firmware ? You can download it from http://bbs.espressif.com/viewtopic.php?f=46&t=1123.
