hi
i am change the parameter, as like this
// spiffs file system size
#define SPIFFS_FLASH_SIZE (256*1024) //512 KB
// spiffs file system offset in emulated spi flash
#define SPIFFS_PHYS_ADDR (592*1024) //512KB
#define SECTOR_SIZE 4096 //4KB
#define PHYS_ERASE_BLOCK SECTOR_SIZE//(SECTOR_SIZE*16) //64KB
#define LOG_BLOCK SECTOR_SIZE//(SECTOR_SIZE*16) //128KB
#define LOG_PAGE 256//(LOG_BLOCK/256) //256 byte
#define FD_BUF_SIZE 32*4
#define CACHE_BUF_SIZE (LOG_PAGE + 32)*4
when init spiffs , it was success, but before success there are a lot the read fail!!!
spi_flash_read failed: 1 (606460, 8)
spi_flash_read failed: 1 (610556, 8)
spi_flash_read failed: 1 (614652, 8)
spi_flash_read failed: 1 (618748, 8)
spi_flash_read failed: 1 (622844, 8)
spi_flash_read failed: 1 (626940, 8)
spi_flash_read failed: 1 (631036, 8)
spi_flash_read failed: 1 (635132, 8)
spi_flash_read failed: 1 (639228, 8)
spi_flash_read failed: 1 (643324, 8)
spi_flash_read failed: 1 (647420, 8)
spi_flash_read failed: 1 (651516, 8)
spi_flash_read failed: 1 (655612, 8)
spi_flash_read failed: 1 (659708, 8)
spi_flash_read failed: 1 (663804, 8)
spi_flash_read failed: 1 (667900, 8)
spi_flash_read failed: 1 (671996, 8)
spi_flash_read failed: 1 (676092, 8)
spi_flash_read failed: 1 (680188, 8)
spi_flash_read failed: 1 (684284, 8)
spi_flash_read failed: 1 (688380, 8)
spi_flash_read failed: 1 (692476, 8)
spi_flash_read failed: 1 (696572, 8)
spi_flash_read failed: 1 (700668, 8)
spi_flash_read failed: 1 (704764, 8)
spi_flash_read failed: 1 (708860, 8)
spi_flash_read failed: 1 (712956, 8)
spi_flash_read failed: 1 (717052, 8)
spi_flash_read failed: 1 (721148, 8)
spi_flash_read failed: 1 (725244, 8)
spi_flash_read failed: 1 (729340, 8)
spi_flash_read failed: 1 (733436, 8)
spi_flash_read failed: 1 (737532, 8)
spi_flash_read failed: 1 (741628, 8)
spi_flash_read failed: 1 (745724, 8)
spi_flash_read failed: 1 (749820, 8)
spi_flash_read failed: 1 (753916, 8)
spi_flash_read failed: 1 (758012, 8)
spi_flash_read failed: 1 (762108, 8)
spi_flash_read failed: 1 (766204, 8)
spi_flash_read failed: 1 (770300, 8)
spi_flash_read failed: 1 (774396, 8)
spi_flash_read failed: 1 (778492, 8)
spi_flash_read failed: 1 (782588, 8)
spi_flash_read failed: 1 (786684, 8)
spi_flash_read failed: 1 (790780, 8)
spi_flash_read failed: 1 (794876, 8)
spi_flash_read failed: 1 (798972, 8)
spi_flash_read failed: 1 (803068, 8)
spi_flash_read failed: 1 (807164, 8)
spi_flash_read failed: 1 (811260, 8)
spi_flash_read failed: 1 (815356, 8)
spi_flash_read failed: 1 (819452, 8)
spi_flash_read failed: 1 (823548, 8)
spi_flash_read failed: 1 (827644, 8)
spi_flash_read failed: 1 (831740, 8)
spi_flash_read failed: 1 (835836, 8)
spi_flash_read failed: 1 (839932, 8)
spi_flash_read failed: 1 (844028, 8)
spi_flash_read failed: 1 (848124, 8)
spi_flash_read failed: 1 (852220, 8)
spi_flash_read failed: 1 (856316, 8)
spi_flash_read failed: 1 (860412, 8)
spi_flash_read failed: 1 (864508, 8)
spi_flash_read failed: 1 (868604, 8)
spi_flash_read failed: 1 (872700, 8)
spi_flash_read failed: 1 (876796, 8)
spi_flash_read failed: 1 (880892, 8)
spi_flash_read failed: 1 (884988, 8)
spi_flash_read failed: 1 (889084, 8)
spi_flash_read failed: 1 (893180, 8)
spi_flash_read failed: 1 (897276, 8)
spi_flash_read failed: 1 (901372, 8)
spi_flash_read failed: 1 (905468, 8)
spi_flash_read failed: 1 (909564, 8)
spi_flash_read failed: 1 (913660, 8)
spi_flash_read failed: 1 (917756, 8)
spi_flash_read failed: 1 (921852, 8)
spi_flash_read failed: 1 (925948, 8)
spi_flash_read failed: 1 (930044, 8)
spi_flash_read failed: 1 (934140, 8)
spi_flash_read failed: 1 (938236, 8)
spi_flash_read failed: 1 (942332, 8)
spi_flash_read failed: 1 (946428, 8)
spi_flash_read failed: 1 (950524, 8)
spi_flash_read failed: 1 (954620, 8)
spi_flash_read failed: 1 (958716, 8)
spi_flash_read failed: 1 (962812, 8)
spi_flash_read failed: 1 (966908, 8)
spi_flash_read failed: 1 (971004, 8)
spi_flash_read failed: 1 (975100, 8)
spi_flash_read failed: 1 (979196, 8)
spi_flash_read failed: 1 (983292, 8)
spi_flash_read failed: 1 (987388, 8)
spi_flash_read failed: 1 (991484, 8)
spi_flash_read failed: 1 (995580, 8)
spi_flash_read failed: 1 (999676, 8)
spi_flash_read failed: 1 (1003772, 8)
spi_flash_read failed: 1 (1007868, 8)
spi_flash_read failed: 1 (1011964, 8)
spi_flash_read failed: 1 (1016060, 8)
spi_flash_read failed: 1 (1020156, 8)
spi_flash_read failed: 1 (1024252, 8)
spi_flash_read failed: 1 (1028348, 8)
spi_flash_read failed: 1 (1032444, 8)
spi_flash_read failed: 1 (1036540, 8)
spi_flash_read failed: 1 (1040636, 8)
spi_flash_read failed: 1 (1044732, 8)
spi_flash_read failed: 1 (1048828, 8)
spi_flash_read failed: 1 (1052924, 8)
spi_flash_read failed: 1 (1057020, 8)
spi_flash_read failed: 1 (1061116, 8)
spi_flash_read failed: 1 (1065212, 8)
spi_flash_read failed: 1 (1069308, 8)
spi_flash_read failed: 1 (1073404, 8)
spi_flash_read failed: 1 (1077500, 8)
spi_flash_read failed: 1 (1081596, 8)
spi_flash_read failed: 1 (1085692, 8)
spi_flash_read failed: 1 (1089788, 8)
spi_flash_read failed: 1 (1093884, 8)
spi_flash_read failed: 1 (1097980, 8)
spi_flash_read failed: 1 (1102076, 8)
spi_flash_read failed: 1 (1106172, 8)
spi_flash_read failed: 1 (1110268, 8)
spi_flash_read failed: 1 (1114364, 8)
spi_flash_read failed: 1 (1118460, 8)
spi_flash_read failed: 1 (1122556, 8)
spi_flash_read failed: 1 (1126652, 8)
spi_flash_read failed: 1 (1130748, 8)
spi_flash_read failed: 1 (1134844, 8)
spi_flash_read failed: 1 (1138940, 8)
spi_flash_read failed: 1 (1143036, 8)
spi_flash_read failed: 1 (1147132, 8)
spi_flash_read failed: 1 (1151228, 8)
spi_flash_read failed: 1 (1155324, 8)
spi_flash_read failed: 1 (1159420, 8)
spi_flash_read failed: 1 (1163516, 8)
spi_flash_read failed: 1 (1167612, 8)
spi_flash_read failed: 1 (1171708, 8)
spi_flash_read failed: 1 (1175804, 8)
spi_flash_read failed: 1 (1179900, 8)
spi_flash_read failed: 1 (1183996, 8)
spi_flash_read failed: 1 (1188092, 8)
spi_flash_read failed: 1 (1192188, 8)
spi_flash_read failed: 1 (1196284, 8)
spi_flash_read failed: 1 (1200380, 8)
spi_flash_read failed: 1 (1204476, 8)
spi_flash_read failed: 1 (1208572, 8)
spi_flash_read failed: 1 (1212668, 8)
spi_flash_read failed: 1 (1216764, 8)
spi_flash_read failed: 1 (1220860, 8)
spi_flash_read failed: 1 (1224956, 8)
spi_flash_read failed: 1 (1229052, 8)
spi_flash_read failed: 1 (1233148, 8)
spi_flash_read failed: 1 (1237244, 8)
spi_flash_read failed: 1 (1241340, 8)
spi_flash_read failed: 1 (1245436, 8)
spi_flash_read failed: 1 (1249532, 8)
spi_flash_read failed: 1 (1253628, 8)
spi_flash_read failed: 1 (1257724, 8)
spi_flash_read failed: 1 (1261820, 8)
spi_flash_read failed: 1 (1265916, 8)
spi_flash_read failed: 1 (1270012, 8)
spi_flash_read failed: 1 (1274108, 8)
spi_flash_read failed: 1 (1278204, 8)
spi_flash_read failed: 1 (1282300, 8)
spi_flash_read failed: 1 (1286396, 8)
spi_flash_read failed: 1 (1290492, 8)
spi_flash_read failed: 1 (1294588, 8)
spi_flash_read failed: 1 (1298684, 8)
spi_flash_read failed: 1 (1302780, 8)
spi_flash_read failed: 1 (1306876, 8)
spi_flash_read failed: 1 (1310972, 8)
spi_flash_read failed: 1 (1315068, 8)
spi_flash_read failed: 1 (1319164, 8)
spi_flash_read failed: 1 (1323260, 8)
spi_flash_read failed: 1 (1327356, 8)
spi_flash_read failed: 1 (1331452, 8)
spi_flash_read failed: 1 (1335548, 8)
spi_flash_read failed: 1 (1339644, 8)
spi_flash_read failed: 1 (1343740, 8)
spi_flash_read failed: 1 (1347836, 8)
spi_flash_read failed: 1 (1351932, 8)
spi_flash_read failed: 1 (1356028, 8)
spi_flash_read failed: 1 (1360124, 8)
spi_flash_read failed: 1 (1364220, 8)
spi_flash_read failed: 1 (1368316, 8)
spi_flash_read failed: 1 (1372412, 8)
spi_flash_read failed: 1 (1376508, 8)
spi_flash_read failed: 1 (1380604, 8)
spi_flash_read failed: 1 (1384700, 8)
spi_flash_read failed: 1 (1388796, 8)
spi_flash_read failed: 1 (1392892, 8)
spi_flash_read failed: 1 (1396988, 8)
spi_flash_read failed: 1 (1401084, 8)
spi_flash_read failed: 1 (1405180, 8)
spi_flash_read failed: 1 (1409276, 8)
spi_flash_read failed: 1 (1413372, 8)
spi_flash_read failed: 1 (1417468, 8)
spi_flash_read failed: 1 (1421564, 8)
spi_flash_read failed: 1 (1425660, 8)
spi_flash_read failed: 1 (1429756, 8)
spi_flash_read failed: 1 (1433852, 8)
spi_flash_read failed: 1 (1437948, 8)
spi_flash_read failed: 1 (1442044, 8)
spi_flash_read failed: 1 (1446140, 8)
spi_flash_read failed: 1 (1450236, 8)
spi_flash_read failed: 1 (1454332, 8)
spi_flash_read failed: 1 (1458428, 8)
spi_flash_read failed: 1 (1462524, 8)
spi_flash_read failed: 1 (1466620, 8)
spi_flash_read failed: 1 (1470716, 8)
spi_flash_read failed: 1 (1474812, 8)
spi_flash_read failed: 1 (1478908, 8)
spi_flash_read failed: 1 (1483004, 8)
spi_flash_read failed: 1 (1487100, 8)
spi_flash_read failed: 1 (1491196, 8)
spi_flash_read failed: 1 (1495292, 8)
spi_flash_read failed: 1 (1499388, 8)
spi_flash_read failed: 1 (1503484, 8)
spi_flash_read failed: 1 (1507580, 8)
spi_flash_read failed: 1 (1511676, 8)
spi_flash_read failed: 1 (1515772, 8)
spi_flash_read failed: 1 (1519868, 8)
spi_flash_read failed: 1 (1523964, 8)
spi_flash_read failed: 1 (1528060, 8)
spi_flash_read failed: 1 (1532156, 8)
spi_flash_read failed: 1 (1536252, 8)
spi_flash_read failed: 1 (1540348, 8)
spi_flash_read failed: 1 (1544444, 8)
spi_flash_read failed: 1 (1548540, 8)
spi_flash_read failed: 1 (1552636, 8)
spi_flash_read failed: 1 (1556732, 8)
spi_flash_read failed: 1 (1560828, 8)
spi_flash_read failed: 1 (1564924, 8)
spi_flash_read failed: 1 (1569020, 8)
spi_flash_read failed: 1 (1573116, 8)
spi_flash_read failed: 1 (1577212, 8)
spi_flash_read failed: 1 (1581308, 8)
spi_flash_read failed: 1 (1585404, 8)
spi_flash_read failed: 1 (1589500, 8)
spi_flash_read failed: 1 (1593596, 8)
spi_flash_read failed: 1 (1597692, 8)
spi_flash_read failed: 1 (1601788, 8)
spi_flash_read failed: 1 (1605884, 8)
spi_flash_read failed: 1 (1609980, 8)
spi_flash_read failed: 1 (1614076, 8)
spi_flash_read failed: 1 (1618172, 8)
spi_flash_read failed: 1 (1622268, 8)
spi_flash_read failed: 1 (1626364, 8)
spi_flash_read failed: 1 (1630460, 8)
spi_flash_read failed: 1 (1634556, 8)
spi_flash_read failed: 1 (1638652, 8)
spi_flash_read failed: 1 (1642748, 8)
spi_flash_read failed: 1 (1646844, 8)
spi_flash_read failed: 1 (1650940, 8)
spi_flash_read failed: 1 (606208, 260)
spiffs config succes
do you know why ?
