I don't now for sure if this is the right place to put this, if it's not than just throw it to the place it should be
I'm hoping you can help me figure out how to make this project work. The idea is that we build a sensor glove which helds five bend sensors, an arduino nano and an ESP8266-01. On the other end we have an InMoov 3D Hand, five servo's, another arduino nano and another ESP8266-01. The set-up works flawless and the only problem we get is with the ESP's sending data to one another. We now do it on the way described in the code below:
Sender:
#include <SoftwareSerial.h>
#define DEBUG true
int bendsensor1 = A0;
int bendsensor2 = A1;
int val1=0;
int val2=0;
SoftwareSerial esp8266(2, 3);
void setup()
Serial.begin(9600);
esp8266.begin(115200);
sendData("AT+RST\r\n", 2000, DEBUG);
sendData("AT+CIOBAUD=9600\r\n", 2000, DEBUG);
esp8266.begin(9600);
sendData("AT+CWMODE=3\r\n", 2000, DEBUG);
sendData("AT+CWJAP=\"test\",\"test\"\r\n", 2000, DEBUG);
delay(15000);
sendData("AT+CIPSTART=\"TCP\",\"192.168.10.10\",80\r\n", 2000, DEBUG);
void loop()
val1=analogRead(bendsensor1);
val2=analogRead(bendsensor2);
sendData("AT+CIPSEND=3\r\n", 100, DEBUG);
Serial.println(val1);
sendData("AT+CIPSEND=1\r\n", 100, DEBUG);
Serial.println(val2);
And the serial output would look like:
AT+CWMODE=3
AT+CWJAP="test","test"
WIFI DISCONNECT
WIFI CONNECTED
WIFI DISCONNECT
WIFI CONNECTED
WIFI GOT IP
AT+CIPSTART="TCP","192.168.10.10",80
ERROR
CLOSED
AT+CIPSEND=3
link is not valid
ERROR
724
AT+CIPSEND=1
link is not valid
ERROR
0
Receiver:
#define DEBUG true
void setup()
Serial.begin(9600);
sendData("AT+CWMODE=3\r\n", 50, DEBUG);
sendData("AT+CWSAP=\"test\",\"test\",1,0\r\n", 50, DEBUG);
sendData("AT+CIPAP=\"192.168.10.10\"\r\n", 50, DEBUG);
sendData("AT+CIPMUX=1\r\n", 50, DEBUG);
sendData("AT+CIPSERVER=1,80\r\n", 50, DEBUG);
sendData("AT+CIFSR\r\n", 50, DEBUG);
sendData("+IPD", 50, DEBUG);
void loop()
AT+CWMODE=3
AT+CWSAP="test","test",1,0
AT+CIPAP="192.168.10.10"
AT+CIPMUX=1
AT+CIPSERVER=1,80
AT+CIFSR
+CIFSR:APIP,"192.168.10.10"
+CIFSR:APMAC,bé•é¢Ò2Ñ:74:dc"
+CIFSR:STAIP,"0.0.0.0"
+CIFSR:STAMAC,"18:fe:34:f4:74:dc"
+IPD
Does anyone see what the problem could be? Or does anyone know if there is another way to send this data? And how fast can I make this sending?
