ESP Touch smart config不成功
Postby leely » Fri Nov 20, 2015 12:24 pm
手机是iphone6 ios8.3。ESP touch v0.3.3。用xCode7做设备调试的时候,可以输出“send gc code”,前端日志如下:
2015-11-20 11:08:35.071 EspTouchDemo[5787:2927996] ESPTouchTask __listenAsyn() expectOneByte: 34
2015-11-20 11:08:41.094 EspTouchDemo[5787:2929212] ESPTouchTask __execute() send gc code
2015-11-20 11:08:47.108 EspTouchDemo[5787:2929212] ESPTouchTask __execute() send gc code
2015-11-20 11:08:53.139 EspTouchDemo[5787:2929212] ESPTouchTask __execute() send gc code
2015-11-20 11:08:59.157 EspTouchDemo[5787:2929212] ESPTouchTask __execute() send gc code
2015-11-20 11:09:05.158 EspTouchDemo[5787:2929212] ESPTouchTask __execute() send gc code
2015-11-20 11:09:11.174 EspTouchDemo[5787:2929212] ESPTouchTask __execute() send gc code
2015-11-20 11:09:17.204 EspTouchDemo[5787:2929212] ESPTouchTask __execute() send gc code
2015-11-20 11:09:23.104 EspTouchDemo[5787:2929212] ESPTouchTask __sleep() start
server: receiveOneByte fail
: Resource temporarily unavailable
2015-11-20 11:09:33.071 EspTouchDemo[5787:2927996] ESPTouchTask __listenAsyn() receive rubbish message, just ignore
2015-11-20 11:09:33.110 EspTouchDemo[5787:2929212] ESPTouchTask __sleep() end, receive signal is NO
2015-11-20 11:09:33.110 EspTouchDemo[5787:2929212] ###################server close() fd=10
: Bad file descriptor
2015-11-20 11:09:33.111 EspTouchDemo[5787:2927996] ESPTouchTask __listenAsyn() receive rubbish message, just ignore
2015-11-20 11:09:33.111 EspTouchDemo[5787:2929212] ESPTouchTask __notify()
2015-11-20 11:09:33.111 EspTouchDemo[5787:2927996] ESPTouchTask __notify()
2015-11-20 11:09:33.112 EspTouchDemo[5787:2927996] ESPTouchTask __listenAsyn() finish
2015-11-20 11:09:33.112 EspTouchDemo[5787:2929212] ESPViewController executeForResult() result is: (
"[isSuc: NO,isCancelled: NO,bssid: (null),inetAddress: 0.0.0.0]"
串口调试输出的后端日志如下:
ets Jan 8 2013,rst cause:1, boot mode:(3,2)
tail 4
chksum 0x89
tail 4
chksum 0xe8
tail 8
chksum 0xc0
csum 0xc0
2nd boot version : 1.4(b1)
SPI Speed : 40MHz
SPI Mode : QIO
jump to run user1 @ 1000
pp_task_hdl : 3fff2750, prio:13, stack:512
pm_task_hdl : 3fff3030, prio:1, stack:176
ApiMsgMutex created
tcpip_task_hdl : 3fff3448, prio:10,stack:512
wdt_task : 3fff3d08, prio:14, stack:176
idle_task_hdl : 3fff4878
tim_task_hdl : 3fff4c70
xPortStartScheduler
frc2_timer_task_hdl:3fff5580, prio:12, stack:512
OS SDK ver: 1.2.0(b900bd2) compiled @ Aug 28 2015 17:18:41
phy ver: 356, pp ver: 9.0
SDK version:1.2.0(b900bd2)
mode : sta(18:fe:34:a4:8c:34) + softAP(1a:fe:34:a4:8c:34)
add if0
add if1
bcn 100
IOT VERSION:v1.0.5t23701(a)
user_plug_init start!
wifi_station_get_ap num 0
apnetif->dhcps_pcb = 1073706632
bcn 0
del if1
configing...
C > multi_conn_init ok!
smartconfig_task start
SC version: V2.4.7configing...
scandone
configing...
scandone
SC_STATUS_FIND_CHANNEL
configing...
configing...
configing...
configing...
configing...
可见,后端的平台任务线程一直等待configing完成,而smart config 任务线程不能接收到手机APP发出的SSID和PASSWD指令,无法进入到SC_STATUS_GETTING_SSID_PSWD状态
同时,开发板上的smart config LED蓝色灯一会慢闪一阵,一会快闪一阵子,不断这样变化,请问问题在什么地方?
ESP_Alfred
Re: ESP Touch smart config不成功
Postby ESP_Alfred » Fri Nov 20, 2015 4:33 pm
Postby leely » Wed Nov 25, 2015 11:06 am
再次安装EspTouch到ipad或者iphone6,运行就不成功了。开发板输出:
T|once 1 80
20:0c:c8:06:f3:c1: 594
20:0c:c8:06:f3:c1: 593
20:0c:c8:06:f3:c1: 592
20:0c:c8:06:f3:c1: 595
T|once 2 80
save, rssi:-74 20:0c:c8:06:f3:c1:
这是怎么回事?什么情况下会打印这样的信息?
ESP_Alfred
Postby ESP_Alfred » Thu Nov 26, 2015 11:38 am
leely wrote:今天开发板使用non-os sc 2.4和2.5.1, ipad iOS 9.0,直接运行EspTouch,成功。
T|once 1 80
T|once 2 80
能否多测试几次,提供全一点的log给我。可以把log打包成文件发上来。
Postby mijin » Wed Dec 09, 2015 1:10 am
I have the same issue on the iPhone 6 (iOS9).
https://github.com/EspressifApp/EsptouchForIOS
It keeps failing.
2015-12-08 16:52:46.106 EspTouchDemo[2490:492596] ESPViewController do confirm action...
2015-12-08 16:52:46.111 EspTouchDemo[2490:493315] ESPViewController do the execute work...
2015-12-08 16:52:46.112 EspTouchDemo[2490:493315] ESPTouchTask init
2015-12-08 16:52:46.113 EspTouchDemo[2490:493315] ##########################client init() _sck_fd=5
2015-12-08 16:52:46.114 EspTouchDemo[2490:493315] ##########################server init(): _sck_fd=6
2015-12-08 16:52:46.115 EspTouchDemo[2490:493315] ESP_NetUtil:: 192.168.1.192
2015-12-08 16:52:46.116 EspTouchDemo[2490:493315] ESPTouchTask executeForResult() localInetAddr: 192.168.1.192
2015-12-08 16:52:52.496 EspTouchDemo[2490:493315] ESPTouchTask __execute() send gc code
2015-12-08 16:52:52.497 EspTouchDemo[2490:493291] ESPTouchTask beginBackgroundTask() entrance
2015-12-08 16:52:52.499 EspTouchDemo[2490:493291] ESPTouchTask __listenAsyn() start an asyn listen task, current thread is: <NSThread: 0x127e86c90>{number = 2, name = (null)}
2015-12-08 16:52:52.499 EspTouchDemo[2490:493291] ESPTouchTask __listenAsyn() expectOneByte: 27
2015-12-08 16:52:58.501 EspTouchDemo[2490:493315] ESPTouchTask __execute() send gc code
2015-12-08 16:53:04.527 EspTouchDemo[2490:493315] ESPTouchTask __execute() send gc code
2015-12-08 16:53:10.532 EspTouchDemo[2490:493315] ESPTouchTask __execute() send gc code
2015-12-08 16:53:16.551 EspTouchDemo[2490:493315] ESPTouchTask __execute() send gc code
2015-12-08 16:53:22.568 EspTouchDemo[2490:493315] ESPTouchTask __execute() send gc code
2015-12-08 16:53:28.587 EspTouchDemo[2490:493315] ESPTouchTask __execute() send gc code
2015-12-08 16:53:34.597 EspTouchDemo[2490:493315] ESPTouchTask __execute() send gc code
2015-12-08 16:53:37.524 EspTouchDemo[2490:493315] ESPTouchTask __sleep() start
2015-12-08 16:53:52.476 EspTouchDemo[2490:493291] ESPTouchTask __listenAsyn() receive rubbish message, just ignore
2015-12-08 16:53:52.529 EspTouchDemo[2490:493315] ESPTouchTask __sleep() end, receive signal is NO
2015-12-08 16:53:52.530 EspTouchDemo[2490:493315] ###################server close() fd=6
2015-12-08 16:53:52.530 EspTouchDemo[2490:493291] ESPTouchTask __listenAsyn() receive rubbish message, just ignore
2015-12-08 16:53:52.530 EspTouchDemo[2490:493291] ESPTouchTask __notify()
2015-12-08 16:53:52.530 EspTouchDemo[2490:493315] ESPTouchTask __notify()
2015-12-08 16:53:52.531 EspTouchDemo[2490:493291] ESPTouchTask __listenAsyn() finish
2015-12-08 16:53:52.531 EspTouchDemo[2490:493315] ESPViewController executeForResult() result is: (
"[isSuc: NO,isCancelled: NO,bssid: (null),inetAddress: 1.0.0.0]"
2015-12-08 16:53:52.534 EspTouchDemo[2490:493291] ESPTouchTask endBackgroundTask() entrance
Any advices in English would be helpful.
M
Postby ESP_Faye » Wed Dec 09, 2015 4:58 pm
Sorry that we can not duplicate your problem. We tested it on iPhone 6(iOS9), and succeed.
In your case, did it fail every time ? Or it just failed sometimes ?
Could your provide the ESP8266's UART output logs for debugging ?
Postby mijin » Mon Dec 14, 2015 7:24 pm
It works randomly in the office which has many sources of interference (with unnecessary amounts of 2.4 Ghz Aps). It seems it doesn't receive any data. See logs below. But when testing at home, it works all the time on both android, iOS apps without giving any failure messages.
Log
*** SMARTCONFIG MODE ***
bcn 0
del if1
usl
mode : sta(5c:cf:7f:12:11:78)
add if0
SC version: V2.5.3
f r0, scandone
f r0, scandone
*** READY TO GET DATA [14422ms] ***
UPDATE: our router supports 2.4Ghz and 5 Ghz bands. It didn't work when packs were broadcasted to 5Ghz.
M
