gdbstub linking will not fit in iram1_0_seg
User avatar
kolban
Postby kolban » Mon Nov 23, 2015 1:38 am
I have downloaded the esp-gdbstub repository, compiled the sources and placed them in an archive. When I now try and link the gdbstub archive with me simple C application, I find that I get the error:
a.out section `.text' will not fit in region `iram1_0_seg'
Running objdump -h over the archive produces the following:
gdbstub.o:     file format elf32-xtensa-le
Sections:
Idx Name          Size      VMA       LMA       File off  Algn
  0 .literal      00000000  00000000  00000000  00000034  2**2
                  CONTENTS, ALLOC, LOAD, READONLY, CODE
  1 .irom0.literal 00000000  00000000  00000000  00000034  2**2
  2 .text         00001133  00000000  00000000  00000034  2**2
                  CONTENTS, ALLOC, LOAD, RELOC, READONLY, CODE
  3 .data         00000008  00000000  00000000  00001168  2**2
                  CONTENTS, ALLOC, LOAD, DATA
  4 .bss          00000128  00000000  00000000  00001170  2**2
                  ALLOC
  5 .rodata       000000aa  00000000  00000000  00001170  2**2
                  CONTENTS, ALLOC, LOAD, READONLY, DATA
  6 .irom0.text   000000c2  00000000  00000000  0000121c  2**2
  7 .comment      00000022  00000000  00000000  000012de  2**0
                  CONTENTS, READONLY
  8 .xtensa.info  00000038  00000000  00000000  00001300  2**0
                  CONTENTS, READONLY
  9 .xt.lit       000000b8  00000000  00000000  00001338  2**0
                  CONTENTS, RELOC, READONLY
 10 .xt.prop      00000be8  00000000  00000000  000013f0  2**0
gdbstub-entry.o:     file format elf32-xtensa-le
Sections:
  1 .text         0000023f  00000000  00000000  00000034  2**2
  2 .data         00000000  00000000  00000000  00000273  2**0
  3 .bss          00000000  00000000  00000000  00000273  2**0
                  ALLOC
  4 .xtensa.info  00000038  00000000  00000000  00000273  2**0
                  CONTENTS, READONLY
  5 .xt.lit       00000008  00000000  00000000  000002ab  2**0
  6 .xt.prop      00000144  00000000  00000000  000002b3  2**0
Has anyone run up against this puzzle before?
Also raised as Github espressif/esp-gdbstub Issue #2.
