my compiler throws out warnings. I need to fix that manually whenever i download a new sdk version.
LOG:
In file included from /opt/Espressif/ESP8266_SDK/include/ets_sys.h:12:0,
from driver/i2c_master.c:11:
driver/i2c_master.c: In function 'i2c_master_gpio_init':
/opt/Espressif/ESP8266_SDK/include/eagle_soc.h:249:38: error: suggest parentheses around arithmetic in operand of '|' [-Werror=parentheses]
& (~(PERIPHS_IO_MUX_FUNC<<PERIPHS_IO_MUX_FUNC_S)) \
/opt/Espressif/ESP8266_SDK/include/eagle_soc.h:50:98: note: in definition of macro 'WRITE_PERI_REG'
#define WRITE_PERI_REG(addr, val) (*((volatile uint32_t *)ETS_UNCACHED_ADDR(addr))) = (uint32_t)(val)
driver/i2c_master.c:108:5: note: in expansion of macro 'PIN_FUNC_SELECT'
PIN_FUNC_SELECT(I2C_MASTER_SDA_MUX, I2C_MASTER_SDA_FUNC);
driver/i2c_master.c:109:5: note: in expansion of macro 'PIN_FUNC_SELECT'
PIN_FUNC_SELECT(I2C_MASTER_SCL_MUX, I2C_MASTER_SCL_FUNC);
cc1: all warnings being treated as errors
NOK SOURCE: (from eagle_soc.h)
#define PIN_PULLUP_DIS(PIN_NAME) CLEAR_PERI_REG_MASK(PIN_NAME, PERIPHS_IO_MUX_PULLUP)
#define PIN_PULLUP_EN(PIN_NAME) SET_PERI_REG_MASK(PIN_NAME, PERIPHS_IO_MUX_PULLUP)
#define PIN_FUNC_SELECT(PIN_NAME, FUNC) do { \
WRITE_PERI_REG(PIN_NAME, \
READ_PERI_REG(PIN_NAME) \
|( (((FUNC&BIT2)<<2)|(FUNC&0x3))<<PERIPHS_IO_MUX_FUNC_S) ); \
} while (0)
CORRECTED SOURCE: (from eagle_soc.h) ADDED ( )
( READ_PERI_REG(PIN_NAME) \
& (~(PERIPHS_IO_MUX_FUNC<<PERIPHS_IO_MUX_FUNC_S)) )\
} while (0)
Compiler warning
Re: Compiler warning
Postby ESP_Faye » Mon Nov 30, 2015 5:02 pm
Here is our compile environment, we offered a VirtualBox to set up it on windows PC.
Or you can refer to https://github.com/pfalcon/esp-open-sdk to set up a compile environment on Linux PC.
And we will also optimize it in next SDK.
Postby rudi » Tue Dec 01, 2015 5:55 am
Espressif_Faye wrote:Here is our compile environment, we offered a VirtualBox to set up it on windows PC.
prev post was edit:
changed link to: https://github.com/pfalcon/esp-open-sdk
Hi Faye,
i am unsure , you ment. to "the most wanted" ESP32 SDK
(this is fun)
btw:
yes, the setup for a compile env. is best descr. in the ESP32 SDK git.
txs for this!
we can use the same Virtual Box we use for ESP8266 for the ESP32 SDK?
can you answere this asap? because we install system for ESP32 SDK next time on extra System, so i ask for Linux User Group ..
best wishes
rudi
edit 02 DEZ 2015:
thanks for edit the link
btw, i have a try in the ESP8266 VM to install the ESP32 Toolchain you ment.
http://esp32.com/viewtopic.php?f=2&t=21
問候飛出去的朋友遍全球魯迪
