ESP-01 hangs and resets itself without AT+RST command
magnetron
Postby magnetron » Wed Nov 25, 2015 9:52 pm
hello dear forum,
I upgraded my ESP-01 to version “0020000903”
I try to make webserver application - ( I succeeded , I was able to see my webpage at google chrome )
everything is fine however after 5 minutes standby
ESP doesnot receive ethernet packets from Google Chrome anymore
when I ping it from PC the packets are lost
and when I tried to give AT command it suddenly resetted itself
why is that so ?
thank you
Re: ESP-01 hangs and resets itself without AT+RST command
Postby ESP_Faye » Thu Nov 26, 2015 1:45 pm
Could you have a try with our latest AT v0.50 http://bbs.espressif.com/viewtopic.php?f=46&t=1123 ?
Please use Espressif official Flash download tool to burn the bin files into Flash.
magnetron
Postby magnetron » Thu Nov 26, 2015 8:40 pm
Hello
please : where is readme.txt located ?
thank you
Postby ESP_Faye » Fri Nov 27, 2015 10:13 am
The "readme.txt" is with the AT bin files.
You need to download the latest AT v0.50, and unzip it, you can find the "readme.txt" in it.
magnetron
Postby magnetron » Fri Nov 27, 2015 9:41 pm
hello ,
I read readme.txt
what is boot mode ?
what is non boot mode ?
do I have to download both boot and non boot files ?
I have ESP-01 / what is the flash size ? which files do I need to download ?
I dinot understand the update steps
do you have a more clear explanation ?
thank you
Postby ESP_Faye » Wed Dec 02, 2015 2:21 pm
boot mode : can use "AT+CIUPDATE" command to upgrade AT firmware through WiFi, your Flash size needs to be 1MBytes or larger.
non-boot mode: can NOT use "AT+CIUPDATE" command to upgrade AT firmware through WiFi, for 512KBytes Flash.
Use Espressif official Flash Download Tool, it will detect the size of your Flash while downloading and show it in "DETECTED INFO" area.
