[SDK Release] ESP8266_NONOS_SDK_V1.5.0_15_11_27
Admin
Site Admin
Postby Admin » Fri Nov 27, 2015 7:43 pm
请勿使用本旧版本 SDK,建议使用 最新发布 SDK。
ESP8266_NONOS_SDK_V1.5.0_15_11_27 Release
Important Links
Here are the links for this SDK release (version ESP8266_NONOS_SDK_V1.5.0_15_11_27):
  1. Download Related Documentation
  2. Bug Bounty Program
Release Notes
  1. Returned value of system_get_rst_info is wrong.
Optimization:
  1. Optimize espconn_regist_recvcb for UDP transmission.
  2. Print information will prompt errors if the input parameters of os_time_arm excess the upper limit.
  3. Optimize memory management.
  4. Optimize RF frequency offset.
  5. Print information will prompt errors if the size of bin file is too large in OTA. OTA can NOT update to the older Version.
  6. Optimize mDNS.
  7. Revise UART output print error when powered on again after call system_uart_swap.
  8. Revise errors during multiple UDP transmissions.
  9. Revise the error when wifi_station_set_config_default is called and the same AP is set as before, while information cannot be stored in the Flash.
  10. Optimize the error of packet loss during UDP transmission process under single station mode.
  11. Add new function, WPA2-Enterprise is supported.
  12. SmartConfig version is upgraded to V2.5.3.
  13. Mesh version is upgraded to V0.2.3.
  14. User application needs to add "-lcrypto" in 'LINKFLAGS_eagle.app.v6" area of Makefile.
Added APIs:
  1. espconn_abort: break TCP connection compulsively.
  2. espconn_secure_delete: delete the SSL server when ESP8266 runs as SSL server.
  3. wifi_station_set_cert_key: set certificate and private key for WPA2 Enterprise.
  4. wifi_station_clear_cert_key: release the resouce of connecting to WPA2 Enterprise AP, and clear the status.
AT_v0.51 Release Note:
  1. Since this ESP8266_NONOS_SDK_V1.5.0, AT firmware is too large to fit in 4Mbit (512KB) Flash. Please use 8Mbit (1MB) or larger Flash.
  2. Revise the error of the first byte in AT command when UART RX interrupt handler is implemented.
  3. Revise the malfunction of display when AT+CWLAP is invoked to scan a specific AP.
Have fun!
ESP8266_NONOS_SDK_V1.5.0_15_11_27发布
相关下载
    以下是最新SDK的相关下载链接 (版本 ESP8266_NONOS_SDK_V1.5.0_15_11_27):
  1. 文档下载链接。
  2. 您可以继续参与 Bug Bounty 计划。
发布说明
修正问题(符合乐鑫 Bug 赏金计划):
  1. system_get_rst_info 返回值异常
优化:
  1. 针对 UDP 传输,优化 espconn_regist_recvcb。
  2. 优化 os_time_arm,如果传入的参数超过上限,打印信息会提示错误。
  3. 优化内存管理。
  4. 优化 RF 频偏部分。
  5. 优化 OTA 升级,bin 文件过大时提示错误。此版本及之后的 OTA 不支持升级到之前的旧版本。
  6. 优化 mDNS 。
  7. 修正调用 system_uart_swap 后,重新上电打印出错的问题。
  8. 修正多个 UDP 传输的情况下,传输出错的问题。
  9. 修正调用 wifi_station_set_config_default 设置同一 AP 信息不保存到 Flash 的问题。
  10. 修正 UDP 传输在单 station 模式下丢包的问题。
  11. 新增支持 WPA2 Enterprise。
  12. SmartConfig 更新到版本 2.5.3。
  13. mesh 更新到版本 0.2.3。
  14. 请注意,用户的应用程序需要在 Makefile 的 LINKFLAGS_eagle.app.v6 字段中添加 -lcrypto。
新增 APIs:
  1. espconn_abort : 强制断开 TCP 连接。
  2. espconn_secure_delete :ESP8266 作为 SSL server 时,可删除此 SSL server。
  3. wifi_station_set_cert_key :设置 WPA2 Enterprise 私钥和证书。
  4. wifi_station_clear_cert_key :释放连接 WPA2 Enterprise AP 占用的资源,并清除状态。
  1. 从当前版本 ESP8266_NONOS_SDK_V1.5.0 起,AT 固件所需空间增大,无法再使用 4Mbit (512KB) Flash,请使用 8Mbit (1MB) 或以上容量 Flash。
  2. 修正 AT 中,用户使用uart接收中断处理时,第一个字节是错误的问题。
  3. 修正 AT+CWLAP 扫描特定 AP 不显示的问题。
感谢您对 ESP8266 的关注!
esp_iot_sdk_v1.5.0_15_11_27.zip
(2.08 MiB) Downloaded 35869 times
