[SOLVED]Flashing chip in 32MBit(1024K+1024K) mode
pieceofsummer
Postby pieceofsummer » Fri Dec 04, 2015 10:03 pm
Hello.
I've compiled a firmware with SPI_MODE_MAP=6, and it works fine after flashing it at 0x01000 address in 32Mbit flashing mode, but loader (1.4b1) shows it is 32Mbit(512K+512K) mode (I've also tried 16Mbit(1024K+1024K), and the firmware works fine as well).
Now I'm trying to flash it in 32Mbit-C1 mode, and after flashing loader shows it correctly as 32Mbit(1024K+1024K), but it never gets to user code. It prints:
tail 4
chksum 0x89
tail 4
chksum 0xe8
tail 8
chksum 0xc0
csum 0xc0
2nd boot version : 1.4(b1)
  SPI Speed      : 80MHz
  SPI Mode       : QIO
  SPI Flash Size & Map: 32Mbit(1024KB+1024KB)
jump to run user1 @ 1000
and never gets any further.
I've tried to download firmware both with Firmware Download Tools on Windows and esptool on Linux, and outcome is the same, so I believe it must be some bootloader issue.
Or am I doing something wrong specific to this mode?
Thanks,
Alex.
Re: Flashing chip in 32MBit(1024K+1024K) mode
Postby ESP_Faye » Sat Dec 05, 2015 3:23 pm
Have you downloaded blank.bin to 0xFE000 and 0x3FE000 for initialization ?
pieceofsummer
Postby pieceofsummer » Sat Dec 05, 2015 6:40 pm
Oh, I've flashed it only to 0xFE000. After flashing it to 0x3FE000 as well it started working, thanks!
I wonder, how it worked fine before in 16M(1024+1024) and 32M(512+512) modes without flashing blank.bin?
Postby ESP_Faye » Mon Dec 07, 2015 2:25 pm
If you did not initialize (burn blank.bin), it will be random value. So it maybe can work,maybe not. It is not safe.
So please always download blank.bin for initialization.
SpenZerX
Contact:
Re: [SOLVED]Flashing chip in 32MBit(1024K+1024K) mode
Postby SpenZerX » Sun Jan 24, 2016 8:31 pm
Strange,
my SDK has no 1024+1024 mode!
or we are talking about 512+512?
eagle.app.v6.new.1024.app1+2.ld ?
