android-esp8266-01 and arduino
alexgr2006
Postby alexgr2006 » Sat Dec 05, 2015 2:52 am
Hello I use App inventor for android applications and arduino and esp8266-01
(My esp8266 is:Image).
and my firmware esp8266-01 is:
AT version:0.25.0.0(Jun 5 2015 16:27:16)
SDK version:1.1.1
Ai-Thinker Technology Co. Ltd.
Jun 23 2015 23:23:50
my connection esp8266+arduino is:
ESP8266 ====== Arduino
TX ====== 11 pin
RX ====== 10 pin
GND ====== GND
CH_PD ====== 3.3V
+3v3 ====== 3.3V
RST ====== -------
GPIO2 ====== -------
GPIO0 ====== -------
My code for app inventor:
if i press the button from my android app the led is on and if realease the button the led is off but sometimes stuck..
can help anyone?
do i have to do update firmware my esp8266-01? if yes can give me one link?
My arduino code is:
    #include <SoftwareSerial.h>
    #define DEBUG false
    SoftwareSerial esp8266(11,10); // make RX Arduino line is pin 11, make TX Arduino line is pin 10.
                                 // This means that you need to connect the TX line from the esp to the Arduino's pin 11
                                 // and the RX line from the esp to the Arduino's pin 10
    void setup()
      Serial.begin(9600);
      esp8266.begin(115200); // your esp's baud rate might be different
      pinMode(8,OUTPUT);
      digitalWrite(8,LOW);
      pinMode(6,OUTPUT);
      digitalWrite(6,LOW);
      pinMode(9,OUTPUT);
      digitalWrite(9,LOW);
     sendData("AT+RST\r\n",2000,DEBUG); // reset module
     sendData("AT+CWMODE=2\r\n",1000,DEBUG); // configure as access point   AP=2, STA=1, 3=BOTH
     sendData("AT+CIFSR\r\n",1000,DEBUG); // get ip address
     sendData("AT+CIPMUX=1\r\n",1000,DEBUG); // configure for multiple connections
     sendData("AT+CIPSERVER=1,80\r\n",1000,DEBUG); // turn on server on port 80
    void loop()
      if(esp8266.available()) // check if the esp is sending a message
        int connectionId = esp8266.read()-48; // subtract 48 because the read() function returns
                                               // the ASCII decimal value and 0 (the first decimal number) starts at 48
               String t;
                esp8266.find("/?"); // advance cursor to "pin="
               while (esp8266.available())
                  t+=(char)esp8266.read();//read byte,convert to char and append it to string
                  if (t.length()==2){break;}
              if(t=="on")
             digitalWrite(8, HIGH);
                Serial.write("ON \n");
              else if(t=="of")
                  digitalWrite(8, LOW);
                Serial.write("OFF \n");
                if(t=="6o")
             digitalWrite(6, HIGH);
                Serial.write("LED is ON \n");
              else if(t=="6f")
                  digitalWrite(6, LOW);
                Serial.write("LED is OFF \n");
         // make close command
       String closeCommand = "AT+CIPCLOSE=";
       closeCommand+=connectionId; // append connection id
       closeCommand+="\r\n";
         sendData(closeCommand,10,DEBUG); // close connection.
    }//loop
    * Name: sendData
    * Description: Function used to send data to ESP8266.
    * Params: command - the data/command to send; timeout - the time to wait for a response; debug - print to Serial window?(true = yes, false = no)
    * Returns: The response from the esp8266 (if there is a reponse)
    String sendData(String command, const int timeout, boolean debug)
        String response ="";
        esp8266.print(command); // send the read character to the esp8266
        long int time = millis();
        while( (time+timeout) > millis())
          while(esp8266.available())
            // The esp has data so display its output to the serial window
            char c = esp8266.read(); // read the next character.
            response+=c;
        if(debug)
          Serial.print(response);
        return response;
    }//end sendData
