it show " ets Jan 8 2013,rst cause:2, boot mode:(6,6) \r\n waiting for host" (foget the boot mode first 6)
the UART is set enable RTS/CTS. and the RTS also rise and fall. the test client stop send data when esp8266 rise the RTS signal. it restart send when esp8266 RTS fall.
//set Rx hardware flow control
if((pconfig->hwflowctrl == USART_HardwareFlowControl_CTS_RTS) || (pconfig->hwflowctrl == USART_HardwareFlowControl_RTS))
SET_PERI_REG_MASK(UART_CONF1(uart_no), ((0x78 & UART_RX_FLOW_THRHD) << UART_RX_FLOW_THRHD_S) | UART_RX_FLOW_EN );
in the UART ISR, read data from FIFO, stored to buffer(512 bytes size), then system_os_post() to active the UART task to handle these datas. the UART task queue size is 64. (512/(128*3/4)= 5.333)
