how do disable os_printf output using RTOS-SDK?
ecl66
Postby ecl66 » Wed Dec 09, 2015 1:58 am
Greetings to All,
Using the non-RTOS SDK, there is a function to disable os_printf output.
Unfortunately, this function doesn't work using the RTOS SDK: do you know any way to do so?
Many thanks,
Emmanuel
Re: how do disable os_printf output using RTOS-SDK?
Postby ESP_Faye » Thu Dec 10, 2015 11:39 am
Here is an example. But it will disable all logs, if something goes wrong, you can not track it by logs, we do not suggest it.
void user_printf(char c)
   // do nothing here
os_install_putc1(user_printf);
Or you can define your own trace
#ifdef USER_DEBUG
#define TRACE    printf
#else
#define TRACE
#endif
ecl66
Postby ecl66 » Fri Dec 11, 2015 12:52 am
Thanks for your reply.
Actually another easy way was to redefine os_printf (within an #ifdef) and to comment out the original definition in esp_libc.h (also within an #ifdef).
best regards,
