[Solved] Cannot boot user2
clinkme
Postby clinkme » Sun Dec 20, 2015 1:59 am
I have ESP-01E with 1024 kB flash size. My firmware uses OTA (no upgrade server,
just writing data from web to the right address of flash - 0x1000 for user1 or 0x81000 for user2,
and then call system_upgrade_flag_set(UPGRADE_FLAG_FINISH);).
I get the strange error code when trying to boot from user2.bin when using flash map
8Mbit(512KB+512KB).
E:M 0
When I revert the boot to user1.bin (erasing 0xFE000 sector), the chip boots OK from user1.bin.
Also, when I use flash map 8Mbit(256KB+256KB), both user1.bin & user2.bin are working OK.
tail 4
chksum 0x89
tail 4
chksum 0xe8
tail 8
chksum 0xc0
csum 0xc0
2nd boot version : 1.4(b1)
  SPI Speed      : 40MHz
  SPI Mode       : DIO
jump to run user2 @ 81000
E:M 0
E:M 0
Solved. There was a problem in makefile (user1 was linked for 1024k flash, but user2 for 512k).
Re: Cannot boot user2
Postby ESP_Faye » Tue Dec 22, 2015 2:34 pm
Please call "make clean" first to delete the files generated in previous compilation (user1.bin), then compile user2.bin.
