Free RAM in ESP-WROOM-02 Wifi Module
ritesh
Contact:
Postby ritesh » Thu Jan 07, 2016 12:31 pm
I have flashed AT Firmware 0.50 which is based on SDK 1.4.0. Now, I want to know howmych RAM is freed based on following informations.
load 0x40100000, len 28076, room 16
tail 12
chksum 0x66
ho 0 tail 12 room 4
load 0x3ffe8000, len 2004, room 12
tail 8
chksum 0x3b
load 0x3ffe87e0, len 5120, room 0
tail 0
chksum 0x97
csum 0x97
Does anyone has idea about how IRAM and DRAM is allocated and howmuch RAM is freed for ESP-WROOM-02 Wifi Module?
Regards,
Ritesh Prajapati
Regards,
Ritesh Prajapati
Re: Free RAM in ESP-WROOM-02 Wifi Module
Postby ESP_Faye » Fri Jan 08, 2016 11:41 am
You can call system_get_free_heap_size() in the user_init, to get the size of free heap. It is about 45~50 KB.
ritesh
Contact:
Postby ritesh » Fri Jan 08, 2016 2:01 pm
I have called "system_get_free_heap_size()" and got around 34208 Bytes. I want to know that "system_get_free_heap_size()" returns total size of DRAM and IRAM which are freed or only IRAM or DRMA which is freed?
Also, let me know how DRAM and IRAM is oragnized in ESP-WROOM-02 Wifi Module if anyone knows about it.
I want to understand how IRAM and DRMA is managed in this ESP-WROOM-02 Wifi Module.
Regards,
Ritesh Prajapati
Regards,
Ritesh Prajapati
Postby ESP_Faye » Mon Jan 11, 2016 2:57 pm
"system_get_free_heap_size()" gets the size of available DRAM.
For ESP8266_NONOS_SDK, IRAM stores the functions without "ICACHE_FLASH_ATTR". Other functions will be stored in Flash, and run in cache when it is called. More details in http://bbs.espressif.com/viewtopic.php?f=61&t=366&p=1345#p1345.
ritesh
Contact:
Postby ritesh » Tue Jan 12, 2016 6:19 pm
Thanks for Reply.
SO, it seems like code without ICACHE_FLASH_ATTR stored in IRAM which is limited in size while code with ICACHE_FLASH_ATTR stored in CACHE Memory which is ROM and depends on SPI Flash Memory Size.
Currently, ESP-WROOM-02 has < 36KB of IRAM and 80 KB of DRAM so that User has to develop application in such a way to store less code in IRAM.
Regards,
Ritesh Prajapati
Regards,
Ritesh Prajapati
Users browsing this forum: No registered users and 193 guests
